[Official] Mayhems users club - Page 1686 - Overclock.net - An Overclocking Community
post #16851 of 16857 (permalink) Old 12-02-2019, 08:03 AM
skupples's Avatar
Rep: 582 (Unique: 326)
we've come a long way from pigeon poop
skupples is offline
post #16852 of 16857 (permalink) Old 12-02-2019, 10:45 AM
Programmer
BradleyW's Avatar
Rep: 1555 (Unique: 1017)
Quote: Originally Posted by skupples View Post
yeah, that's not surprising. Aurora is incredibly tempermental, and amazon users likely did nothing but just dump it into their system. The amount of prep work required for it to not shift is pretty hefty, same for trying to use black dyes.
aside from that - as far as additives go. X1 or Biocide+ inhibitor+ are phenomenal products. I used x1 in a soft tube sytsem i didn't properly clean, and ignored it for 5 years. Only took 5 minutes to clean the blocks back to new (minus some copper patina)
Quote: Originally Posted by ThrashZone View Post
Hi,
Makes you wonder a little
Seeing the instructions on the blitz part 1's bottle and white paper are light years different on potency on just how harsh part 1 can be so if someone followed the bottle and ran it through an entire system instead of just the rads what would happen = meltdown ... [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
for sure, mick assumes his users do their due dilligence, and they don't. the amazon reviews are pretty funny. too bad they didn't stumble on this little thread first. I wonder if we show up on the 1st page when googling mayhems? I can't really test it, my results would be tainted.
imagine running that body dissolving grade acid straight, then filling w. coolant, turning on your dual pump at full blast... your radiators would turn into sprinklers.
as stated, step 1 is overkill for most folks, unless they're trying to build a top tier beast with funky coolant, and then continue to run said funky coolant as a daily driver.
you can easily recreate this at home with less caustic stuff, and a simple baking soda wash.
orrrr, just do it the old school way (lots of hot water), and use normal coolant = 99% of problems solved.
X1 is brilliant. A must have. A wonder product. Works brilliantly at an affordable price and can last a long while over its service lift of 9-12 months. Not recommended of course.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
AMD ASUS STRIX OC VEGA 64
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO NVM.e 250GB
SeaSonic 1250W Gold
Corsair 900D + Custom Loop.
BradleyW is offline
post #16853 of 16857 (permalink) Old 12-02-2019, 08:42 PM
Rep: 1 (Unique: 1)
Quote: Originally Posted by war4peace View Post
people generally should go for water unless they want to use Hydrofluoric acid or Mercury in their builds
Mercury cooling? Now THAT is metal AF!
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Sapphire Rx 590 Nitro+ 8Gb SE
Kingston Fury HyperX
Corsair CS750M
Noctua NH-D9L
Lian Li PC-011 Dynamic
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
Logitech G402 Hyperion Fury
bkrownd is offline
post #16854 of 16857 (permalink) Old 12-02-2019, 08:43 PM
skupples's Avatar
but how would you cool it?
skupples is offline
post #16855 of 16857 (permalink) Old 12-03-2019, 02:52 AM
Big Radiators!
war4peace's Avatar
Rep: 23 (Unique: 21)
That's a tricky feat. 1L of Mercury weighs 13.53 kg, so you will need a very strong pump. Also, mercury amalgamates with most other metals, however you could platinum-coat your waterblocks (instead of nickel-coating them). Not sure what you could do about the radiators, I guess you could make them of iron, which doesn't form an amalgam with mercury. Don't use steel, though, because mercury corrodes it.
Due to its extreme weight per volume, you would need thick glass tubing, although I suspect 16/10 tubing would suffice.
Looking at the above, I guess it's not worth it
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #16856 of 16857 (permalink) Old 12-03-2019, 07:56 AM
skupples's Avatar
yeah it would be quite the cluster lol
i mean, even CLU eats away at your blocks and that has minute mercury & galium.
skupples is offline
post #16857 of 16857 (permalink) Old 12-03-2019, 09:40 AM
Big Radiators!
war4peace's Avatar
Truth be told, it had been one of my "what if...?" things related to watercooling, until I researched it and realized it's next to impossible. It would definitely not help GPU waterblocks but would very likely drop CPU temperatures because it would soak away heat much more rapidly.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
