Pump advice on 100.00 budget. - Page 2 - Overclock.net - An Overclocking Community
post #11 of 20 (permalink) Old 04-12-2012, 06:08 PM
AMC
AMC's Avatar
Rep: 269 (Unique: 217)
Originally Posted by Juggalo23451 View Post
its not louder. its barely audible. i have used the 655,355, and 35x too
the 355 out performs the 655 with a top. the mcp35x would be best. it is noticeable when running
it is only slightly louder. I used both and the 655 is quieter. The MCP35x is a very nice pump. It performs well but it does have a slightly higher failure rate since it runs hotter. There mods you can do to make it run cooler. I just have found that the 655 is more reliable. But I do recommend getting a pump top, it helps a lot.
Quotes. (Click to show)Warning: Spoiler! (Click to show)
Response to working with Bulldozer before release.
If you can record your computer's load power in wattage, please click below to help out thumb.gif
AMC is offline
post #12 of 20 (permalink) Old 04-12-2012, 07:39 PM - Thread Starter
Little_Timmy's Avatar
Rep: 4 (Unique: 4)
Thanks that gives some perspective
Little_Timmy is offline
post #13 of 20 (permalink) Old 04-12-2012, 08:07 PM
Location: Honky Tonk Nashville, TN - Fold for Nerds For Jesus, Team 31630
Rep: 112 (Unique: 104)
The Laing DDC-3.x series of the MCP355 AND MCP35X run under load around 100C for heat.
The Laing DDC-1T or called the MCP350 runs a mere 57C under load for heat. If a performance top is added to this pump, the flow increases and the head pressure is better than a MCP655. AND ... the DDC-1T (MCP350) can run from the MB CPU fan header as well.
Jump over to Martin's Lab's for a review and comparison for WCing pumps.
Support Your Local Sheriff - At high noon
My Heatware ID 63611 is bmaverick - Paypal Verified
The maverick of happy pump owners
bmaverick is offline
post #14 of 20 (permalink) Old 12-21-2012, 12:39 PM
dumbazz's Avatar
Rep: 4 (Unique: 3)
dumbazz is offline
post #15 of 20 (permalink) Old 12-21-2012, 12:48 PM
Rep: 365 (Unique: 250)
http://www.dazmode.com/store/product/ek-dcp_4_0_high_performance_water_pump/
60 bucks canadian some people say its noisy some don't
Master__Shake is offline
post #16 of 20 (permalink) Old 12-21-2012, 12:51 PM
dumbazz's Avatar
Rep: 4 (Unique: 3)
dumbazz is offline
post #17 of 20 (permalink) Old 12-21-2012, 01:03 PM
Rep: 8 (Unique: 8)
I have a similar problem choosing a pump, I figured I could join the conversation and maybe give the OP more options.
I've considered:
MCP655 with Alphacool HF D5 top
DDC 3.2 with PWM stock top
DDC 3.25 no PWM stock top
or any of the other DDC pump with stock tops, but I guess the other are a better choice?
One thing i'd like to know is, is the DDC 3.2 the same as Swiftech MCP 35x? Or is the 35x the 3.25 with PWM?
naikee is offline
post #18 of 20 (permalink) Old 12-21-2012, 02:24 PM
vaporizer's Avatar
Rep: 52 (Unique: 32)
I hope the OP has bought one already since its been 8 months since his post, but for the resent posters... I use a mcp655 as I would rather have silence and low heat as that was my goal with water. I read that it is more reliable as well and I like not having to think about my pump going out on me. I leave the comp on even when not using it and if the pump went out and I wasn't around or my MB didn't shut the comp down it would equal sad times.
vaporizer is offline
post #19 of 20 (permalink) Old 12-21-2012, 03:01 PM
dumbazz's Avatar
Rep: 4 (Unique: 3)
Thanks for the site Snake I found my motherboards water blocks there
dumbazz is offline
post #20 of 20 (permalink) Old 12-24-2012, 09:40 PM - Thread Starter
Rep: 4 (Unique: 4)
Thanks everyone. I got the mpc655 (D5) and also purchased a rheostat controller to go with it and my fans but havent needed it. I burned up one chip messing with baseclock and seeing how high i could go and after that just decided to go with the 4.3 clock on the 3820.... Cooling system even with two 580 classys in the loop is still way overkill to need the pump turned up much i think i keep it at 2 just because i cant hear it and my fans on my rad are hooked to my cpu fan header
