H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 74 - Overclock.net - An Overclocking Community
post #731 of 1518 (permalink) Old 04-25-2013, 03:01 AM
rh pc's Avatar
Rep: 2 (Unique: 2)
Here is my new H100i setup:
1. Antec 1200
2. Asus M5A99FX Pro 2.0
3. AMD FC-8120 @ 4.3Ghz
4. Corsair H100i
5. Gigabyte 7850 2GB (soon Xfire)
rh pc is offline
post #732 of 1518 (permalink) Old 04-25-2013, 02:04 PM
IamPain's Avatar
Rep: 1 (Unique: 1)
so i guess the H80i doesn't fit the Lian Li Q08? What about the H60?
I wonder what other closed loop cooler will fit in the Lian Li Q08
IamPain is offline
post #733 of 1518 (permalink) Old 04-27-2013, 05:27 AM
Ketadine's Avatar
Rep: 0
Hey guys,
I've got a Cooltek Skiron black/red for a computer case and I was wondering if I could fit a H110 on top ?
If not, can I fit a H100 or a H100i ? From the specs of the case it supports 2x 120 mm or 2x 140 mm fans on top, but I would like to know if anyone else has tried it.
Ketadine is offline
post #734 of 1518 (permalink) Old 04-28-2013, 03:03 AM
joe2108's Avatar
Rep: 1 (Unique: 1)
Hello. Here My Hackintosh Gear
Processor : Intel i5 3570K (Box) intel LGA 1155
Mobo : MSI z77A-G45 Thunderbolt
VGA GTX 660 Ti 2Gb
Cooling : Corsair 110 -- Push Pull Config
Memory Corsair Veangene 32GB
HDD Seagate 1TB SATA3 x 2
SSD : Corsair Neutron 128GB
PSU : Seasonic MII620 modular
Casing Corsair Veangance C70
Corsair H110 Push & Pull Setup on Veangance Corsair C70
Power cable top Fan, round back into casing
Temp OC to 4,5GHz
Temp OC 4,7GHZ
Thanks
joe2108 is offline
post #735 of 1518 (permalink) Old 04-28-2013, 08:56 AM
DUpgrade's Avatar
Rep: 78 (Unique: 68)
VGA GTX 660 Ti 2Gb
Thanks
It's a nice setup but those AF140s in push are not static pressure fans. None the less though it looks great and your temps are awesome. thumb.gif
"People willing to trade their freedom for temporary security deserve neither and will lose both." ~ Ben Franklin
DUpgrade is offline
post #736 of 1518 (permalink) Old 04-28-2013, 08:58 PM
joe2108's Avatar
Rep: 1 (Unique: 1)
Yes I'm looking for better 14cm fan... ? any suggestion?
joe2108 is offline
post #737 of 1518 (permalink) Old 04-29-2013, 09:24 AM
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
Other than Noctua fans, not really. 140mm fans don't seem to be static pressure optimized in a sence. But I would use Noctua fans as they will help with better performance due to their focus flow and square shroud.
Hey, what is the best way to apply thermal paste for the H100i and a 3930K? Also, how can I ensure that I have the best possible mount? Any ways to increase mounting pressure? I remember the days of washer mods wink.gif
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #738 of 1518 (permalink) Old 04-29-2013, 11:34 AM
DUpgrade's Avatar
Apply it to the copper block and smooth it out evenly and real thin. I always lay my case on it's side so that I set the block on CPU and press and hold it in place. Each screw can be started but make sure you swap corners when you tighten them evenly, instead of 1, 2, 3, 4 tighten them 1, 4, 2, 3 then repeat until they're secured. You don't want to overtighten anything with these because you risk stripping the threads on the mount and then you'll be stuck with an air cooler until Corsair can handle your RMA.
DUpgrade is offline
post #739 of 1518 (permalink) Old 04-29-2013, 11:42 AM
Programmer
BradleyW's Avatar
Is there some place were I can buy the screws as a backup?
Thank you.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #740 of 1518 (permalink) Old 05-02-2013, 06:30 AM
Abandoned's Avatar
Rep: 12 (Unique: 12)
Yo Yo
I am getting my H110 today for my COMOS 2 case. Will confirm the fitment later today.
Abandoned is offline
