If i do this, how much of temp improvement will i see? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 10-23-2011, 03:51 PM - Thread Starter
thrgk's Avatar
Rep: 44 (Unique: 39)
Right now, i have a 360 rad on the back of my haf 932, but its right to the back of it, so only about 120 is above the comp, if i add the bitspower rad support I so that it is like off the back around 2 inches, and add an extra fan(since right now it only has 2 fans) how much of a temp improvement will i see? Im using 2 coolmaster 1500rpm fans for it, and its the swiftech one on the back, the rs360 has 3 yate looms. BTW, both are pulling air into the rad.
thrgk is offline
post #2 of 9 (permalink) Old 10-23-2011, 04:16 PM
andrewmchugh's Avatar
Rep: 626 (Unique: 493)
If you have the fans in push you will get better temps, I tried pull on my set up and it was pathetic.
Graduate of Computer Science (Game Engineering) - Newcastle University
andrewmchugh is offline
post #3 of 9 (permalink) Old 10-23-2011, 04:24 PM - Thread Starter
thrgk's Avatar
So put it so fans blow into the rad? Plz explain
Sent from my ADR6300 using Tapatalk
thrgk is offline
post #4 of 9 (permalink) Old 10-23-2011, 04:38 PM - Thread Starter
thrgk's Avatar
if you can draw a pic, or just explain that'd be great. thank you so much!
thrgk is offline
post #5 of 9 (permalink) Old 10-24-2011, 04:17 AM
arfaad's Avatar
Rep: 21 (Unique: 21)
yes, he means you should set fans so they blow air through the rad. AKA - push.
arfaad is offline
post #6 of 9 (permalink) Old 10-24-2011, 04:45 AM
Tranquil's Avatar
Rep: 3 (Unique: 3)
(-->) = the direction the fans are blowing.
A push/pull setup would look like this.
(-->)Radiator(-->)
The first fan pushes air through the radiator, while the fan on the other side pulls that air away creating much better airflow.
Tranquil is offline
post #7 of 9 (permalink) Old 10-24-2011, 05:42 AM - Thread Starter
thrgk's Avatar
why would i want air pulling from where my computer is? if i do <--rad<-- then it would be pulling air from way behind it, which is most likely cooler right?
thrgk is offline
post #8 of 9 (permalink) Old 10-24-2011, 05:49 AM
Tranquil's Avatar
Rep: 3 (Unique: 3)
That's up to you. I was just explaining what push/pull is.
I've got my 360 on the top of my haf X Pushing and pulling out. My temps are low 20's idle. I've tried the other way around... But pulling air in kind of screwed up the airflow in my case and temps were 5-6c higher.
Tranquil is offline
post #9 of 9 (permalink) Old 10-24-2011, 05:55 AM
Schmuckley's Avatar
Rep: 709 (Unique: 566)
probably pretty good..i got a drastic improvement by putting my videocard in a higher slot..a couple of inches versus very close..makes a world of difference !
Schmuckley is offline
