Haf X and RX360 radiator - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 08-02-2012, 10:03 AM - Thread Starter
andrew99's Avatar
Rep: 0
Hey everyone,
Will a rx360 radiator fit on the top of a Haf-X case?
My motherboard is an asus maximus V formula.
I am thinking of a push/pull configuration with these fans : http://www.frozencpu.com/products/9124/fan-570/Scythe_Kaze-Jyuni_Slim_Slip_Stream_120mm_x_12mm_Fan_-_2000_RPM_SY1212SL12H.html?tl=g36c15s972#blank
andrew99 is offline
post #2 of 17 (permalink) Old 08-02-2012, 10:28 AM
Codycjd's Avatar
Rep: 0
Yes.
"Up to 2 top 200mm fans (one optional) or 360mm radiator"
Source
Codycjd is offline
post #3 of 17 (permalink) Old 08-02-2012, 11:56 AM
jcho285's Avatar
Rep: 12 (Unique: 12)
Yes it fits. This is my RX360 on my old build on the HAF
jcho285 is offline
post #4 of 17 (permalink) Old 08-02-2012, 12:06 PM - Thread Starter
andrew99's Avatar
Rep: 0
Did you need to take out some of the front drive bays?
andrew99 is offline
post #5 of 17 (permalink) Old 08-02-2012, 12:24 PM
jcho285's Avatar
I don't think so but don't remember for sure. I had a small fan controller (half the size of regular cd-bay) installed in the first bay. Last 3 bays was for a fan.
jcho285 is offline
post #6 of 17 (permalink) Old 08-02-2012, 04:16 PM - Thread Starter
andrew99's Avatar
Rep: 0
ok, a little off topic, What is the best coolant fluid? and would you recommend red tubing with clear fluid, clear tubing with red fluid, or red tubing with red fluid? (Yes I want to have UV lighting)
andrew99 is offline
post #7 of 17 (permalink) Old 08-02-2012, 06:35 PM
jcho285's Avatar
Distilled water with Silver Coil is the best. Less maintenance.
Red tubing/distilled will work fine, in fact, probably what i'll do next.
Red tubing is going to look great on that Formula board.
This is my clear/uv tube with distilled with blue LED lighting:
jcho285 is offline
post #8 of 17 (permalink) Old 08-02-2012, 06:42 PM - Thread Starter
andrew99's Avatar
Rep: 0
I have heard that some people put a little antifreeze into it, is that a good idea?
Also nice rig!
andrew99 is offline
post #9 of 17 (permalink) Old 08-02-2012, 07:18 PM
jcho285's Avatar
Thanks, I heard antifreeze isn't a good idea, anything other than water=potential clog.
Also even with the antifreeze, not much of a temperature gain.
jcho285 is offline
post #10 of 17 (permalink) Old 08-02-2012, 09:27 PM - Thread Starter
andrew99's Avatar
Rep: 0
Really? I heard that the purpose of it was to put a few drops and then that could prevent corrosion.
andrew99 is offline
