Pipe bending 101 - Overclock.net - An Overclocking Community
Pipe bending 101
post #1 of 2175 (permalink) Old 07-10-2012, 02:36 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
I have been asked a few times now how i bent my pipe for my SR 2 build,so i decided to do a little walk thru.
The tools you will need are these:
A Cup of Tea...mine was a milky number to get the juices flowing.
A set of benders...these are for half-hard pipe but can be used for annealed.
A Cutter for the chosen OD of your tube
A Ruler
Some tape.
I recommend Rothenberger benders,these are high quality and are worth the extra.
Otherwise,you may have to 'mod' the benders..like this:
The top guide was poorly aligned and needed a bit of work before use.
Poorly aligned guides can distort the tube and put creases down the length of the bend.
So..take a bit of tape to make a base mark.
Place the base mark on the 0 point of the bender.
Line up the guide with the 0 mark.
Make the bend using constant pressure,dont snatch at it,use nice firm and even pressure.
Once you have made your bend,measure the distance from the 0 mark and the outer wall of the bend.
This is the radius measurement,in this case 28mm,remember this as it will allow you to make accurate 90-90 bends to go 180 like this.
To cut the tube to length,use the cutter,rotating the the direction indicated on the tool.
Try to keep everything straight when cutting,the cutter can spiral if its not held 90 to the pipe.
This a basic guide,for any specific info,please comment below.
Pipe stockists in the US. Kindly provided by Fuganater
10mm:
http://www.mcmaster.com/#standard-metal-tubing/=icfb8z
http://www.onlinemetals.com/merchant.cfm?pid=18333&step=4&showunits=inches&id=1288&top_cat=87
http://www.onlinemetals.com/merchant.cfm?pid=1866&step=4&showunits=inches&id=1295&top_cat=87
http://electrontubestore.com/index.php?main_page=product_info&cPath=57_122_123&products_id=1587
http://www.ebay.com/sch/i.html?_odkw=10+mm+copper+tube&_osacat=0&_trksid=p2045573.m570.l1313&_nkw=10+mm+copper+pipe&_sacat=0
12mm:
http://www.mcmaster.com/#standard-metal-tubing/=icfaeq
EDIT:
KPForce's method of straightening coiled tube
B NEGATIVE is offline
post #2 of 2175 (permalink) Old 07-10-2012, 02:58 AM
Old to Overclock.net
threephi's Avatar
Rep: 120 (Unique: 96)
threephi is offline
post #3 of 2175 (permalink) Old 07-10-2012, 03:03 AM
Fuganater's Avatar
Rep: 68 (Unique: 54)
Fuganater is offline
post #5 of 2175 (permalink) Old 07-10-2012, 03:09 AM
Ace_finland's Avatar
Rep: 68 (Unique: 67)
Do you remember what the inner diameter was on the fittings? When i was looking for pipe fittings they were like 6mm id, thought that would be too restrictive? How has you loop worked?
Ace_finland is offline
post #6 of 2175 (permalink) Old 07-10-2012, 03:16 AM
post #7 of 2175 (permalink) Old 07-10-2012, 03:24 AM
DEEBS808's Avatar
Rep: 15 (Unique: 14)
DEEBS808 is offline
post #8 of 2175 (permalink) Old 07-10-2012, 03:53 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Originally Posted by DEEBS808 View Post
Thanks man.Will try in new build..what size pipe are those?
This pipe is 10mm OD.
You can also go for 12mm pipe and use BP/Phobya Sli Fittings,not recommended for 180 pipe runs as they dont have a lock ring.
post #9 of 2175 (permalink) Old 07-10-2012, 03:57 AM
CrazzyRussian's Avatar
Rep: 63 (Unique: 62)
Even if I'll probably never get that far into water cooling to use this, awesome guide bro!
CrazzyRussian is offline
post #10 of 2175 (permalink) Old 07-10-2012, 03:58 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Thanks man.
