H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 80 - Overclock.net - An Overclocking Community
post #791 of 1518 (permalink) Old 05-15-2013, 07:48 AM
Rep: 3 (Unique: 3)
Alright, thanks guys! I'll give some of those a shot. O: if nothing else, I'll go and pick up another 120 or 240 rad
Desolator2B is offline
post #792 of 1518 (permalink) Old 05-15-2013, 04:08 PM
Been here for a while
Rep: 29 (Unique: 22)
Anyone knows if a NOX coolbay VX can handle a double radiator? like the H100, in the top of the case
[Intel] Core i7 6700k
[Gigabyte] Z170X-UD3
[Gigabyte] R9 280x
[Corsair] Vengeance LPX
[Samsung] 840 EVO
[Crucial] MX100
[Western Digital] Caviar Black 1TB
Optical Drive
[ASUS] DRW-24F1ST
[Corsair] HX750
[Antec] Khüler H2O 620
[Artic Cooling] MX-4
[Corsair] SP 120
[Corsair] AF 120
[Corsair] AF 140
[Bitefenix] Recon 5.25 Fan Controller
[Corsair] 200R
Operating System
[M$] Windows 10 Pro
[BenQ] XL2411Z 144Hz
Keyboard
[Corsair] K70 Cherry MX Red
Mouse
[Corsair] M65
Mouse
[Corsair] MM200
Audio
[Tritton] AX 720 Plus
Audio
[Creative] Inspire T3150 2.1
Other
[Saitek] Pro Flight X-55 Rhino H.O.T.A.S.
[AMD] FX 8320
[Gigabyte] 990FXA-UD5
[EVGA] GTX 960 SSC
[Corsair] Vegeance 3x4GB
[Samsung] 840 EVO
[Western Digital] Caviar Blue 1TB
Optical Drive
[ASUS] DRW-24F1ST
[Corsair] CX500M
[Cooler Master] Hyper 212 EVO
[NOX] Coolbay VX
Operating System
[M$] Windows 10 Home
[AMD] FX 8120
[Gigabyte] GA-970A-D3 (RIP)
[Gigabyte] GTX 650
[Corsair] Vegeance DDR3
danilon62 is offline
post #793 of 1518 (permalink) Old 05-15-2013, 06:21 PM
Mergatroid's Avatar
Rep: 179 (Unique: 144)
Originally Posted by jleslie246 View Post
It is made of aluminum which is a very soft metal. The threads simply strip out when over tightened. I would go to the hardware store and find small nuts to put on the back side. There is a tiny gap between the fins and the hole. You can put the nut between the hole and fins then tighten the screw into the nut. Should work fine. A tiny drop of superglue can be used to hold the nut in place. Do this before trying to mount it all together. Good luck.
That's a good idea for correcting that fault.
He could also purchase a similar sized tap from a hardware store with matching screws and carefully retap the holes to a slightly larger size.
Originally Posted by DUpgrade View Post
I wouldn't advise putting anything between the rad and fan beucase you'll run the risk of having a gap instead of the fan right up against the rad. I don't know if the holes on the rad go all the way through or not, can't remember if mine does. Glue will indeed void your warranty. That being said, I'm not sure if you can RMA or not considering you stripped them and it's not a defective product. Usually these have at least a 2 year warrenty on them, but you'll have to go through Corsair not the store you bought it from. You can always try the retailer but I highly doubt you'll get anywhere.
I think he's saying to put the nuts between the hole and the fins, not between the rad and the fans. I believe I have seen people say they have had their H100 exchanged because of stripped holes. Some people have had excess paint in the holes, causing the screws to be extraordinarily tight and stripping the holes. This could be the case here as well.
I do agree though that any modding, even just gluing a nut in, would likely void the warranty. It is a decent solution to the problem though.
Just contact Corsair. I bet they will replace it for you. It could have been the paint issue mentioned above.
Of course, one last option is to go to a hardware store and purchase some self tapping screws the same length, but slightly larger.
Don't try replacing the rad since the system is sealed. If you do you will likely have to start maintaining it like an open loop because of bacteria and algae.
It would actually be easier to drill the mounting holes to the next size up, purchase a tap from a hardware store the same size along with some screws, retap the holes and use the new screws.
Personally, I would contact Corsair before doing anything else.
Mergatroid is offline
post #794 of 1518 (permalink) Old 05-16-2013, 02:19 AM
Baskt_Case's Avatar
Rep: 62 (Unique: 55)
Cooler Master 690 II Advanced, H100i top mount, push only. Radiator is inside the case, so there is possibly room for a set of pull fans outside with no mods but I have not tried yet.
My only modification was cutting a small notch in the fan housing to accommodate my RAM. Note that the RAM heatsinks would have cleared no problem, it was the PCB of my RAM that interfered.
Prime95 @ 4.6GHz
Baskt_Case is offline
post #795 of 1518 (permalink) Old 05-16-2013, 02:30 PM
nobruds's Avatar
Rep: 0
Hello
I have a question about the H110
Sorry to ask, but I didn't found the Cooler Master Cosmos S in that list, but searching on google, I did found some posts saying that the H110 fits on the Cosmos S
Can someone please confirm that ? The H110 fits on Cosmos S ?
thanks
nobruds is offline
post #796 of 1518 (permalink) Old 05-17-2013, 05:28 AM
jleslie246's Avatar
Rep: 16 (Unique: 16)
Thanks for the support Megatroid. And yes. superglue could be messy. I was meaning to suggest a very tiny drop just to hold the nut in place during the mounting process. This can easily be removed with denatured alcohol on a qtip if an RMA is required. Threading new holes is easy in an engine block, but on thin aluminum it could be a challenge not to strip out the new holes as well. And d's nuts are cheaper than the tooling to make said holes biggrin.gif Keep your original hardware (the bolts are plenty long enough) and add nutz. Try it without glue 1st. No mess no fuss.
jleslie246 is offline
post #797 of 1518 (permalink) Old 05-18-2013, 05:10 PM
Imprezzion's Avatar
Rep: 102 (Unique: 89)
Guys, is a H100i going to fit in a NZXT Lexa S case? And in push-pull without having fans on the outside?
I've been looking at the case secondhand from a clanmate of mine, but we live too far apart for me to just test it..
Case does have 2x 120/140mm top mounted fan holes, but I have no idea whether it'll fit or how many fans it'll support.
Cars:
-Crashed: (not my fault ) '94 Nissan 100NX GA16DE (a.k.a. NX1600). Renault Laguna Phase I facelift '99 1.6 K4M. (Broke a strut and smacked a tree).
-Sold: '00 Nissan Primera P11-144 QG18DE, '97 Honda Prelude F20A4, 03 Ignis Sport.
-Current daily: '07 Ford Focus 1.6 Futura.
-Current funcars: '03 Peugeot 206CC 2.0 RFN fully riced and tuned (Turbo coming soon)
Full-On Rainbowbarf
(16 items)
P45 power!
(9 items)
i9 9900K @ 5.1Ghz 1.248v
MSI MEG Z390 ACE
MSI Armor GTX1080 Ti w/ Accelero IV @ 2063/6500Mhz
Corsair Vengeance RGB B-Die @ 4200 16-17-17-28-280-2T 1.54v
Samsung 850 EVO 500GB x2
Samsung 970 Evo 1TB
Seasonic Focus Plus Gold 750W
EK MLC-Phoenix 280 Kit
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro X64
Samsung S27B350H @ 1080p 75Hz OC
Iiyama GB2788HS @ 144Hz
Keyboard
Logitech G710+
Mouse
Trust GXT31
Mousepad
Corsair MM300 Large
Audio
Steelseries Siberia V2
Intel Core 2 Quad Q6600 G0 @ 3Ghz (333x9)
MSI P45 Neo2-FR
MSI GTX760 Gaming X
6GB completely random 1 and 2GB sticks. All 4 different ones.
A-Data 120GB SSD
AOpen 350w
Some huge aluminum Xeon heatsink
Cartboard box.
Operating System
W10 Pro x64
Intel Xeon E3-1270v1 @ 3.8Ghz
ASUS P8H61-i R2.0
Sapphire R9 280X Vapor-X @ 1230Mhz core.
16GB Kingston HyperX Savage 2400CL11 @ 1333CL6
Kingston 240GB SSD
Corsair CX600
Corsair H110i GTX
Custom open test bench made from a cut-up CM690 v1
Operating System
W10 Pro X64
Samsung 23" cheap thing
Keyboard
Cheapest one Aldi had
Mouse
Mousepad
The desk...
Imprezzion is offline
post #798 of 1518 (permalink) Old 05-19-2013, 04:34 AM
RNALTD's Avatar
Rep: 1 (Unique: 1)
Cooler Master Elite 430 case with Corsair H80i installed in push/pull set-up with airflow from outside inward. Plenty of room with the Gigabyte 990FXA-UD3 motherboard. As mentioned in other CM E430 posts you need to get the CPU power cable in place before H80i installation. As known, cable management is very limiting with this case but workable. The cooler runs great overclocking AMD FX-8350 to 4.5 MHz at stock voltage with temps in the low 30's. I have 2 intake fans (front, and side cover) and 2 exhaust fans on top.
RNALTD is offline
post #799 of 1518 (permalink) Old 05-20-2013, 05:26 AM
jleslie246's Avatar
Fractal R4 with H100i
post #800 of 1518 (permalink) Old 05-20-2013, 05:31 AM
jleslie246's Avatar
Fractal R4 with H100i (view 2)
