[Build Log] First rig update "Going Black": X79 RIV BE, 4930k, Tri-SLI 780's, Black Acrylic Tubing - Overclock.net - An Overclocking Community
post #1 of 242 (permalink) Old 10-25-2011, 10:26 PM - Thread Starter
erayser's Avatar
Rep: 73 (Unique: 58)
Born on New Years Day (01-JAN-2014)
Current Pictures: 18-JAN-2014
Current Pictures: 01-JAN-2014
Current Pictures: 27-DEC-2013
Warning: Spoiler! (Click to show)
Current Pictures: 28-DEC-2013
I'm editing my first post with the updates I'm planning to do starting in December 2013:
Pic of things I've purchased since for my update... a lot of the boxes are empty since I used some of the items on my 2011 build.
Specs:
Case: Corsair Obsidian 800D
CPU: Core i7 2600K
CPU: Hexacore i7 4930K
Mobo: Asus Maximus IV Extreme-Z
Mobo: X79 Asus Rampage IV Black Edition
Graphics Cards: 2 x 3072MB EVGA GTX580 FTW Hydro Copper 2
Graphics Cards: 3 x EVGA GTX 780 SC in Tri-SLI
Ram: Corsair Dominator-GT 8GB DDR3 1866MHz 1.5v
Ram: Corsair Dominator Platinum 16GB DDR3 2133MHz 1.5v
Storage:
- Crucial M4 128GB SATA 6Gb/s SSD
- Samsung 840 EVO 500GB SATA III SSD
- WD Cavier black 2TB
Optical: LG CD/BD/DVD drive
PSU: Corsair AX1200
PSU: Corsair AX1200i
Case Fans: 4 x 120mm Bitfenix white spectre and 3 or 2x stock corsair fans
Case Fans: 4 x 120mm Gentle Typhoon AP-15
Watercooling:
Radiators:
- 1x XSPC RX360 push/pull top with a Koolance 350 shroud
- 1x Swiftech MRC220 push/pull bottom
- 1x EK 120 rad
Radiator Fans: 12x Gentle Typhoon 120mm AP-15
Reservoir: Koolance RP-452X2 (Rev 1.3)
Reservoir: EK-MultiOption RES X3 250 - Tube
Pumps: 2 x Koolance PMP-450
EK D5 Dual CSQ Pump Top - Acetal - Black
Tubing: Feser 1/2 x 3/4 white UV
Tubing: Primochill Black Acrylic
CPU Block: Raystorm
CPU Block: Supremacy Clean CSO c/p
GPU Blocks: FTW Hydro Copper 2 (pre-installed)
GPU Blocks: 3x EK-FC GTX Titan/780 c/p + Back Plates
Mobo block: EK-FB Asus Max IV Extreme
Ram block: EK Ram Dominator
Fittings:
- 14X Bitspower Black 1/2" x 3/4" Rotory Compression fittings(various)
- 4x Bitspower 1/2" barbs
- 2x Koolance Black Adjustable VID connector (GPU's in parallel)
- 20X Primochill Revolver Black Acrylic Compression Fittings
- Bitspower elbows (various)
- 4x Bitspower Adjustable Aqua Link Pipe (GPU's in parallel)
Fan Controller: Scythe Kaze Master Pro (bought 2 but may only use 1)
My original build log from 2011 starts here:
https://www.overclock.net/t/1152008/build-log-update-in-progress-my-first-attempt-computer-build-and-going-watercooled#post_15456515
erayser is offline
post #2 of 242 (permalink) Old 10-25-2011, 10:27 PM - Thread Starter
erayser's Avatar
Current Pictures: 19-NOV-2011
15-NOV-2011
11-NOV-2011
08-NOV-2011
06-NOV-2011
05-SEP-2011
This is my first and only computer build, and I feel really clueless to what I'm doing. I've been lurking in OCN and other forums for months trying to learn as much as I can before I purchased. I'm not really a gamer, but I wanted to build a computer just to keep up with the technology. I am a Programmer/Analysts (Oracle dev/dba), so I am mainly a user... who complains to IT why my computer isn't working... LOL...
As I searched about building computers, I stumbled on watercooling systems on YouTube... and I was blown away... and hooked. I used to play COD when it first came out, so maybe I'll become a gamer again. BF3 seems like a good start.smile.gif
I wasn't planning on doing a build log thread, but since I've been lurking and learning in the watercooling forum, and other forum sections... and everyone seems cool and helpful... I decided to do this thread so I can maybe get some help and encouragement along the way.
Here are some parts pics:
I have individual parts pics... but I don't feel like uploading them.
Not the amazing specs that I've seen on other threads in this forum... but this is what I going to work with on my first computer build.
Specs:
CPU: Core i7 2600K
Storage:
PSU: Corsair AX1200
Watercooling:
Radiators:
Radiator Fans: 10x Gentle Typhoon 120mm AP-15
CPU Block: Raystorm
Fittings:
The above is what I'm going with no matter if it turns out good or bad. I'll learn from my mistakes. There are parts I know other people have different ideas of... but I based my decisions on reviews I've read, compatiblility, and good first hand experiences I've read in forums. Hopefully I can gain a lot of experience from this project, so I'll be a helpful contributer in this forum someday.
erayser is offline
post #3 of 242 (permalink) Old 10-25-2011, 10:27 PM - Thread Starter
erayser's Avatar
Work I've done so far...
First thing was to remove the feet so I can get a cleaner cut with my cheap sears jigsaw:
After removing the bottom cage, I test fitted the push/pull 240 rad on the bottom:
Next I installed the intake fans to pull in cool air into the bottom rad section and HDD cage section:
Installed u-channel for clean look (McMasters is very cheap for u-channel by the foot smile.gif)
Pics of the intake/exhaust for bottom rad section and HDD cage. I'm going to reverse the corsair floor fan to blow down prevent any hot air to rise, and pull some hot air down and out the bottom (top rad will be intake to pull in cool air through the rad). Hopefully this will limit any additional heat from rising.
Here are some pics of the sleeving I've done so far... there is still a lot more sleeving I have to do.frown.gif
For the fan controller, I want to control the 3x push fans on channel 1, and 3 pull fans on Channel 6 for the RX360 rad. So I tested it by making the following adapter:
Since worked out, I'll be making a nicer fan adapter with black molex connectors and black sleeving. The adapter will make it easier for me to replace fans if they ever go out on me.
UPDATE: 30-OCT-2011
Anyhow... I didn't have time to do much because all these holloween activities I have to do with my 2 boys. My wife and I are working on Fred and Wilma Flintstone costumes from scratch... lol...
Here are the little updates I've done this week...
Installed the my koolance shroud. Still waiting on some socket head screws to install the fans in the shroud. It's scheduled to be delivered on Tuesday.
Speaking of fans, I am going to use both fan controllers after doing the math on watts per channel (amps x volts = watts). For those who want couple fans together in parallel... get lamptron fan controllers (30 watts/channel). For now... I will use the Kaze Master Pro's, but I will be replacing them with Lamptrons... and re-wiring the fans in the future. This is the configuration I'm going with (for now) on the front panel...
I also did more sleeving on my PCI-E cables for my GPU's, and 2 pumps...
Why the coiled blue wire? Since I am using 2 fan controllers (12 channels), I'm going to use 2 channels for the pumps. Mainly using it to alarm if 1 of the pumps fail.
Finally, I positioned the pumps so I can easlily access the variable controls. I got a little tired of drilling holes in my case.tongue.gif
After I get my screws in on Tuesday, I'll install all the fans on the case, and making adapters/sleeved to connect to the fan controllers. When I complete that... it's on to working on the mobo. smile.gif
small UPDATE: 01-NOV-2011
This is my poor mans isolation fan mounts (one sided foam tape). Put it on there to seal the fan mount... and noise cancelling.
Stay tuned... and thanks for all the encouragement that I recieved in posts, PM's, and rep comments.thumb.gif
erayser is offline
post #4 of 242 (permalink) Old 10-25-2011, 10:31 PM
Retired Staff
metallicamaster3's Avatar
Rep: 89 (Unique: 76)
Absolutely MAD! Not a gamer yet you've got nearly double the cash dumped into your rig compared to mine, and I'm a hardcore gamer... simply mad! What do you plan on using such a beast of a machine for?
Subscribed to this thread. I LOVE these kind of build threads. The case customizations and the endless possibilities of watercooling combinations really tickle my pickle.
I'm from Brooklyn, I'm the OG owner of the New Yorker Club
metallicamaster3 is offline
post #5 of 242 (permalink) Old 10-25-2011, 10:35 PM
van13330gg's Avatar
Rep: 17 (Unique: 15)
Wow and this is a first timer?
http://heatware.com/eval.php?id=78416
“The persistence of a human may never win against the persistence of time, but the fruits of the labors are wondrous to behold, even in our brevity” --Daniel Costin
"...what's Fonzie like?"
van13330gg is offline
post #6 of 242 (permalink) Old 10-25-2011, 10:35 PM
Angrybutcher is offline
post #7 of 242 (permalink) Old 10-25-2011, 10:39 PM - Thread Starter
erayser's Avatar
As an end user at work, I've lost touch of the technology out there. I mainly wanted to build a computer for knowlege, and to keep up with latest hardware. However, in researching... I was blown away with what people are doing with computer builds. I was a semi-gamer in the past, and I do play the PS3 with my sons... so I will be taking advantage of this hardware playing BF3.smile.gif
My wife thinks I'm insane... lol...
Originally Posted by Angrybutcher;15456585
UPDATE: 01-NOV-2011
Finally installed my rads after thinking if I should filter them or not. Decided just to filter the bottom rad only... because I think that is where most dust is in my office.tongue.gif
One thing I have to mention on the swiftech rads, the holes don't line up well with the standard 120mm fan holes. I read the same issue on reviews... and it was true in my case. It was a pain bought after screwing it once... it was hard the second time around.
Here is the bottom of the case (note: finally got the feet back on the case again.smile.gif)
Sealed the bottom fan with some one sided foam tape:
I know I installed the shrouded fans before....
.... but was a pain to get the nuts on the screws with this installed mad.gif....
It wasn't impossible, but it took a while to get the screw threading in the nut started with little room with the rad in the way. If i had to do it again... I would drill, punch, and tap. I'm going to look into some type of threaded inserts... so I'll be able to maintenance later on.
I'll be making extention cables for the fans to connect to the fan controller, and sleeving them... tomorrow or the following days. After that... installing the water blocks on the mobo. smile.gif
UPDATE: 08-NOV-2011
Tonight I worked on some cable management. Cable management sucks... but it's the only way to keep the cable police quiet... lol... tongue.gif
The way I have the cables exiting worked best for me to route the cables into the PSU compartment. I lost a lot room with the 240 rad in the way.
UPDATE: 11-NOV-2011
Still working on wire connections and cable management...
Worked on the tubing, but it isn't finalized. I'm still waiting on Koolance QD's, and not satisfied on the tightening on my compression fittings. Didn't realize how hard it was to work with compression fittings. My fingers are torn up.frown.gif
After I get my koolance QD's, I'll connect tubing to the upper rad, and reservior. Hope I feel a little more confident when I start water testing my loop. Getting close, but not quite there yet.
FINAL STAGE: 15-NOV-2011
Everything is all installed... wires tied down, and water tubing is completed. Tested fan controller, fans and lighting again, and all is working.thumb.gif
FINAL STAGE: 19-NOV-2011
I haven't updated my thread in a while because... I've been enjoying my computer.smile.gif Currently playing BF3...
Although it took me a long time to build... since I wasn't sure what I was doing... I am really happy how it came out. I learned a lot from this experience... and look forward to learning more on another future build. Thank you all for the kind words and support... and thank you for taking this awesome journey with me.
For the record... the hard to bleed Koolance RP-452x2 issue isn't the case with rev 1.3. After I turned my case upside down, and it didn't take long to bleed.
erayser is offline
post #8 of 242 (permalink) Old 10-25-2011, 10:43 PM
Linux Lobbyist
clubber_lang's Avatar
Location: Portland OR ( Ghetto city! )......My game plan?......"Pain!"
Rep: 10 (Unique: 10)
Man...Erayser beat me to the punch! I'm a first time builder myself , but haven't even started gathering all my stuff yet. I've got something kind of big planned myself.
Erayser....good luck man! That's coming from one fellow noob to another!
clubber_lang is offline
post #9 of 242 (permalink) Old 10-25-2011, 10:45 PM
Rep: 0
Zekrom is offline
post #10 of 242 (permalink) Old 10-25-2011, 10:47 PM
Spykerv's Avatar
Rep: 158 (Unique: 118)
You've got to be kidding me... You're a first timer!
SIMPLY AMAZING. Mega mad props to you sir, mega mad props. CONGRATS and I hope to see you around and your fantastic builds around. DANGGG.
I think you just about one uped every first timer here. Insane!
Spykerv is offline
