H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 93 - Overclock.net - An Overclocking Community
post #921 of 1518 (permalink) Old 07-07-2013, 02:29 PM
DUpgrade's Avatar
Rep: 78 (Unique: 68)
Originally Posted by shaukj0n3s View Post
The h100i fits in the corsair 350d in either push or pull in the top mounts or in push pull front mounted so the h100 should fit as well although I don't have one so I can't say for sure
H100 isn't different than H100i in terms of rad. The block is different in there's only 3 fan speeds and the H100i has rubber tubes and USB control over the block.
"People willing to trade their freedom for temporary security deserve neither and will lose both." ~ Ben Franklin
DUpgrade is offline
post #922 of 1518 (permalink) Old 07-07-2013, 02:43 PM
TomcatV's Avatar
Rep: 170 (Unique: 126)
ooops nevermind ... true ...
As far as mounting clearances and radiator mounting holes the H100/H100i are identical wink.gif
I only said for sure about the h100i because I didn't see the 350d in any compatibility on the first page but I said I'm guessing the h100 would fit because they look to be very similar with thier dual 120mm dads and both in the h100 line
I'm sure Mattyd863 will update soon, especially if you post some pictures so he can "Link" you to the 1st page confirmation wink.gif
TomcatV is offline
post #923 of 1518 (permalink) Old 07-07-2013, 02:45 PM
shaukj0n3s's Avatar
Rep: 1 (Unique: 1)
shaukj0n3s is offline
post #924 of 1518 (permalink) Old 07-08-2013, 10:51 AM
cRckR's Avatar
Rep: 0
I want to but a ANtec HF-85 but it looks like a pain....I am looking for opinions here CM Storm Stryker + h100i CM sTORM TROOPER + H100 i
I am trying to future proof my case as I expect it to last a long time /...I have had my thermaltake armor Jr for 8 years..I Want to be able to fit XL-ATX boards.... correct me if I am worng but if XL -ATX ea-ATX borad will fit correct? anywho some guidance would be nice...I want good temps..and a full tower
cRckR is offline
post #925 of 1518 (permalink) Old 07-11-2013, 06:18 PM
Linux Lobbyist
Exxlir's Avatar
Rep: 1 (Unique: 1)
Originally Posted by TomcatV View Post
Yes Kires you are exactly right. I can confirm this as I made a mockup template for a friend who was considering the scenario above. The rad and 1 set of fans will fit with minimal (tight) clearance in either a Push config or Pull but not both with out mounting the 2nd set of fans externally outside the case. The overall thickness of the H110 is only 2mm more than the H100/(i) but it will be tight depending on your mobo's heatsinks or possibly ram retention clips. see H100 pics HERE
And you will have to redrill at least 5 holes/6 holes if you want the rad centered, 7/ (8) if you want to go all out. I've found 6 total mounting holes are sufficient. Some even say they're comfortable with only 4 holes as long as they are at each corner!
Technical Specifications from Corsair ...
HAF 922 (Top) has 20mm fan hole spacing for 120mm fans only
Hydro Series H110 ...
• Radiator dimensions: 140mm x 312mm x 29mm
• Fan dimensions: 140mm x 25mm
H110 = 20mm fan hole spacing
TOTAL Thickness 54 millimeters = 2.12598425 inches
Hydro Series H100:
Radiator dimensions: 122mm x 275mm x 27mm
Fan dimensions: 120mm x 120mm x 25mm
H100 = 15mm fan hole spacing
TOTAL Thickness 52 millimeters = 2.04724409 inches
Thanks for the replys guys really appreciate it ! i think i will buy one and chance my luck to fit it on the top fan mount i dont plan on doing any case modding if it doesnt fit ill just have to send it back but im guessing it should fit " just " lol but yeah thanks !
Exxlir is offline
post #926 of 1518 (permalink) Old 07-12-2013, 06:52 PM
Myyu's Avatar
Rep: 4 (Unique: 3)
So, the h100i will fit in a Tempest 410 Elite, but its a bit of pain if you have a high mobo. (more specifically if your Ram slots are high up on your Mobo)
The only way I could put it in was to put the rad ontop, and the fans on the inside of the case. Even with it like that, I could only secure it using the 8 long screws. I could NOT mount it in any way using the 8 smaller screws and 8 fan screws. The way the holes on the top of the case are, the fans would use the same holes to mount the rad.
So, unless I get a different case/mobo, I have it in pull. (I think its pull. Fans are sucking in air through the rad)
Rather than upload the pics again, just view them in my other thread.
https://www.overclock.net/t/1409245/so-i-got-my-h100i-yesterday
LoLZ (Click to show)
Originally Posted by TheOwlHootHoot
GIBBERISH??? My MSI Radeon 7950 are made with the bones of dead terrorist and F-16 parts.
Myyu is offline
post #927 of 1518 (permalink) Old 07-13-2013, 12:21 PM
TomcatV's Avatar
Excellent, very informative presentation. The only key factors you left out performance wise, not related to the H100i mounting into your 410 Elite, were your ambient temps and how long you ran P95. See [HERE] or my sig. Screenshots are great ... wish more people would use them ... +R for you thumb.gif
TomcatV is offline
post #928 of 1518 (permalink) Old 07-14-2013, 04:53 AM - Thread Starter
Rep: 87 (Unique: 80)
So, I finally got around to updating page 1!!!
Took me several weeks to get to it but it's done.
If I missed any posts or info then just let me know and I'll get to them.
Massive thanks to the regulars for answering questions and handing out advice, you know who you are!
I'll get round to leaving rep for posts that went on to the OP soon.
Thanks for your posts and your patience!!
I'd just like to say in answer to a couple of queries, I can only post what information is provided, nothing is 100% and the post is totally reliant on the user providing the correct info.
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #929 of 1518 (permalink) Old 07-14-2013, 10:59 AM
Swag's Avatar
Rep: 290 (Unique: 201)
Nice! Looks great. I know how hard it is to update the OP or spreadsheets, it gets kind of annoying here and there but it's worth it to see the progress. tongue.gif
Swag is offline
post #930 of 1518 (permalink) Old 07-14-2013, 02:30 PM
DUpgrade's Avatar
Nice update to help everyone out. There's been a few cases that pop up I've tried to advise on how to go about measuring (can lead a horse to water but can't make it drink) for their specific case.
BTW I have a 900D now and can confirm that it will support fit every cooler on this list without issue. kungfu.gif
DUpgrade is offline
