[Official] Mayhems users club - Page 1702 - Overclock.net - An Overclocking Community
post #17011 of 17384 (permalink) Old 04-04-2020, 04:33 AM
Astral85's Avatar
Rep: 4 (Unique: 4)
Quote: Originally Posted by ThrashZone View Post
Hi,
Seems pretty clear
Whoops missed that, was more focused on the mixing ratios further down the page. What is another 10% on top 100ml if you were to add more for sub zero?
Asus Maximus XI Hero, 8700K 5.0Ghz, Custom loop: EKWB Velocity, X-RES D5, Rads: EK PE 360, Corsair XR5 280, EVGA RTX 2080 Ti FTW3 Ultra/EK Vector FTW3, Corsair Dominator Platinum RGB 32GB 3733Mhz, Samsung 850/860 Evo's, Seasonic Prime Ultra 1300W, Phanteks Eclipse P600S, Asus ROG Swift PG349Q 120hz 34"
Astral85's RIG
(0 items)
Astral85 is offline
post #17012 of 17384 (permalink) Old 04-04-2020, 05:19 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 732 (Unique: 385)
maybe i'm still asleep.
10% of 100 = 10?
are you going sub zero? if not, you may affect your water's cooling potential by using too much NUKE
Add me on Steam, same name
skupples is offline
post #17013 of 17384 (permalink) Old 04-04-2020, 11:30 AM
Rep: 1 (Unique: 1)
Quote: Originally Posted by skupples View Post
you'd need to drain, clean, inspect for damage.
how much X1 did you use, and how did you clean your radiators before filling for good?
I clean with many liters of destillated water.
How much X1 did i use? All.
Its already pré-mixed (from 5L bottle).
Mordorr is offline
post #17014 of 17384 (permalink) Old 04-04-2020, 07:45 PM
Vermin Supreme 2020
skupples's Avatar
=\ shaking room temp distilled doesn't always do the job.
blitz kits ftw.
skupples is offline
post #17015 of 17384 (permalink) Old 04-04-2020, 09:38 PM
What's a computer?
Rainmaker91's Avatar
Rep: 105 (Unique: 80)
Blitz is preferred for sure, but even Mayhem has mentioned alternatives to it before. I do agree though, just trusting room temperature distilled water to do it for you is a bit to naive. Boiling distilled water is better and will at the very least remove the flux and most of the debris from the radiator. To remove any paint residue and corrosion you will have to use stronger chemicals.
It's not going to be as good as Blitz, but you could try it the way Mayhem shows it @17min in this video:
Rainmaker91 is offline
post #17016 of 17384 (permalink) Old 04-05-2020, 02:34 AM
Rep: 1 (Unique: 1)
Nice.
But one year using car liquid didnt`t do that to my Heatkiiler D5 suport....
Not impressed.
Mordorr is offline
post #17017 of 17384 (permalink) Old 04-05-2020, 08:17 AM
Vermin Supreme 2020
skupples's Avatar
A.) should've stuck with what was working
B.) who knows what weird stuff is going on now in the loop if you had auto coolant going before, & didn't clean properly.
you need to do a genuine flush. not just fill & drain.
skupples is offline
post #17018 of 17384 (permalink) Old 04-05-2020, 09:57 AM
Rep: 1 (Unique: 1)
ok, ok.
I get the message. But i did remove all coolant....quiete sure about it.
Have to turn off the dam pc, dismantle everything.....arghh.....
Any chance to recovery the niquel mirror effect?
Thanks for the video few posts above...learn a lot!
Mordorr is offline
post #17019 of 17384 (permalink) Old 04-05-2020, 09:59 AM
Vermin Supreme 2020
skupples's Avatar
you should be able to rub off whatever that is.
do not use any compounds or solvents on the nickel itself.
radiators are traps. they're the main thing you wanna acid bath, then basic bath.
skupples is offline
post #17020 of 17384 (permalink) Old 04-05-2020, 10:18 AM
What's a computer?
Should be fine just running massive amounts of water through it to. I have for example just straight up hooked my radiator to the sink and let it run for an hour, flusehed out the acid/base quite well. Though you should obviously do a PH check afterwards and then rinse out with a less agressive cleaner (Like Sysprep, Blitz part2 or any otehr prep fluid really).
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
