H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 85 - Overclock.net - An Overclocking Community
post #841 of 1518 (permalink) Old 06-11-2013, 10:37 PM
ledzepp3's Avatar
Rep: 110 (Unique: 85)
Any idea of an H110/ NZXT Kraken X60 fitting in the roof of a Fractal R4?
1995 Chevy Impala SS: Dark Cherry Metallic, Nitto NT555's (255/40/W17), Flowmaster 40 Series Mufflers, stock 350-LT1 V8. The Daily.
2006 Pontiac GTO: Brazen Orange Metallic, 6-speed, Stock Internal 6.0L LS2 V8, SLP Long Tube Headers, SLP Loudmouth II Cat-Back, Custom Catless Mids by Red's Muffler, Trickflow Intake, BMR Aluminum Skidplate, Hinson Motorsports Single-Piece Aluminum Driveshaft w/ Forged Chromoly Yolks, Hinson Motorsports Short-Throw Shifter, Melling High-Volume LS2 Oil Pump, Powerbond 15% Underdrive Pulley, SCSS Oil Pressure and Boost/Vacuum Gauges, BMR Sub-Frame Connectors, BMR Strut Tower Brace, Hotchkis Front/Rear Sway Bars, Roadsafe Bushingless Front Swaybar Endlinks, Tow Brace Delete, Hinson Polyurethane Transmission and Motor Mounts, Koni Adjustable Shocks and Struts, Whiteline Upper Rear Shock Bushings, Whiteline Differential Support Insert, Whiteline Upper Strut...
ledzepp3 is offline
post #842 of 1518 (permalink) Old 06-12-2013, 04:10 AM
Belial's Avatar
Rep: 166 (Unique: 142)
I plan to get an x60 (same thing as h110), can you put it in a bitfenx shinobi or nzxt source 210 or similar case with 2x120 on the front if you remove the hdd bays and such? Basically, can it be mounted on 2x120mm fan slots with 15mm spacing (they both use 15mm, i think corsair had a typo saying 20mm at one point)...
Thanks.
Belial is offline
post #843 of 1518 (permalink) Old 06-12-2013, 06:46 AM
jongbot's Avatar
Rep: 1 (Unique: 1)
I have a Define R4, rear mounted h90 in push/pull
see pics
jongbot is offline
post #844 of 1518 (permalink) Old 06-14-2013, 03:20 AM
Belial's Avatar
Belial is offline
post #845 of 1518 (permalink) Old 06-14-2013, 10:10 AM
kelpt's Avatar
Rep: 0
Anyone know if the IN WIN GT1 will fit a h100i rad on top?
i7-3770k 4.3
Sabertooth z77
16gb 1866 corsair
kelpt is offline
post #846 of 1518 (permalink) Old 06-14-2013, 10:27 AM
shadow99tr's Avatar
Rep: 1 (Unique: 1)
Hello,
I don't speak english sorry..
http://www.youtube.com/watch?v=6qrPVPMKslc
weather temperature 29-30c
My computer use i7 3770k 1.2v 4500mhz ..
corsair h110 fan rpm 600 silent profil ---idle 34-36c ----prime 95 %100 63c
1000rpm idle 29-30c ----prime 95 %100 58c-59c
No problem
Intel Core i7 3770k @ 4.5 Ghz v1.2 || Asus p8z77-v pro Mainboard ||2 GB MSI Lightning gtx 680 || Corsair neutron gtx 120 gb Solid State Drive || Corsair Vengeance 1600mhz cl9 2x4gb 1.5v || Western Digital green 500 gb || Seasonic x 80+ 850w Gold PSU || Corsair H110 || Thermaltake level 10gt || || Acer gnhbmid 23.6'' 3D Led Monitör || Logitech Rumble gamepad ||Xbox wifi gamepad Logitech x530 5+1 Ses Sistemi || Razer Deathhadder 3200 v2 mouse
http://cdn.overclock.net/f/f7/900x900px-LL-f79b3b6a_20130608_143020.jpeg
more photos page 84..
shadow99tr is offline
post #847 of 1518 (permalink) Old 06-14-2013, 07:07 PM
jleslie246's Avatar
Rep: 16 (Unique: 16)
I have the H100i and it fits with wiggle room in the top of my R4 so I would say yes but you may have to off set it toward the side of the case.
jleslie246 is offline
post #848 of 1518 (permalink) Old 06-17-2013, 01:59 AM
nohackmove's Avatar
Rep: 2 (Unique: 1)
Hi everybody.
At last i got a new case and mounted all my system and H100i on it.
I got Corsair Vengeance C70 White.
Disabled HDD slots and used a dvdrom slot for my only disk Corsair SSD
Now there is lots of room for air.
nohackmove is offline
post #849 of 1518 (permalink) Old 06-17-2013, 04:38 AM
navit's Avatar
Rep: 110 (Unique: 100)
And some cable management !
"The kind that thinks his printer is a removable usb boot device"
navit is offline
post #850 of 1518 (permalink) Old 06-17-2013, 09:26 AM
DUpgrade's Avatar
Rep: 78 (Unique: 68)
"People willing to trade their freedom for temporary security deserve neither and will lose both." ~ Ben Franklin
DUpgrade is offline
