[Official] Mayhems users club - Page 1700 - Overclock.net - An Overclocking Community
post #16991 of 17425 (permalink) Old 02-17-2020, 05:45 AM
Black Sun Empire
Wuest3nFuchs's Avatar
Rep: 38 (Unique: 31)
thank you guys for the little inside of aquariumstuff. Also the video is very interesting.looking forward thx
Gesendet von meinem SM-G950F mit Tapatalk
Watercoolingbox
https://www.overclock.net/t/1352993/...oolingbox/0_20
V3g4n0
(18 items)
2700X
Asus ROG Crosshair Hero VII
Sapphire RX Vega56 Pulse
GSkill F4-3200C14D-16GFX
Crucial MX 500
Crucial MX 500
Optical Drive
Pioneer BDR S09 XLT
BeQuiet Straight Power
BeQuiet Silent Loop 240mm
BeQuiet DARK BASE PRO 900 Silver rev. 2
Operating System
Win 10 1803
AOC Agon AG241QX, 23.8"
Keyboard
Steelseries M750
Mouse
Steelseries Sensei 310
Mousepad
Steelseries DEX
Audio
Steelseries Arctis 5
Audio
Sound Blaster X-Fi titanium HD
Other
Tobii Eyetracer 4c
Ryzen 5 2400G
Asus TUF X470 PLUS GAMING
Crucial Ballistix Sport AT DIMM Kit 16GB Single Ranked BLS2K8G4D30CESTK
Samsung SM843 MZ7TD240HAFV-000DA
Crucial M4
be quiet! Straight Power 11 550W ATX 2.4 (BN281)
Ryzen 7 Wraith RGB
Fractal Design Define R6 Black
Operating System
Win 10 1803 / Server 2016 Standard
Samsung SyncMaster XL2370 LED, 23" (LS23EFPKFVEN)
Wuest3nFuchs is offline
post #16992 of 17425 (permalink) Old 02-17-2020, 12:00 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Quote: Originally Posted by Wuest3nFuchs View Post
Good morning,
Would you guys buy a reverse osmosis filtration system with deionization(which should be Ultra Pure H2O afterwards) for ~300€ and use/mix it in your Loop together with the biocide+ and inhibitor+ or even x1 ?
I just found such a device that does eliminate all that bad stuff in water.
http://growmaxwater.com/reverse-osmo...m-000-ppm.html
greetings
I buy distilled 4 gallons at a time at $1.08 (USD) each which is enough to flush and refill my loop.
I couldn't justify the cost, unless I had difficulty getting true distilled water and had to travel and hour in either direction.
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #16993 of 17425 (permalink) Old 02-18-2020, 03:17 PM
hahler2's Avatar
Rep: 0
So my first time using distilled water in a loop. Had always used coolants before. I filled with distilled, and then added a few drops of Inhibitor+ and Biocide+ to the res. Ran the loop for a couple of days and then used my pH kit to test it. Long as I'm reading it correctly, I believe I've got my pH at almost exactly 7. do I need to just automatically add a few drops of Inhibitor and Biocide every few months, or should I test my water first, and only add more drops when the pH starts to get off?
hahler2 is offline
post #16994 of 17425 (permalink) Old 02-18-2020, 03:36 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 736 (Unique: 388)
bottle says to add a few drops every so often. always good to aim for 7, ofc. it's the only metric of stability we really have. no one's taken the time to figure any others out
Add me on Steam, same name
skupples is offline
post #16995 of 17425 (permalink) Old 02-18-2020, 03:39 PM
hahler2's Avatar
Rep: 0
Thank you
hahler2 is offline
post #16996 of 17425 (permalink) Old 02-19-2020, 09:36 AM
Zfast4y0u's Avatar
Rep: 4 (Unique: 3)
just ordered mayhems x1 clear, but not from them directly cause of insane shipping prices. got one question about x1 clear. im not sure how am i supposed to mix this thing correctly with distilled water. according to their instructions i should do this: For "Normal Ambient Cooling" - Mix 125 ml of coolant with 850 ml of water. (makes 2 Ltrs in total).
https://www.mayhems.net/products/x1-...903bc7be&_ss=r
so i guess, its 125ml of x1 + 850ml of water = 1l of coolant. where i ordered it, it say mix 250ml of x1 + 750ml of water for 1l of coolant, so which one is it? xD
Zfast4y0u is offline
post #16997 of 17425 (permalink) Old 02-19-2020, 10:03 AM
Shawnb99's Avatar
Rep: 60 (Unique: 41)
It means Mix 125 ml of coolant with 850 ml of water for 1l of coolant, yes I'm aware that's only 975ml but I guess 25ml doesn't mattet. The whole bottle makes enough for 2l. If you need more then that you need more bottles. If less then use math to figure out the smaller amounts, IE 75ml and 425 of water for 1/2l of coolant and so on.
The other measurement is if you're going sub-ambient water temps.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #16998 of 17425 (permalink) Old 02-20-2020, 12:37 PM
Rep: 1 (Unique: 1)
Wait....wait.....
I did buy 5L of X1 Clear....and didn`t mix with nothing...
You guys are telling that it must be mixed with water???
P.S Never mind.....you guys talk about concentrated....
Mordorr is offline
post #16999 of 17425 (permalink) Old 02-25-2020, 08:21 PM
M3TAl's Avatar
Rep: 182 (Unique: 134)
Any projected date for the new Pastel XTR to hit retail in the states? Putting together new Ryzen build but might try to wait until Pastel XTR is out because once the loop is done I'm not draining and cleaning just to swap fluids. I really am that lazy haha. Watercooling a desk is actually kind of a pain and maintenance stinks too. Prefer to get it right the first time then let it be for a long time.
M3TAl is offline
post #17000 of 17425 (permalink) Old 02-25-2020, 09:13 PM
Vermin Supreme 2020
skupples's Avatar
Quote: Originally Posted by Mordorr View Post
Wait....wait.....
almost positive the 5L is a pre-mix. it would say as such on the bottle.
concentrate, or premix...
skupples is offline
