H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 67 - Overclock.net - An Overclocking Community
post #662 of 1518 (permalink) Old 03-12-2013, 04:26 AM
Zamora's Avatar
Rep: 1 (Unique: 1)
Hi Guys,
Looks like it's upgrade time and I need to know if the Corsair H110 cooler will fit in the top of my Coolermaster ATCS 840.
I have a feeling it will fit but need to double check before purchasing.
Cheers
Zamora is offline
post #663 of 1518 (permalink) Old 03-16-2013, 12:37 AM
polycount's Avatar
Rep: 0
hello all, I have one big question smile.gif will H110 fit into Thermaltake GT10 at the top? Thanks a lot !
polycount is offline
post #664 of 1518 (permalink) Old 03-16-2013, 01:39 AM
Coach Mcguirk's Avatar
Rep: 20 (Unique: 17)
Hmmm, I dont see the NZXT Source 210 Elite in there.
Budget Box
(16 items)
i5 4690
MSI H97 PC Mate
EVGA GeForce GTX 1660Ti XC Ultra
Crucial CT250MX
Toshiba
External USB 3.0 Seagate
Optical Drive
DVDRW 24x
EVGA
Cooler Master Hyper T4
Enermax
Operating System
Windows 10 Home 64
Acer IPS 2560 x 1440p
Keyboard
Logitech Mechanical
Mouse
Steel Series
Mousepad
Steel Series
Audio
Insignia 2.1
Coach Mcguirk is offline
post #665 of 1518 (permalink) Old 03-16-2013, 01:38 PM
trojan92's Avatar
Rep: 100 (Unique: 86)
NZXT Source 210
H80i
Fitted into the rear of the case
No mods required.
E5400 @ 3.0ghz > Q8300 @ 3.1ghz > 3570K @ 4.5ghz > 4930K @ 4.5ghz > R7 3800X
GT 240 > GTX 460 > GTX 570 > GTX 650 > HD 7850 > HD 7970 > XFX HD 7990 > Sapphire R9 290 TRI-X OC x2 > GTX 980 Jetstream > GTX 980 Ti
trojan92 is offline
post #666 of 1518 (permalink) Old 03-21-2013, 09:48 PM
Titaniumhold's Avatar
Rep: 0
Corsair H110 Does fit in a Thermaltake chaser MK-1. Some modding was required (drilling new holes) 4/8 holes in rad secured to case with screws, it doesn't move at all but I used zip-ties through the existing 4 holes in the rad for good measure. Stock thermaltake colorshift 200mm fan(s) 1 or two still fit above rad and the 140mm fans included with the H100 fit also. I have an asrock extreme 6 mobo with a rather tall phase converter heatsink at the top, easily clears this as well.
Titaniumhold is offline
post #667 of 1518 (permalink) Old 03-21-2013, 10:38 PM
Originally Posted by trojan92 View Post
NZXT Source 210
H80i
No mods required.
Hey, I'm about to buy that in case you got, early April (black). Does the case panel, behind the motherboard, also come off? Wanted to know if I can easily install the rear part of the H80i cooler, without having to take the whole motherboard out. Thanks.
Budget Box
(16 items)
i5 4690
MSI H97 PC Mate
Crucial CT250MX
Toshiba
Optical Drive
DVDRW 24x
EVGA
Enermax
Operating System
Windows 10 Home 64
Keyboard
Logitech Mechanical
Mouse
Steel Series
Mousepad
Steel Series
Audio
Insignia 2.1
post #668 of 1518 (permalink) Old 03-23-2013, 06:22 AM
elmosworld's Avatar
Rep: 0
Originally Posted by [email protected] View Post
H100 fits in the top of the Define R4 (w/out any modding). Mount it off-set (using 140mm fan mounting holes) if you have tall MOSFIT heatsinks***
Which motherboard did you use in here?
Will a H110 fit?
elmosworld is offline
post #669 of 1518 (permalink) Old 03-23-2013, 12:26 PM
Junkie62's Avatar
Rep: 0
The rad will fit inside the case with the fans on top.The hoses should go toward the front of the case or you will have to remove the rear case fan.Just got mine installed and it fit nicely.Motherboard is an ASUS P8Z68-V Pro.The fans are rattling at high speed so I am going to set up an RMA with Corsair. This is with the Corsair 500R
Junkie62 is offline
post #670 of 1518 (permalink) Old 03-24-2013, 05:01 AM - Thread Starter
Rep: 87 (Unique: 80)
OP updated, I'll try and find some time to research questions that have been asked soon, been mega busy of late. Cheers all!
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
