[Work Log] Switch 810 w/ 420mm rad & fully modular - Page 2 - Overclock.net - An Overclocking Community
post #11 of 31 (permalink) Old 03-02-2012, 10:25 AM
PCModderMike's Avatar
Rep: 165 (Unique: 134)
Originally Posted by Iggg View Post
Christmas Morning in March
450
10x Bitfenix Spectre Pro LED 140mm Fans along with lamptron invertless UV light bars.
The monster 420mm rad.
Sadly the gasket that I ordered for it do not line up with the radiator mounting holes, let's hope the switch does not disappoint and line up correctly.
450
Lastly,
Sleeving and custom cable & tools for making 6 in 1 3 pin fan connectors.
450
Wow oh wow, I love getting deliveries with new goodies biggrin.gif I think if you check mironccr345's log, you'll see he is having some issues with the holes lining up, so he plans to drill holes I think.
Sony Alpha A7II | Sony 28-70mm f/3.5-5.6 | Sony FE 55mm f/1.8 Zeiss Sonnar T
~The Switch~
Post The Last Thing You Ate!
PCModderMike is offline
post #12 of 31 (permalink) Old 03-02-2012, 10:39 AM - Thread Starter
Iggg's Avatar
Rep: 4 (Unique: 4)
Darn,
That's not what I wanted to hear, I noticed on this work log that he only used a few holes and not all of them, I'm hoping that's the case with mine,
B. Plan I'll just cut slits instead between the 140MM holes and make the rad mount into sliders.
Good thing is that the top is already off so I can dremel it without disturbing the rest of the case. thumb.gif
Iggg is offline
post #13 of 31 (permalink) Old 03-02-2012, 10:52 AM
Darn,
Well I hope Plan C doesn't have to be touched, because that's a nice 420 you got there thumb.gif I'm sure you'll figure out some kind of solution for it smile.gif
~The Switch~
post #14 of 31 (permalink) Old 03-02-2012, 11:02 AM
mironccr345's Avatar
Rep: 118 (Unique: 105)
Darn,
Yeah, I wasn't expecting the rad holes not lining up. redface.gif The Phobya G-Changer rad. holes are spaced 3/4" and the spacing on the S810 is 1" So you'll be drilling your own holes if you want to mount the phobya rad.
mironccr345 is offline
post #15 of 31 (permalink) Old 03-02-2012, 11:11 AM - Thread Starter
Iggg's Avatar
Rep: 4 (Unique: 4)
I'm awaiting/curious to see how you managed to mount yours.
Mine is a Black Ice Stealth 420
Iggg is offline
post #16 of 31 (permalink) Old 03-02-2012, 10:40 PM - Thread Starter
Iggg's Avatar
Rep: 4 (Unique: 4)
Goind Under!
Koolance Quick Disconnect Fittings finally arrived.
450
Now due to a few post of others, I thought that I'd have to drill new holes for the Black Ice Stealth 420mm radiator but once a while, luck actually was in my favor.
The holes line up without any drilling involved!
450
700
Next the blocks and fittings went in fairly quickly.
I could not use all the QDCs like I wanted around on the radiator to the clearance issues for the rear fan. These fittings are huge, measuring almost 3 inches when combined.
450
The 420mm rad fits beautifully up at the top in push/pull configuration, plenty of room to breath up at the front at the space created by cutting down the top most set of rails.
450
Top fans going in.
450
By now, everything is plugged back in and I'm eager to fire this sucker up.
450
These spectre Pros x6 are not bad at all at full speed (for now). They will be plugged to one channel on the lamptron FC touch later after I mod the PCB I have for them.
Last project for the night, changing the LEDs of the D5 res from red to blue.
This actually involves changing an entire pcb board with the built in LED in them, wasn't complicated but you'd need a molex pin remover if you want to change it.
Before:
223
After:
450
Tomorrow will be a full day of soldering to place the 6x case fans on one controller channel and the 6x push/pull fans on the radiator on a separate channel.
Iggg is offline
post #17 of 31 (permalink) Old 03-03-2012, 12:18 PM
gr3nd3l's Avatar
Rep: 21 (Unique: 17)
Very nice job with the top rad!
Can't wait to see what else you have in store!
Imagination is more important than knowledge.
I <3 Mechanical Keyboard
[BUILD] Project BLU [coming soon] - Apple G5 Mod
[BUILD] Switch3d - NZXT 810
[PARTS] mini Collider - EVGA Hadron Air
[PARTS] Prod1gy - BitFenix Prodigy
gr3nd3l is offline
post #18 of 31 (permalink) Old 03-06-2012, 05:16 AM - Thread Starter
Iggg's Avatar
Rep: 4 (Unique: 4)
Crazy Weekend of Cabling.
That was a crazy weekend of custom cable making and sleeving.
Didn't seem like a lot of work was done but I am now awaiting some more ATX pin removal tools, went through 2 sets so far.
PSU died out on me so I'm awaiting a replacement from corsair to finish sleeving the main PSU cable that's not modular.
This is my first time sleeving anything.
Made me a custom 6 to 1 3 pin fan header for the radiator fan and another 4 to 1 for the case fans.
All the Fans are spectre pro 140mm.
700
The first cable I've sleeved EVER!
This cable took me about 4 hours in figuring out which way the pin removal tool goes in to proper sleeving length etc.
450
Finally,
I got my computer to a semi finished state while I'm awaiting a replacement PSU. Then I can sleeve at my leisure.
450
450
P.S Removing ferrite rings on the modular HX1000 PCI-E cable suck.
Iggg is offline
post #19 of 31 (permalink) Old 03-06-2012, 10:50 AM
TheJesus's Avatar
Rep: 186 (Unique: 146)
I hear you on the Corsair ferrite rings. I just got one yesterday, how the hell do you cut them off or did you just remove the connectors and slide them off?
If you respond to one of my posts in a very busy thread, I probably won't see it, so feel free to message me.
TheJesus is offline
post #20 of 31 (permalink) Old 03-06-2012, 10:57 AM - Thread Starter
Iggg's Avatar
Rep: 4 (Unique: 4)
I did it exactly like this guy.
I cut a slit into the heat shrink then blasted it with the heat gun. The heat shrink will pull away at the slit then just pry it apart with a screw driver or something.
As for the ring, I just slid out the wires one at a time as i sleeved it.
Iggg is offline
