Pump advice on 100.00 budget. - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 04-12-2012, 04:44 PM - Thread Starter
Little_Timmy's Avatar
Rep: 4 (Unique: 4)
I am considering MCP-35X vs. MCP655 but would consider any pump if I overlooked some good options. I like the idea of having a pump controlled by my motherboard but in the reviews I have looked at the 35x seems quit a bit louder? I am new to water cooling so could use suggestions. would be using a phobya xtreeme 1080 if I decide to go inside the case and a Watercool MO-RA3 9x140mm if I go outside the case. Large res if I make my own or a phobya 2 bay res if I am not so creative. Only cooling the one CPU at first but plan to cool 2 video cards later. Not sure how much of that matters but listed it for restriction purposes.
Little_Timmy is offline
post #2 of 20 (permalink) Old 04-12-2012, 05:08 PM
STG3 VET
Juggalo23451's Avatar
Rep: 1174 (Unique: 756)
the mcp355 with a pump top with out perform the mcp655.
I have the mcp355 with the xspc dual bay res for the mcp355
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><p><a href="https://www.overclock.net/water-cooling/913181-water-cooling-guide-noobs.html#post11984918">Water cooling guide for noobs,parts,setup install case suggestions,etc</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/962044-upgrade-time-update-2-3-18-a.html">Case labs TH10/ build log (2 gtx 590s) water cooling oh my</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/528648-heatkiller-club.html">Founder of the Heatkiller Club</a></p><span></span><p><span>W</span><a href="https://www.overclock.net/water-cooling/601449-water-cooling-cases.html">ater cooling case suggestions</a></p></div></div>
Juggalo23451 is offline
post #3 of 20 (permalink) Old 04-12-2012, 05:12 PM
AMC
AMC's Avatar
Rep: 269 (Unique: 217)
MCP655
Quotes. (Click to show)Warning: Spoiler! (Click to show)
Response to working with Bulldozer before release.
If you can record your computer's load power in wattage, please click below to help out thumb.gif
AMC is offline
post #4 of 20 (permalink) Old 04-12-2012, 05:13 PM
superericla's Avatar
Rep: 161 (Unique: 134)
I second the MCP655
superericla is offline
post #5 of 20 (permalink) Old 04-12-2012, 05:14 PM
072665995's Avatar
Rep: 40 (Unique: 35)
i wud personally choose the MCP 655 since it has a very high relaibility rate.
072665995 is offline
post #6 of 20 (permalink) Old 04-12-2012, 05:15 PM
AMC
AMC's Avatar
This.
The MCP355 performs a bit better but is louder, hotter and fails more.
AMC is offline
post #7 of 20 (permalink) Old 04-12-2012, 05:31 PM - Thread Starter
Rep: 4 (Unique: 4)
Originally Posted by AMC View Post
This.
Hmm.... sounds like the 655 wins. I assume there is no PWM pump that is as good in this pricerange then. Thanks
post #8 of 20 (permalink) Old 04-12-2012, 05:33 PM
STG3 VET
This.
its not louder. its barely audible. i have used the 655,355, and 35x too
the 355 out performs the 655 with a top. the mcp35x would be best. it is noticeable when running
post #9 of 20 (permalink) Old 04-12-2012, 05:34 PM - Thread Starter
Rep: 4 (Unique: 4)
Argg... just when I thought I had it figured out.
post #10 of 20 (permalink) Old 04-12-2012, 05:42 PM
STG3 VET
abs 595 with mcp 355,all you here is the fan noise
