Fractal Arc Midi + RX240 = Good? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 18 (permalink) Old 01-19-2012, 02:46 PM
mm67's Avatar
Rep: 259 (Unique: 218)
Res/pump combo that comes with Rasa kit won't fit anywhere else but in those 5.25" bays. You need to buy a DDC or D5 pump if you want to use those bays for something else.
Here are couple of examples, old version with MCP35X and res at bottom :
550
Current version with dual MCP350's :
529
mm67 is offline
post #12 of 18 (permalink) Old 01-19-2012, 03:01 PM - Thread Starter
Explicit528's Avatar
Rep: 2 (Unique: 2)
I'd rather just switch cases rather than pumps...I just want to go with the full kit rather than putting pieces in, taking others out, etc. Any reccommendations? This caught my eye.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129178
Explicit528 is offline
post #13 of 18 (permalink) Old 01-19-2012, 03:04 PM
mm67's Avatar
CM 690 would be a better option in that case.
mm67 is offline
post #14 of 18 (permalink) Old 01-19-2012, 03:13 PM - Thread Starter
Rep: 2 (Unique: 2)
I think I like this case the most now actually.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
EDIT: Didn't see your post about the CM 690 II. I dunno, I feel like I need a bit of convincing to get that case, it kind of turns me off for some odd reason lol. Not the looks though, I think it looks fine.
post #15 of 18 (permalink) Old 01-19-2012, 03:19 PM
mm67's Avatar
RS240 might fit there but it looks a bit too low for RX240 unless that fits to the bottom like on CM 690
mm67 is offline
post #16 of 18 (permalink) Old 01-19-2012, 03:28 PM - Thread Starter
Rep: 2 (Unique: 2)
How can you tell that its too low?
EDIT: About the Arc Midi... Arent the drive bays at the top right? Which are untouched? Or is that not the drive bays
448
post #17 of 18 (permalink) Old 01-19-2012, 05:48 PM - Thread Starter
Rep: 2 (Unique: 2)
I was thinking about the 400/500R...do you guys think the extra cash for the 500R will be necessary? Is a side fan still necessary even if I'm water cooling?
post #18 of 18 (permalink) Old 01-19-2012, 10:08 PM
mm67's Avatar
448
Drive bays are at top but with a Rasa kit you have to put reservoir/pump combo there. Upper right corner of this picture, takes two bays as you can see :
492
mm67 is offline
