[Build Log] First WC build, NZXT Switch 810 Matte black - Overclock.net - An Overclocking Community
post #1 of 83 (permalink) Old 07-02-2012, 10:01 AM - Thread Starter
luciddreamer124's Avatar
Rep: 52 (Unique: 46)
This was my very first water cooled build. *will be moving build to a CaseLabs SM8 soon with major changes to loop and wiring, will be making a new thread soon*
Computer parts:
Ivy Bridge 3770k (stable at 4.8ghz)
2 gtx 670 FTW editions in SLI (1300mhz)
ASUS z77 Sabertooth motherboard
Corsair AX850
Nzxt switch 810 matte black case
16 gb corsair dominator platinum RAM
Plextor M3 256gb SSD
Seagate Barracuda 1TB HDD
ASUS optical drive
Corsair K90 Keyboard, Razer Deathadder mouse, Siberia V2 frost edition headset.
Watercooling parts:
EK supremacy cpu block
2x heatkiller nickel "hole edition" 680 waterblocks, 2 heatkiller 680 backplates
Swiftech MCP655 pump
XSPC Dual bay res V2
Bitspower matte black compression fittings
Coolaboratory liquid pro (delidded 3770K) with
XSPC RX360 radiator
Alphacool xt45 240mm radiator
3x noctua nf-f12 pwm fans
4x Corsair sp120 quiet edition fans
3x Corsair af140 fans
Durelene clear tubing (1/2 ID 3/4 OD)
Bitfenix white extension cables.
Hope you guys like the build smile.gif, will be posting lots of pictures soon.
luciddreamer124 is offline
post #2 of 83 (permalink) Old 07-02-2012, 10:45 AM - Thread Starter
First order of watercooling parts arrived first. Unfortunately the white tubing had a bunch of blue scuff marks all over one side. However there was enough unmarked length to make my short loop thankfully. Also waiting on one fan that was on backorder from them (Sidewindercomputers).
450
700
post #3 of 83 (permalink) Old 07-02-2012, 10:47 AM
WaterCooler
Sir Beregond's Avatar
Rep: 72 (Unique: 65)
Deus Ex (2015-)
(21 items)
[Intel] Core i7-4790k
[ASUS] Z97-DELUXE
[ASUS] GTX 980 Strix
[Corsair] Vengance Pro Series 16GB DDR3-2400
[Crucial] M550 512GB
[WD] Black 3TB x 2
[Corsair] AX750
[EK] Supremacy EVO - Gold
[EK] GTX 980 Strix - Fullcover w/ Backplate
[EK] D5 X-RES Top 100 w/ D5 Vario
[Monsoon] 3/8" ID 5/8" OD Compressions - Gold
[XSPC] EX240 x 2
[Corsair] SP120 x 5 / AF120 x 1
[Corsair] Carbide Air 540
Operating System
[Windows] 8.1 Pro 64-bit
[LG] 32GK650F-B
Keyboard
[Corsair] K70 - Red switches
Mouse
[Razer] Naga Epic
Audio
[Audio Technica] ATH-A700
Audio
[Antlion] ModMic
Other
[Lamptron] FC5-V2
[Intel] Core i7-960
[ASUS] Rampage III Formula
[EVGA] GTX 670 FTW 2GB
[Corsair] Dominator-GT 6GB DDR3-1866
[Crucial] M4 128GB
[Samsung] Spinpoint F3 1TB x2
[WD] Caviar Black 750GB
[Corsair] AX850
[XSPC] Raystorm
[XSPC] EX360 and EX240
[Scythe] Gentle Typhoon AP-15 x 5
[EVGA] GTX 680 Hydro Copper w/ Backplate
[XSPC] Dual-bay Res w/ [Swiftech] MCP655
[Bitfenix] Spectre Pro Red LED - 140mm x 4
[NZXT] Switch 810 Matte Black
Operating System
[Windows] 7 Ultimate 64-Bit
[BenQ] XL2420TX
Keyboard
[Saitek] Cyborg V.5 Red LED
Mouse
[Razer] Naga Epic Red LED
Audio
Audio
[ASUS] Xonar Essence STX
Other
[Lamptron] FC5-V2
[Intel] Core M-5Y10
[Intel] HD Graphics 5300
[Generic?] 8 GB DDR3
[Generic?] 256GB SSD
Operating System
[Microsoft] Windows 10
1920 x 1080
Sir Beregond is offline
post #4 of 83 (permalink) Old 07-02-2012, 10:57 AM - Thread Starter
Case and second watercooling order got here next. I LOVE THIS CASE. It is enormous, packed with awesome features, and super good looking. Only complaint I could think of is that the plastic matte black is a noticeably different black from the case panel, but I don't mind too much.
450
450
Love the graphics card block.
700
Got my whole work space set up, just need the computer parts.
450
Figured I could mount the rad in the mean time, so I took the roof off the case and attached it with the 2 noctua fans I had so far.
700
450
Switched the included green O rings for white Monsoon ones, which look WAY better.
post #5 of 83 (permalink) Old 07-02-2012, 11:15 AM - Thread Starter
450
At last! The main parts arrived!
700
700
This motherboard is AMAZING!
700
450
If anyone is planning on getting a z77 sabertooth, get patriot viper xtreme memory. It goes with it perfectly.
700
700
SSD looks great.
450
At first I wasn't too keen on the look of the EK supremacy. However, after installing it I couldn't be happier. It goes perfectly with the motherboard.
700
Got the pump installed.
700
Unfortunately, the ring on the pump has ridges that just slightly interferred with the optical drive below it. All I had to do though was file the plastic ridges down a bit and it fit fine.
450
Drilled a couple holes so I could use the stealth bay cover on the bottom drive.
450
post #6 of 83 (permalink) Old 07-02-2012, 11:32 AM - Thread Starter
Ok to be honest, I am doing this after I finished everything lol. I'll just make it seem like it's happening at the moment. ANYWAY...
700
Had a bit of a scare as I was trying to plug in the 8 pin power connector. I originally had a straight compession fitting up in the corner on the rad, and I then realized that there would not be room to hook up the tubing there, as the motherboard thermal armor was in the way. However I was able to screw in one of my 90 degree fittings up there and have it face outward so I could hook up the tubing.
450
Took out all the screws from the graphics card to install the waterblock.
450
700
700
450
After several painstaking tries I was able to get the graphics card block on.
450
Started tubing routing. The upper left corner was a bit tight.
450
Took a while to hook it up to the res but I finally got it secure.
450
450
Cable management looks a bit messy, especially with all the extensions. However, it is actually very organized, and the side panel fit on with ease.
700
post #7 of 83 (permalink) Old 07-02-2012, 12:25 PM
tomato16's Avatar
Rep: 9 (Unique: 9)
Any reason why you went with a 360mm radiator instead of a 420mm?
tomato16 is offline
post #8 of 83 (permalink) Old 07-02-2012, 12:33 PM
FearXI's Avatar
Rep: 18 (Unique: 12)
In these cases you can't fit a 420.
And yes does look good.
Firearm Glock 19 Generation 4
FearXI is offline
post #9 of 83 (permalink) Old 07-02-2012, 12:42 PM - Thread Starter
Here are some pictures of the finished build. Hopefully I will get some better pictures of it once I get my hands on a better camera.
450
450700
700
Realized the sticker that came with the motherboard would actually look SICK.
450
450
This is my temporary set up (lol) until my dad and I build a new desk for it.
700
Future updates include:
Add another 670, RX240 at the bottom,
More extension cables (internal USB and audio, EPS).
Might get some primochill coolant (just have distilled water and kill coil right now, don't want any corroision).
Also, thinking about putting some carbon fiber vinyl on parts, black or white not sure. If you guys have imput on where I should do that / what color feel free to comment.
post #10 of 83 (permalink) Old 07-02-2012, 12:46 PM - Thread Starter
The reason for this is that the spacing on the 140mm holes is not standard, and I would have to drill some holes up top to make it work. Didn't really want to do that, so just went with a 360 which fit perfectly. Also the upper left corner is already super tight with tubing because of the thermal armor on the mobo, and I have a feeling the 420 would make it even more cramped since the fittings would be farther back.
