H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 82 - Overclock.net - An Overclocking Community
post #811 of 1518 (permalink) Old 05-25-2013, 02:11 PM
Linux Lobbyist
cravinmild's Avatar
Rep: 173 (Unique: 144)
I have put the H110 into my HAF 932 and posted a pic log of sorts. Its not hard if you don't mind a little bit of a unorthodox mount. I used 120mm on the top of the rad with the stock 140mm below the rad. This allowed for the stock 120mm mounting holes of the case to line up with the upper 120mm fans. Seems to work just fine. After a few weeks of use temps are 30-31c across all four cores currently. games max out around 48c with some benchmarking (stock cpu) around 54c. There is some mild fan noise but hardly [email protected] and [email protected]
Here is a linky to the pics
https://www.overclock.net/t/612436/official-corsair-hydro-series-club/22750#post_19922404
cravinmild is offline
post #812 of 1518 (permalink) Old 05-28-2013, 11:30 AM
Rep: 2 (Unique: 1)
Just put the H100i in my Antec 1200, push pull and at the back on the two 120mm fans.
The links on the first page need to be updated, the first link links to a post that says " Fits in the antec 1200 push/pull but u can only get two screws in but it is rock solid." but that is wrong. If you follow this guide: http://www.youtube.com/watch?v=bzzmLbAQKNY you will get ALL the screws in. The second link only links to the main page.
Also pics from my install: http://imgur.com/otXwLv0,Assp9RU,GmHLYKU,iNIHK8a,aMNAEeo
It is a very tight fit! Also the top PCI-E/PCI slot will not be able to be used. The second slot will have a small gap of about 5-8mm between the bottom of the radiator and the card that uses the 2nd slot, as you can see from the pics.
Newt182 is offline
post #813 of 1518 (permalink) Old 05-29-2013, 11:48 PM
Skeggy's Avatar
Rep: 0
sup guys
Hard to read all of 82 pages. So i hope for a one simple answer for a simpler question. Will H110 fit into CM HAF X without additional modding of the case?
TY.
Skeggy is offline
post #814 of 1518 (permalink) Old 05-30-2013, 10:01 AM
GhostHuntr's Avatar
Rep: 2 (Unique: 2)
#813 I unfortunately think you have to mod it a bit, since it's built with 200mm fans in mind, but I'm not sure since it's been a long time since I had my HAF X
GhostHuntr is offline
post #815 of 1518 (permalink) Old 06-01-2013, 01:16 AM
polycount's Avatar
Rep: 0
Hi, anyone know that case Thermaltake Level 10 GT will fit Corsair 2x H90? I would like to hook 2 x H90 on E5-2690 in thermaltake case, or what can You recommend a case - E-ATX that fit double Corsair H90.
polycount is offline
post #816 of 1518 (permalink) Old 06-02-2013, 10:10 PM
rayweil's Avatar
Rep: 1 (Unique: 1)
Originally Posted by Swag View Post
Here is my H100i installed in my C70 Military Green case!
What's your temps like?
Thanks.
rayweil is offline
post #817 of 1518 (permalink) Old 06-03-2013, 11:01 AM
ADHDadditiv's Avatar
Location: Outside your bedroom window.... You gunna finish that milk?
Rep: 178 (Unique: 135)
Probably, but why would you want to. Ugly, waist of money.
Try the Corsair 800D. Or the 650D, I think it will fit in there. Also look at the Coolermaster HAF 932 or the Rosewill Thor V2. If you really want something large, have a looksy at the Rosewill Blackhawk Ultra. Absolutely massive case that will be able to fit anything you want. You could fit 2 H100's in that thing and have room left over.
ADHDadditiv is offline
post #818 of 1518 (permalink) Old 06-04-2013, 04:14 PM
octhis's Avatar
Rep: 3 (Unique: 2)
I've used the search function but didn't find the answer so my question is, does anyone know if the H100/i fits the Antec 1100 ?
octhis is offline
post #819 of 1518 (permalink) Old 06-04-2013, 04:25 PM
http://lmgtfy.com/?q=will+the+corsair+h100+fit+in+the+antec+1100
post #820 of 1518 (permalink) Old 06-04-2013, 04:28 PM
octhis's Avatar
Rep: 3 (Unique: 2)
Why bother having a forum then ?
And if there is info on it why wasn't the list updated with that info ?
Would be useful to have everything in one place .
octhis is offline
