H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 89 - Overclock.net - An Overclocking Community
post #881 of 1518 (permalink) Old 06-29-2013, 08:03 PM
xNeonCandy's Avatar
Rep: 0
looking at the front of the case, the fans are at the very edge of the left side. there is 2 inches of space between the edge of the fans and the right side of the case.
i'd be worried about it hitting my ram heat sinks possibly, but not my mobo.
xNeonCandy is offline
post #882 of 1518 (permalink) Old 06-29-2013, 08:18 PM
DUpgrade's Avatar
Rep: 78 (Unique: 68)
I'm not sure what exactly you're talking about. Your top case fan is almost touching your mobos upper VRM heatsink not taking the RAM into consideration. If you have an extra case fan laying around put that up against the fans you have, that's how much vertical space the rad is going to add. There's just no way it's going to fit up above your mobo.
"People willing to trade their freedom for temporary security deserve neither and will lose both." ~ Ben Franklin
DUpgrade is offline
post #883 of 1518 (permalink) Old 06-29-2013, 08:41 PM
xNeonCandy's Avatar
Rep: 0
an extra fan hits the ram heatsink on the fan towards the front. the fan in the back doesn't hit anything.
the fan would hang down by the VRM heatsink (directly in front of it actually) but it wouldn't it it. what i'm saying is that the fans would be IN FRONT of the mobo, not hitting it because the mobo is against the case on one side and the fans are against the case on the opposite side.
*uploading pics*
post #884 of 1518 (permalink) Old 06-29-2013, 08:48 PM
xNeonCandy's Avatar
Rep: 0
post #885 of 1518 (permalink) Old 06-29-2013, 09:26 PM
DUpgrade's Avatar
It's not going to clear, sorry. I don't know how else to break this to you with your current configuration. confusedsmiley.png
DUpgrade is offline
post #886 of 1518 (permalink) Old 06-29-2013, 10:01 PM
Intel Fanboi
Phenomanator53's Avatar
Rep: 69 (Unique: 61)
Hey guys, will a H90 fit on the top of my case? Pics below:
Vaporiser II
(12 items)
Ryzen 5 1600X
Asus X470-I
RTX 2080 Founders
Micron 16GB 2400MHz ECC-UDIMM
960 EVO 250GB
ST2000LX001
Delta GPS-850HB-C Platinum 850W
NH-U12S
H200 Black/Black
Operating System
Windows 10
LG 27UK600W
Phenomanator53 is offline
post #887 of 1518 (permalink) Old 06-30-2013, 09:38 AM
Rep: 1 (Unique: 1)
The H80i fits the Corsair 200r with both push/pull config.
Nytrixx is offline
post #888 of 1518 (permalink) Old 06-30-2013, 08:43 PM
jleslie246's Avatar
Rep: 16 (Unique: 16)
In response to NeonCandy and the Rosewill Future:
Maybe with some moding you could put it between the mb and hdd rack? Some good cable management would help clarify.
jleslie246 is offline
post #889 of 1518 (permalink) Old 07-01-2013, 06:49 AM
itomic's Avatar
Rep: 12 (Unique: 12)
Can CoolerMaster CM690 II Advanced fit Corsair H110 ??
Croat to the end
itomic is offline
post #890 of 1518 (permalink) Old 07-01-2013, 07:38 AM
Rep: 1 (Unique: 1)
Looking at there site it support 240mm rad in bottom of the case check out this link I don't know for sure if a H110 would fit there or not.
http://www.coolermaster-usa.com/product.php?product_id=2970&product_name=CM%20690%20II%20Advanced
Nytrixx is offline
