H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 84 - Overclock.net - An Overclocking Community
post #831 of 1518 (permalink) Old 06-08-2013, 06:03 AM
shadow99tr's Avatar
Rep: 1 (Unique: 1)
Intel Core i7 3770k @ 4.5 Ghz v1.2 || Asus p8z77-v pro Mainboard ||2 GB MSI Lightning gtx 680 || Corsair neutron gtx 120 gb Solid State Drive || Corsair Vengeance 16000mhz cl9 2x4gb 1.5v || Western Digital green 500 gb || Seasonic x 80+ 850w Gold PSU || Corsair H110 || Thermaltake level 10gt || || Acer gnhbmid 23.6'' 3D Led Monitör || Logitech Rumble gamepad ||Xbox wifi gamepad Logitech x530 5+1 Ses Sistemi || Razer Deathhadder 3200 v2 mouse
shadow99tr is offline
post #832 of 1518 (permalink) Old 06-08-2013, 05:56 PM
Mergatroid's Avatar
Rep: 179 (Unique: 144)
^ Why did you post that here? Talk about completely the wrong thread.
Mergatroid is offline
post #833 of 1518 (permalink) Old 06-09-2013, 08:44 AM
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
Why not? He is showing us his H110. I also posted shots like this to show my H100i many months ago and nobody had a problem.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #834 of 1518 (permalink) Old 06-09-2013, 10:26 AM
Tartaros's Avatar
Rep: 0
Anyone knows if the the h110 fits in the front on the XL R2?
Tartaros is offline
post #835 of 1518 (permalink) Old 06-09-2013, 10:39 AM
DUpgrade's Avatar
Rep: 78 (Unique: 68)
I don't see the issue here. Granted so many pictures requires you to scroll more they do have an H110 in there. I would have liked to see a pic with the side panel on it to block those lights though. I posted my rig back when I installed my H80i so it's all good.
"People willing to trade their freedom for temporary security deserve neither and will lose both." ~ Ben Franklin
DUpgrade is offline
post #836 of 1518 (permalink) Old 06-10-2013, 04:12 AM
tarunagg's Avatar
Rep: 1 (Unique: 1)
Hello Friends
I have Just Build My New PC
with Asrock Z77 Extreme 6 Motherboard I5 3570k CPU
Its Hot Season Here In India Room Temp Is 35-40 So Intel Cpu Cooler Is not Performing well Here are My Current results
I have CM690 Advance II With 8 120MM fans Installed(5 intake 3Exhaust)
With Out Overclocking
Minmum Cpu Temp 48'C
Maximm CPU Temp 78"C(And sometimes 85'C)
So i was thinking to buy Corsair H80i does it perform better how much difference i can see in CPU temp
tarunagg is offline
post #837 of 1518 (permalink) Old 06-10-2013, 03:59 PM
TomcatV's Avatar
Rep: 170 (Unique: 126)
Originally Posted by tarunagg View Post
Hello Friends
But for a quick answer, it is a night and day difference in improving "Load" temps between the stock HSF and the H80i,. On average you'll see about a 20c improvement depending on your setup and overclock, if any biggrin.gif
Although THIS review is w/Sandy Bridge you will see similar results with Ivy bridge, just search the Corsair Hydro thread linked above if you need more confirmation thumb.gif
TomcatV is offline
post #838 of 1518 (permalink) Old 06-11-2013, 04:23 AM
nohackmove's Avatar
Rep: 2 (Unique: 1)
I live in Turkey and my options on my mind are Corsair Cases that are 500R , C70 or Obsidian 550D.
I would rather prefer 550D as it seemed as tidy and cool also there is no vent at front it has only air vents for places where case fans can be mounted and al those vents have covers to disable them.
But there is a question on my mind that will it be capable for my system?
I had cooler Corsair H100i and Mother board MSI P67A-GD65. M.B. has cooler pipe above the cpu slot.
so it need a space between top of the case and M.B.
I will mount rad on top and between rad and M.B. i will mount fans to push air from case to outside as exhaust.
If it fit with my system i choose 550D
Otherwise will look for other two.
Also i found a 550D second hand and half price of current pricing. it is 300 Turkish Liras if you buy new one and i found at price of 150 T.L.
but realy did not like that case seem ugly to me. and there is vents in front means lots of dust. although there will be filter for dust outside of front panel will keep dust on.
Originally Posted by ADHDadditiv View Post
Well whats your price range? Also the only cases I know of that have PSU's built in are small form factor cases and really cheap mid towers.
nohackmove is offline
post #839 of 1518 (permalink) Old 06-11-2013, 08:04 AM
Programmer
BradleyW's Avatar
Does oxidation on the block cause a loss of performance on the H100i?
Thank you.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #840 of 1518 (permalink) Old 06-11-2013, 12:50 PM
DUpgrade's Avatar
Thank you.
If you see the copper block starting to turn green you can try cleaning it. I've seen some people use a sander and lap the surface back to a shiny looking copper. No idea if performance changes however you want to make sure the surface is clean for the TIM to make proper contact. Did you buy one used that was living in a box for awhile or something of the sort? How old is the unit?
DUpgrade is offline
