H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 68 - Overclock.net - An Overclocking Community
post #671 of 1518 (permalink) Old 03-25-2013, 05:01 PM
Overtorque's Avatar
Rep: 7 (Unique: 3)
Corsair H100i fitted in in the upper ceiling of a Zalman Z11 plus, with fans in push on the top.
Little mod was required as drilling new holes and replace the top fins coverage .
It works at the best in conjunction with the airflow provided by a Corsair AF140 fan mounted in the upper front 5.25 bay area and the rear AF120 fan as exhaust.
Overtorque is offline
post #672 of 1518 (permalink) Old 03-25-2013, 05:43 PM
cplifj's Avatar
Rep: 5 (Unique: 5)
Corsair H110 fitted to carbide 300r, minor modding of top grill, either the fans or the rad have to sit on top of the grill.
here is a link : https://www.overclock.net/t/1307044/official-corsair-300r-owners-fan-club-and-guide-post-build-logs-and-mods/120#post_19597739
a radiator grill on top would be even nicer, i have to look for one.
System : i7-3770 (4.1 GHz Allcore OC) / 16 GB Corsair Dominator platinum cl9 1600MHz ram / Asus P8Z77-M / RX Vega 64 LC / R9290X secondary / SSD Intel 520 series + Samsung 850 evo + kingston UV400 / 2x 2TB Seagate HD / DVD-WR / Corsair H110 AIO LC (cpu) / 2x Front Intake fan / Corsair HX1000i psu / Iiyama GB2888ushu 4k freesync monitor / Corsair K70 rapidfire rgb / Logitech G502 / Corsair void usb. + a ghost that sometimes acts up.
cplifj is offline
post #673 of 1518 (permalink) Old 03-26-2013, 10:27 AM
icsd08063's Avatar
Rep: 1 (Unique: 1)
Originally Posted by jotavip View Post
Hi. I was able to fit the H100i in my CM690 Nvidia Edition standard case. The only thing is that fixing the radiator on the top was a bit tricky.
I was only able to fix two screws of the radiator, my motherboard is an Asus Rampage Extreme II, and it have a heatsink sitting in some capacitors above the CPU slot. This heatsink blocked the radiator to be placed in the correct position. But even with only two screws the radiator was firmily attached.
But I think the temps are high. My CPU is an i7 920. I used Real Temp to measure it
At 2.6 GHz: 40 on idle and 65 load.
At 3.2 GHz: 50 idle and 75 load.
I searched around, and the temps should be around 10 ~ 15 degrees lower. Anyone has suggestions to low the temps?
below is a picture of my installation:
Good evening from Greece,
Well, recently i upgraded my first PC build, going from s1156 and Core i5 760 to s2011 and Core i7 3930K, keeping some stuff from the first build.
So, my current build consists of:
Intel Core i7-3930K
Gigabyte GA-X79-UD5
Coolermaster V8
G.Skill Ares 32GB @ 1866MHz (10-11-10-30)
Gigabyte GTX460-768I
OCZ Vertex 2 SSD 60GB
Western Digital 640GB CaviarBlack SATA3
Coolermaster Silent Pro M600
Coolermaster CM 690 Pure Black Edition
I was wondering wether the H100i would fit in my case, considering Gigabyte's UD5 motherboard layout.
I really want to go with water cooling. Right now, with V8, core voltage from 0.876V to 1.260V max (depends on load) and cpu speed @ 3.8GHz idle temperature is 30-35 degrees celsius.
Temperature under intel burn test (full load) is 68-73 degrees celsius.
Here's a some pics of my build.
Intel Core i7-3930K | Gigabyte GA-X79-UD5 | Corsair Hydro Series H100i | G.Skill Ares 32GB | Gigabyte GTX460-768I | Creative SoundBlaster Z | OCZ Vertex 2 SSD 60GB | Western Digital CaviarBlack 640GB | Coolermaster Silent Pro M600 | Coolermaster 690 Pure Black Edition Case
Dell Vostro 3550 (OCZ Vertex SSD 60GB/8GB Ram)
icsd08063 is offline
post #674 of 1518 (permalink) Old 03-26-2013, 03:31 PM
Tyr03's Avatar
Rep: 0
I was wondering if the H100i will fit on very top (just under the plastic, above the "real" case) of a Nzxt Phantom or a Phantom 410
Tyr03 is offline
post #675 of 1518 (permalink) Old 03-26-2013, 06:21 PM
Mergatroid's Avatar
Rep: 179 (Unique: 144)
You should look for some of the external shrouds used in this build:
https://www.overclock.net/t/907643/corsair-obsidian-650d-mid-tower/750#post_14943357
Put your fans up top under the shrouds and your rad inside the case. It should look pretty sweet on your case.
Mergatroid is offline
post #676 of 1518 (permalink) Old 03-28-2013, 11:33 AM
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
Hi, I have a 9c diff between hottest and coolest core. Is this normal for the H100i on a 3930k?
The block won't fit on any tighter.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #677 of 1518 (permalink) Old 03-28-2013, 12:18 PM
TomcatV's Avatar
Rep: 170 (Unique: 126)
Only if it is for your idle temps. Seems like a lot, but I think you'll be OK. I usually only see a 6c-7c difference in idle, BUT what really counts for me is at my Load temps the core temps really tighten up and typically I'll only see a 2c difference between all cores under load. So check the spread under a full load such as P95.
Edit: If there is still a 7c-9c difference under load then I'd try a remount to eliminate uneven pressure due to over tightening/under tightening of one or more screws.
TomcatV is offline
post #678 of 1518 (permalink) Old 03-28-2013, 12:32 PM
Programmer
BradleyW's Avatar
Same story at full load. Then again, I have 2 extra cores.
If I re-seat, I will have to use thermal-right chill factor III. Is this as good as what Corsair use on the H100i?
Thanks mate.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #679 of 1518 (permalink) Old 03-29-2013, 05:59 AM
Quesoblanco's Avatar
Rep: 197 (Unique: 160)
Yes heres a picture. Use the brackets the Nzxt Phantom came with!
photo.JPG 2730k .JPG file
Quesoblanco is offline
post #680 of 1518 (permalink) Old 03-29-2013, 10:28 AM
chiggx's Avatar
Rep: 0
Hi!
I currently have the Fractal Design R3 case and a Hyper 212+ as cooler. I want to upgrade to watercooling and was looking into either the H100i or H110. I have two questions:
1- Can I mount the H110 radiator on top of my case on the outside? ie will the screw holes line-up?
2-If i do mount it outside, how do i disconnect the tubes from the radiator so I can pass them through the watercooling holes at the back of the case? What are the warranty implications of doing this?
Thanks
chiggx is offline
