I still use mine. They still work - the ones I have are the very first generation 3600 rpm ones, but I have had to drop them down to ~2700 rpm for the noise to remain sane. I'm not fond of the 5.25'' bay res, but the issues I had with it were also (supposedly) because it was basically the very first revision. I have used for the past three or so years only the standalone plexi tops and the double pump res is sitting somewhere in the closet.
The pump with the standalone plexi top, unfortunately, is not very compact.
Added a picture of how they are currently. It's an old case and they are side by side zip tied to the 3.5'' slots taking approx 2 slots high space in the bottom of the bay.
Reason: added a picture
