H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Overclock.net - An Overclocking Community
post #1 of 1518 (permalink) Old 10-17-2011, 06:12 AM - Thread Starter
Rep: 87 (Unique: 80)
THIS THREAD IS FOR H SERIES COOLER CASE COMPATIBILITY - HAVE ANOTHER QUESTION? THEN GO TO THE OCN OFFICIAL CORSAIR HYDRO SERIES CLUB
***NOTE - REFERENCE H80i & H100i COOLERS*** Please Read
I will now include the new "i" Series coolers. They are almost the same with regards to size which let's face it, is all the matters to this thread.
The only noticeable difference is that due to the new thicker tubes, the reservoir on the end of the radiator has been increased very slightly. I haven't seen a single setup where this would make a difference.
I am waiting for clarification that the tubes are the same length.
From now on, when a link is specifically to an "i" series cooler, I will name it as such
I know there are threads for the H80 & H100 coolers, and threads for individual cases. However, this doesn't stop the numerous threads with people asking if this cooler will fit in their case, normally as a new thread!
Please keep in mind this is only based on the info provided by other forum users and I accept no liability for any mistakes! The thread is only for a summary of compatibility, not for discussion into HXXX versus air cooling or tech help etc.
I will keep this page updated in the first post and summarise all the info, all I require is the info from you via PM or in the thread to include:
Case manufacturer, model, version
H80 or H100
Position
Summary of any mods required or close calls on fitting (i.e. might not suit everyones HW)
If you want the info to point to a specific post with pics etc then please provide the link to that post only, not the entire thread.
If you wish to include any other closed loop water cooling systems (antec etc) then let me know.
Thanks for all info so far - Please try and include a link or a picture with your info if you can so people viewing this thread have a reference!
If you notice any broken links please let me know so I can update them!
H80 & H80i
COOLER MASTER
CM690 Std
Fits Rear in P/P configuration - LINK
Does not fit top, makes contact with MB heatsink and RAM with some HW. May be okay with other MBs.Adv versions of the case have a bit more room, but check first.
CM690 II Adv
Fits in rear without modding - LINK
Storm Enforcer (SGC-1000-KWN1)
Fits Rear without issue. LINK & LINK
Storm Scout
Fits in Push/Pull - LINK - H80i
Storm Sniper
Fits rear and top fan mounts, awaiting pics.
HAF 912
Will fit rear fan mount. - H80i
Custom mod for front - LINK
HAF 922
Fits in rear - LINK
HAF 932
Fits rear fan mount - LINK
Cosmos S
Should fit, with some caveats/restrictions - See LINK
Elite 430
Fits on rear fan mount, may be HW dependant - LINK
Rear Mounted - H80i
Elite 431
Fits in the rear mount, might be HW dependant - See LINK
Silencio
Fits on rear mount without issue - LINK
SILVERSTONE
RAVEN 3
Fits, please view LINK
TJ10
Fits on rear fan mount - LINK
TJ08-E
Fits, limited room - LINK & LINK
FT03
Fortress FT01
Fits on rear mount in push/pull - LINK
CORSAIR
200R
Fits rear in push pull, no issues - H80i
500R
Fits rear, no issues - LINK
600t
Fits top but require modding for P/P configuration as per H100 LINK
650D
Fits - LINK
300R
Fits rear, no issues - H80
NZXT
Phantom (please see details, different versions are unconfirmed!)
Fit in the front - LINK (PIC SHOWS H50, but H80 will also fit)
Fits in the rear - H80i
Source 210
Fits on rear mount - H80i
Thermaltake
Armor A60
Fits rear mount - Link
Armor (VA8000BWS)
Armor (VH6001)
Fits but not as Push/Pull inside the case, see link, also may be possible to have one fan externalLINK
V9 Black
Element G
Fits, no issues - LINK
ANTEC
Antec NSK6000 / 6500 / 6580 / 6580b
Fits rear. - LINK
200
Fits rear mount in P/P but may be HW Dependant - LINK
300
Fits rear in push pull - LINK
900
Fist rear with minor mod to side panel clip - LINK & H80i
1100
Fits on rear mount - LINK
1200
Fits rear fan mounts, using bottom my affect other components - LINK
P183 V3
Fits top or rear - LINK for REAR
LanBoy Air
Fits in P/P - LINK
FRACTAL DESIGN
Define XL
H70 Fits in rear as P/P, H80 should also fit. LINK
Define Mini
Will fit but may be HW dependant - LINK
Arc Midid
R2 & R3
Fits in rear - LINK
Additional R3 - LINK
R4
Fits in front, link is for H60 but H80 should work the same - LINK
Core 1000
Should fit, see comments in LINK - Also confirmed now may fit with losing some of the vertical drive mountings - LINK
Fits in the front with some modding - H80i
Core 3000
LIAN Li
PC-7FN
Fits but need to remove rubber grommets from fan mount - Awaiting link
PC-7FNWX
Fits on rear mounts if you remove the rubber gromets see - H80i
CaseLabs
SM8
Will fit on rear mount or on top mount - LINK
ASUS
TA-D2
Tight squeeze, but fits - LINK
AZZA
Solano 1000
Fits on rear mount, both fans internally may impact side panel fan - See LINK
BITFENIX
Prodigy
Fits on rear mount, See H80i
Rosewill
Thor V2
Fits on rear mount without issues, See H80i
Zalman
Z12
Fits on rear mount without issues, See H80i & H80i
H90 (140mm Version of H80)
Fractal
Define R4
Fits on rear mount without issues - H90
H100 & H100i
COOLER MASTER
CM690 Std
Fits in base if HDD cage is partially removed, be careful that water pipes are long enough to reach CPU over graphics card.
Fits in the top without modding - H100i
Fits i the top with very light modding dependant on hardware. See H100i
CM690 II Advanced
Fits in base - Requires removing some of HDD cage - LINK & LINK(Shroud)
Fits in top as P/P using top fan mounts without issue, but is HW dependant. - LINK
Fits on top of case in P/P with some heavy modding - LINK
Fits in bottom in P/P + Some shrouds with some modding - LINK
Top Mounted Push Only - H100i
Bottom Mounted - H100i
Centurion 590
Fit in top in Push or Pull - Heavy modding required for P/P - Ext link
Elite 430
Fits top with modding for push or pull only. - see H100i
HAF 912
Fits top with some modding for P/P - see link - read full thread comments.
HAF X
Fits top without modding
Some modding may be required for P/P, may fit some cases without modding, HW dependant. - LINK
HAF 922
Fits top in Push or Pull but require minor modding - LINK
HAF 932
Fits Push or Pull - LINK
P/P Confirmed - LINK
P/P confirmed, top 230mm may need to be removed if complete P/P configuration will not fit inside with hardware, check first.
Storm Sniper
P/P Confirmed with one on top, waiting on confirmation of 2 fans fiting - LINK
Storm Scout
Fits in front with heavy modding - LINK
Fits in top as push or pull, tight fit asnd component dependant - LINK
Storm Scout 2
Fits in the front with some modding - LINK & Alternative method LINK
Top Mounted without modding - H100i
Storm Stryker
Fits in the top - H100i
Cosmos II
Fits in top in push or pull - LINK H100i
SILVERSTONE
Raven 02
Will fit P/P if case fans removed but not required, P/P possible using case fans - LINK
Raven RV-03
Fits in 5.25 drive bays with modding - LINK
TJ07
Fits in top with some very light modding and a few caveats, see -LINK
TJ10
Fits in P/P without issue - LINK
CORSAIR - Should fit all, but check first, waiting for links to individual case installs
200r
Fits in the top with slight mod - H100i
300r
Fits in Push or Pull but is hardware dependant, specifically RAM - LINK
Good link showing HW constraints - LINK
400r
Fits in Push or Pull only - Modding required for P/P setup - LINK
500r
Another Push Pull setup - LINK
New info, fits P/P without modding but is hardware dependant, more specifically size of heatsinks - AWAITING LINK
600t SE
Fits Push or Pull confirmed - LINK & LINK
Push Pull - LINK & LINK & LINK
550D
Fits in the top in push or pull, P/P may be hardware dependant - LINK
650D
Fits in Push/Pull, be cautious about other components - LINK & NEW LINK
800D
Fits in top - Ext Link (Full Intsall) & Ext Link (Full Install) & LINK
C70 Military
Fits in top - H100i
C70
Fits in top - H100i
NZXT
Phantom
Fits Push or Pull - Link & LINK
Fits in Push Pull with some modingd - LINK
TEMPEST 410
Fits in the top - EXT LINK
TEMPEST 410 Elite
Fits in the top, HW dependant - H100i & H100i
Phantom 410
Fits seperating the fan and rad either side of plate - LINK & LINK & Alt LINK
Switch 810
Fits in the top, room for push pull - LINK
Gamma
Fits top with modding - LINK
Fits in Push/Pull without mods - LINK
ANTEC
300
Will fit in front with some quite heavy modding - LINK
Can be fitted in 3.5" bays with some modding - LINK - Thanks pale
1200
Will fit on rear in P/P - LINK & LINK & EXT LINK - H100i
Top Mounted - H100i
Push Pull setup, rear mounted - H100i
900
Will fit in the front without modding at the loss of some bays - LINK
Dark Fleet (DF) 85
Yes, with mods - LINK
Push Pull without modes confirmed - LINK
Lanbot Air
Fits in front, full install guide - LINK
Thermaltake
Level 10 GT
Fits Push Pull - EXT YOUTUBE LINK & LINK & NEW LINK
Fits Push or Pull, also shows space available for P/P config which may be HW dependant - LINK
RX-1
Fits in top in Push/Pull - LINK
Fits in the top IN P/P without removing 200mm fans but may be HW dependant due to space limitations around larger RAM or heatsinks. See LINK
V4
Fits in Push or Pull - LINK
Armor Plus
Fits in Push Pull custom fit - see link
Chaser Mk1
Confirmed in Push or Pull - LINK
Fractal Design
Arc Midi
Fits in top in Push or Pull
P/P now confirmed without modding - LINK - and alternative - LINK & LINK & LINK
Mini
Can be mounted in front - LINK
Arc Mini
Fits in top in push pull (lower profile rear 120mm fan required i.e. 25mm+ will not fit)- LINK
Push or Pull in the H100i
R4
Fits in front in push or pull removing the drive cages, simple mod - LINK
Also fits the front in push/pull - H100i
Front and top fitting -
Fits in the top without modding, HW dependant see - LINK
Fits without modding by offsetting the fan mounts, may be HW dependant - See LINK
Top Push or Pull Mounted - H100i
LIAN Li
PC 50
Can be mounted in the front in P/P with some heavy modding - LINK - UPDATED LINK
PC-V2120
Fits in Push/Pull - may be component dependant see - LINK
PC-K62
Fits with some modding, see - LINK
Bitfenix
Prodigy
Fits in top in Push or Pull with some caveats - See H100i
Rosewill
Thor
Fits in top in Push/Pull with some modiing. Modding should not be required for Push or Pull, but not yet confirmed - LINK
Azza
Solano
Fits in top in Push or Pull, Push pull possible utilising the existing built in 230mm fan without modding. See H100i
Zalman
Z11 Plus
Will fit in the top in push or pull with minor mods. See - H100i
H110 (280x140mm Version of H100)
Cooler Master
Cosmos 2
Fits in top in Push/Pull using 200mm case fans, requires some light modding. See - H110
HAF 932
Fits in top with caveats - H110
Comprehensive post of top mounted H110
Thermaltake
Chaser Mk-1
Fits in top - H110
Level 10gt
Fits in top in push or pull - H110
Corsair
carbide 300r
Fits on top with some minor mod. See - H110
Vengeance C70
Fits in the top in push pull - See H110
Top Mounted Push/Pull Setup - H110
Fractal Design
Arc Midi
Fits in the front - H110
Arc Midi R2
Fits in the front, very minor mod - H110
There's no such thing as a stupid question..... Only stupid answers!
Mattyd893 is offline
post #2 of 1518 (permalink) Old 10-17-2011, 06:17 AM
olli3's Avatar
Rep: 94 (Unique: 85)
This is such a good idea for a thread. It would be useful to expand this to all coolers because some air coolers are too big for many cases, but I guess that would be a lot of work lol.
PS3: o_oli
Steam: oll13
Origin/BF3: o_oli1
post-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gif
olli3 is offline
post #3 of 1518 (permalink) Old 10-17-2011, 06:18 AM
vitality's Avatar
Rep: 106 (Unique: 91)
Fits in the 600t on the top. Just no push pull without modding.
vitality is offline
post #4 of 1518 (permalink) Old 10-17-2011, 06:19 AM - Thread Starter
H100 included?
post #5 of 1518 (permalink) Old 10-17-2011, 06:24 AM - Thread Starter
Hope I'm not biting off more than I can chew already!
post #6 of 1518 (permalink) Old 10-17-2011, 07:48 AM
Doming0's Avatar
Rep: 4 (Unique: 4)
Fits in the Corsair 400r and 500r (basically the same case). BUT, without modding or removing the top mesh, the H100 will only fit Push or Pull and not PUSH/PULL.
Doming0 is offline
post #7 of 1518 (permalink) Old 10-17-2011, 02:59 PM
vitality's Avatar
Originally Posted by Mattyd893;15340433
H100 included?
Yeah. I meant the h100.
vitality is offline
post #8 of 1518 (permalink) Old 10-17-2011, 08:02 PM
Mergatroid's Avatar
Rep: 179 (Unique: 144)
Actually, the H100 fitting into a 240mm rad location is no guarantee that the double thick 120mm push/pull H80 will fit. I would just remove that 99% line if I were you.
And the H100 also fits in all the Corsair cases. (under H100, List Corsair - ALL).
Nukeyork
(19 items)
i7 10700K
ASUS Prime Z490-A
Gigabyte RTX 2070 Super OC
Corsair RGB Pro 3200MHz
ADATA
Optical Drive
ASUS BW-12B1ST Blu-ray RW
Corsair AX750
Thermaltake Water 3.0 Ultimate
Corsair 760T
Operating System
Windows 10 64 pro
HKC c340 34" Ultrawide 3440 x 1440
Keyboard
Redragon RGB 10-Keyless
Mouse
Logitech Lightspeed G903
Audio
On Board
Other
Thermaltake X 5G Superspeed USB 3.0 Hard Drive Dock
Other
Logitech Driving Force GT Steering Wheel
Other
Thrustmaster T.Flight Hotas X Joystick
Other
Razer Orbweaver Chroma RGB Mechanical Gaming Controller
Other
Ergotron LX Desk Mount LCD Arm
Mergatroid is offline
post #9 of 1518 (permalink) Old 10-17-2011, 11:54 PM - Thread Starter
Removed...Forgot about the extra bulk!
And yes, I'm sure it will fit into all Corsair cases, but I would rather fill the info with links to OC members posts about fitting and any mods needed/possible for any given case. Does my new quote satisfy you ;-)
post #10 of 1518 (permalink) Old 10-17-2011, 11:58 PM
Xyphyr's Avatar
Rep: 25 (Unique: 24)
I was able to shroud my h50 in the front of my nzxt vulcan. I would imagine the h80 would work fine as well.
95.567% of people make up the stats in their sig. If you are part of the 4.433% who uses real stats, put
this in your sig.
Xyphyr is offline
