[Official] Mayhems users club - Page 1699 - Overclock.net - An Overclocking Community
post #16981 of 17415 (permalink) Old 02-15-2020, 09:46 AM
Black Sun Empire
Wuest3nFuchs's Avatar
Rep: 38 (Unique: 31)
Quote: Originally Posted by iamjanco View Post
Again, depends. Can you actually make effective use of the quantity of the RO you could be generating using the €300 setup you mentioned? How many liters is your brother's aquarium? €300 could purchase a large quantity of Pure H2O and then some; even more distilled water, if you went that route if it's available at a reasonable cost to you.
As an example, my RO was always hooked up and running, and I kept a 33 gallon pail (roughly 125 liters) full of RO. Granted, I had a 125 gallon saltwater tank, sump, refuge, etc., and had no trouble going through that amount of water on a regular basis, which more or less made the operation cost effective and did away with the various aspects of procuring such water otherwise; the only real drawback being the need to have a dedicated space and mains source of water to run the RO and store its output.
Weigh the pros and cons against you and your brothers needs, then go from there.
he has a 250ltr aquarium and he hates that distilled plastic bottles ,me too.
So i think we go that route.
Quote: Originally Posted by skupples View Post
we have one on the entire house. Had it installed after seeing how well the ones @ work, work.
idk about using it in my PC, but its sure yummy everywhere else.
I'll let you guys know when i have it,and tried it in my Loop.
But i'll guess that takes a bit of time to own this device, cause i cant find a seller in my country(yet).
Gesendet von meinem SM-G950F mit Tapatalk
Watercoolingbox
https://www.overclock.net/t/1352993/...oolingbox/0_20
V3g4n0
(18 items)
2700X
Asus ROG Crosshair Hero VII
Sapphire RX Vega56 Pulse
GSkill F4-3200C14D-16GFX
Crucial MX 500
Crucial MX 500
Optical Drive
Pioneer BDR S09 XLT
BeQuiet Straight Power
BeQuiet Silent Loop 240mm
BeQuiet DARK BASE PRO 900 Silver rev. 2
Operating System
Win 10 1803
AOC Agon AG241QX, 23.8"
Keyboard
Steelseries M750
Mouse
Steelseries Sensei 310
Mousepad
Steelseries DEX
Audio
Steelseries Arctis 5
Audio
Sound Blaster X-Fi titanium HD
Other
Tobii Eyetracer 4c
Ryzen 5 2400G
Asus TUF X470 PLUS GAMING
Crucial Ballistix Sport AT DIMM Kit 16GB Single Ranked BLS2K8G4D30CESTK
Samsung SM843 MZ7TD240HAFV-000DA
Crucial M4
be quiet! Straight Power 11 550W ATX 2.4 (BN281)
Ryzen 7 Wraith RGB
Fractal Design Define R6 Black
Operating System
Win 10 1803 / Server 2016 Standard
Samsung SyncMaster XL2370 LED, 23" (LS23EFPKFVEN)
Wuest3nFuchs is offline
post #16982 of 17415 (permalink) Old 02-15-2020, 10:43 AM
diggiddi's Avatar
Rep: 108 (Unique: 87)
is this normal for coolant to look like this after a year, using mayhems xt-1 old formula?
Also is it ok to flush with hot water, then distilled then run distilled + vinegar before final flushing with distilled, plus cleaning plate with vinegar and distilled water
But can it run.... Angry Birds???
About the NVidia GTX 970
"When comes down to it, it's really a $250 card with lies printed all over the box."--Rexer
diggiddi is offline
post #16983 of 17415 (permalink) Old 02-15-2020, 11:14 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 736 (Unique: 388)
do you have a less opaque object and a more steady hand?
coolant picks up stuff over a year even if the system was stupid tier cleaned first.
Add me on Steam, same name
skupples is offline
post #16984 of 17415 (permalink) Old 02-15-2020, 11:33 AM
Taking a break
iamjanco's Avatar
Rep: 145 (Unique: 66)
That's the way you should go then. Though the RO/DI water should be fine in your PC (and your brother's aquarium) if you manage it properly, you might also want to get a TDS meter of some sort to make sure that what you'll be using is being processed properly. You'll likely want to get an RO setup that includes DI filtering as well.
In any event, your brother may already have what you need to test the water you process if he's been checking the water he uses in his aquarium himself. Even the best filtration systems will need occasional testing as the filters used in them eventually will need to be changed:
Using Reverse Osmosis Water in Saltwater Aquariums
Full Google search: testing RO DI water used in saltwater aquariums
Muffler Bearings
(24 items)
i9-7900X, i9-10940x
Asus Rampage VI Extreme
EVGA X299 DARK
EVGA GeForce RTX 2080 Ti XC
(2 ea) EVGA GTX 1080 Ti FTW3
G.SKILL F4-3200C14Q2-64GTZ
(2ea) Intel Optane 900P (480GB)
(2ea) Samsung 850 Pro 1TB
(2ea) Samsung 850 Pro 256GB
(2ea) Samsung 970 Pro 512GB
(1ea) Samsung 950 Pro 256GB
EVGA SuperNOVA 1600 T2
Custom water
Custom, 8020x3060 and x2020
Operating System
Win 10 Pro/Ubuntu
NEC PA272W-BK-SV
Eizo ColorEdge CE240W
Alienware AW3418DW
Keyboard
Ergodox EZ with Kailh Thick Gold (Bronze) and Copper switches
Audio
Bottlehead Mainline Amp
Audio
RME ADI-2 Pro FS 2-in/4-out AD/DA Converter
Audio
FOCAL Clear Professional Headphones
Audio
Mr. Schpeakers ETHER C Flow 1.1 Headphones
Other
Protectli Firewall Micro Appliance With 6x Intel Gigabit Ports, Intel i5 7200U, AES-NI
Other
Misc. see build description for details
iamjanco is offline
post #16985 of 17415 (permalink) Old 02-15-2020, 11:38 AM
diggiddi's Avatar
It looks like copper sulfate solution from rads and block, not sure I understood your statement though
diggiddi is offline
post #16986 of 17415 (permalink) Old 02-15-2020, 01:20 PM
Black Sun Empire
Nice read, thanks alot!
A tds meter measures ppm/ec?
If it's that we have such a device.
if i couldnt find a seller for this growmax ro/di whatelse can i and my brother use from a different maker?
Also thanks for the links
Watercoolingbox
V3g4n0
(18 items)
2700X
Crucial MX 500
Crucial MX 500
Optical Drive
Pioneer BDR S09 XLT
Operating System
Win 10 1803
Keyboard
Steelseries M750
Mouse
Mousepad
Steelseries DEX
Audio
Audio
Other
Tobii Eyetracer 4c
Ryzen 5 2400G
Crucial M4
Ryzen 7 Wraith RGB
Operating System
post #16987 of 17415 (permalink) Old 02-15-2020, 01:54 PM
Taking a break
iamjanco's Avatar
You're welcome
I've been out of the reef hobby for years, so I couldn't really give you sound recommendations about the different brands available today, especially in your part of the world. But if your brother is a member of a relatively local reef club, you or he might start by inquiring there. If you're near enough to Innsbrook, there might be a club there.
You might also try inquiring at public aquariums in Innsbruck for recommendations, perhaps check with the staff there. It looks like there might also be a an aquarium specialist shop or two in the Innsbrook area where you might try your inquiries; though I'd think other hobbyists in your area would be the best bet for recommendations.
You're also not extremely far from larger cities like München, where answers might be found easier. In any event, good luck, and let us know what you eventually come up with
Muffler Bearings
(24 items)
i9-7900X, i9-10940x
EVGA X299 DARK
Custom water
Operating System
Win 10 Pro/Ubuntu
NEC PA272W-BK-SV
Alienware AW3418DW
Keyboard
Audio
Audio
Audio
Audio
Other
Other
iamjanco is offline
post #16988 of 17415 (permalink) Old 02-15-2020, 06:57 PM
Vermin Supreme 2020
skupples's Avatar
oy vey.
I spent a year taking care of my dad's failed attempt at a home reef.
my take away is this - if you don't wanna setup a proper quarantine tank rotation, stick to just coral. otherwise, you'll be fighting disease forever. there's no such thing as a disease free fish from the local fish store. at least, not at the tier of local store we were shopping at.
growing coral is definitely on my list of things to do again. coral & crustaceans. I'm good on the salt fish bit, at least until I have a large enough place to setup all the extra tanks needed to keep everyone happy & healthy.
skupples is offline
post #16989 of 17415 (permalink) Old 02-15-2020, 07:11 PM
Taking a break
iamjanco's Avatar
I enjoyed it myself; though like a lot of hobbies, it can be a money pit.
Crustaceans, eh? If you want to go fishless, you might try one of these. Heck, sometimes they even come free in the live rock you get:
Otoh, if you don't want to go fishless and end up with one or more of those in the live rock you get, sooner or later you might be fishless
Muffler Bearings
(24 items)
i9-7900X, i9-10940x
EVGA X299 DARK
Custom water
Operating System
Win 10 Pro/Ubuntu
NEC PA272W-BK-SV
Alienware AW3418DW
Keyboard
Audio
Audio
Audio
Audio
Other
Other
iamjanco is offline
post #16990 of 17415 (permalink) Old 02-15-2020, 07:15 PM
Vermin Supreme 2020
skupples's Avatar
always gotta have a clean up crew, though not one so savage that it eata EVERYTHING else in the tank
and yes, most definitely one of the more expensive "adult hobbies" though, at least in Florida, there's no shortage of used tanks on the low low.
skupples is offline
