H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 71 - Overclock.net - An Overclocking Community
post #701 of 1518 (permalink) Old 04-09-2013, 01:17 AM
badmojout's Avatar
Rep: 0
Originally Posted by johnadams View Post
Does anyone know if my H80 will fit in the front of a Fractal Define XL R2 (not sure if tubing will reach that far)? I'm in the market for a new case and want something that will accommodate a H80 in the front with plenty of room behind the mobo tray for cable extensions and management.
I would assume that the H80 should be just fine. The front is actually supposed to be able to accommodate a 120 mm thin rad if I recall correctly. I upgraded from an H80 to H110 so I still have my H80 lying around. When I have to replace my motherboard later this week, I can take a look to see if it does fit.
badmojout is offline
post #702 of 1518 (permalink) Old 04-10-2013, 02:05 PM
GhostHuntr's Avatar
Rep: 2 (Unique: 2)
Changed abit around today, so now I have 2 fans for intake in the top, and the rest as exhaust smile.gif
GhostHuntr is offline
post #703 of 1518 (permalink) Old 04-12-2013, 03:40 AM
nohackmove's Avatar
Rep: 2 (Unique: 1)
Hi all.
Is there any chance to use H100i on my case Cooler Master Elite 430?
the dealer, i purchased H100i, told me there was no chance to use on it.
Now i am looking for a new case for b plan and interested in using carbidge 300r but i guess it was same as my current case and somebody advised 400r to insert fans inside of case directly installing to radiator of h100i.
but with 400r case is getting bigger and when choose it i can also think other brand products.
i dont want any case bigger than 300r.
when need to decide a new case for new pc build i need usb 3.0 front panel ports and dont need dvdrom slot more than 2 and also dont need hdd slots more than 3-4.
so there i dont know what am i supposed to do.
nohackmove is offline
post #704 of 1518 (permalink) Old 04-13-2013, 10:49 AM
itzhoovEr's Avatar
Rep: 107 (Unique: 92)
Will the H100i fit in the Arc Midi 2?
itzhoovEr is offline
post #705 of 1518 (permalink) Old 04-13-2013, 11:49 AM
TomcatV's Avatar
Rep: 170 (Unique: 126)
Nice pick on your case ... size/performance/$$$ thumb.gif
Looks like it will fit just fine with NO Mods even with a push/pull setup, because Fractal was smart to give the user a choice of mounting holes up top. Instead of the typical down the middle mounting holes they also provide holes to mount your rad off-center, towards the left side of the case to clear the Mobo's heatsinks! In this example a pretty beefy Asus P9X79 Pro Motherboard.
Checkout Gar818's video [HERE] ... he's had way to much coffee (epileptic camera) but you'll be able to see confirmation. And below is his comment that he did not have to drill any additional holes for mounting ...
Gar818
Hey Robin, the R3 might have a problem fitting the H100 in a push pull configuration with 4 fans, because the fan holes are placed right in the center of the top of the case. The Arc Midi however has many holes to use from, if you look at the video you can see that the radiator is close to the left side panel therefor allowing room for mounting.
Originally Posted by nohackmove View Post
Hi all.
Well that dealer was right AND wrong ... The h100i will fit but it will take some slight modifications. Only the radiator will fit on the inside of the case and you will have to mod some holes and fit the fans on the outside of the case on top ... doesn't really look that bad and it performs well! See video [HERE]
If your looking for a new smallish, economical case maybe check out the Arc Midi R2 above ... or [HERE]
I can vouch for it's quality/performance/$$$.
And yes you will run into the same problems with the 300R/H100(I) ... and the same guy above thought the H80i would be a better fit ... But not to be, so he did a really nice mod to fit the H80i into the front of the case [HERE]
TomcatV is offline
post #706 of 1518 (permalink) Old 04-13-2013, 01:22 PM
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
It seems that when my CPU reaches the 200w usage, the H100i goes up by 1c per each watt above 200w.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #707 of 1518 (permalink) Old 04-13-2013, 03:11 PM
Linux Lobbyist
Rep: 8 (Unique: 7)
The H80i fits in the back of a BitFenix Prodigy. Tubing had to be squeezed a little. It can't be helped with the size of that casing smile.gif.
Tribalinius is offline
post #708 of 1518 (permalink) Old 04-13-2013, 03:21 PM
nohackmove's Avatar
Rep: 2 (Unique: 1)
Thank you for your reply.
I have also been watched months before same video. but i havent mind to read the posts under video that there was some mode was done to drill holes on top to mount fans.
Now i will try to drill some holes tomorrow.
Also i liked the case you mentioned Arc Midi R2 but it is not sold in our markets.
I was thingking about some other models.
Cooler Master Haf 912 advance and 922
also another option is that Aerocool Strike-X (series) One Advanced (hdd slots are very old fashioned may need to cut them)
Corsair Carbidge 400r also would be good may be the betterr but it is getting bigger and i dont want big case because i will not fill in the case.
if it is possible to setup h100i radiator and push fans inside case i would like to prefer Haf 912. Because i found a used one near to my place.
post #709 of 1518 (permalink) Old 04-13-2013, 08:28 PM
antitauon's Avatar
Rep: 1 (Unique: 1)
H110 + Fractal Design Define R4 (front): http://www.tomshardware.co.uk/forum/282949-29-nzxt-kraken-corsair-h110-noctua#10605271
THG forum post with a detailed description of how the guy managed to get the radiator installed in the front. Unfortunately without pictures.
antitauon is offline
post #710 of 1518 (permalink) Old 04-14-2013, 07:48 AM
icsd08063's Avatar
Rep: 1 (Unique: 1)
Well, i managed to fit H100i in my Coolermaster 690 first edition case, having an EATX motherboard also!
I had to driil 2 holes on top in order to mount the radiator. Motherboards heatsinks would not let it mount correctly otherwise.
Intel Core i7-3930K | Gigabyte GA-X79-UD5 | Corsair Hydro Series H100i | G.Skill Ares 32GB | Gigabyte GTX460-768I | Creative SoundBlaster Z | OCZ Vertex 2 SSD 60GB | Western Digital CaviarBlack 640GB | Coolermaster Silent Pro M600 | Coolermaster 690 Pure Black Edition Case
Dell Vostro 3550 (OCZ Vertex SSD 60GB/8GB Ram)
icsd08063 is offline
