Antec Kuhler 620: 8 Rad/Fan Setups Tested - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 08-07-2012, 05:25 PM - Thread Starter
M3TAl's Avatar
Rep: 180 (Unique: 132)
Not sure if this should be in water cooling or air cooling…
Note: These tests were to find the best possible position/temps for my case/setup before remounting. Temps are worse after moving to new mobo and going from stock paste to mx-2. Will be remounting soon.
Flaw in testing methodology: I have nothing to record ambient temps but house does run AC on 77F/25C. My room is the hottest in the house and is normally 79-81F/26.1-27.2C in the summer day or night.
Tested 8 different fan/radiator setups using the Antec Kuhler 620 with stock fan in CM690II Advanced B&W. 20min Prime95 Blend runs recorded using Open HW Monitor.
Tmp#1=random mobo sensor
Tmp#2=VRM
Tmp#3=CPU Socket
955 @ 4ghz 1.488v load 1.456v idle 1.072v power saver idle
Cpu-nb stock 2ghz 1.1v
Results are listed from WORST to BEST based on MAX CPU CORE temp
Result 1: 63C Very stupid setup... Just shows how your fans are setup make a big difference. Refer to Result 4 for comparison.
Result 2: 61C Thought this result would be better than Result 3 due to recycling hot exhaust back into radiator. Apparently not.
Result 3: 60C
Result 4: 58C
Result 5: 57C Seems to be recycling warm exhaust. Look at Result 7 for comparison.
Result 6: 56.5C Not bad but would prefer to not intake from the rear... no dust filtration.
Result 7: 55.5C Not bad result but the antec fan is loudest when mounted vertically in the top as intake as compared to horizontally mounted.
Result 8: 54.9C and 54.8C. These two tests were taken on two separate days and should show that ambient temps and overall testing methodology were fairly consistent. The only difference was the side intake fan.
How it looks inside the case:
M3TAl is offline
post #2 of 4 (permalink) Old 08-08-2012, 01:32 AM
Fuganater's Avatar
Rep: 68 (Unique: 54)
Fuganater is offline
post #3 of 4 (permalink) Old 03-03-2013, 11:13 PM
8bitG33k's Avatar
Rep: 18 (Unique: 18)
I'll have to try rigging my 920 in the hard drive bay soon. So you have your 620 mounted sideways? At least that's what it looks like in the pic. Love the shoelace mod btw! +rep
ModboXx
(24 items)
i7-8700k
MSI Z370 Gaming Plus
ASUS GTX 1070 8GB ROG Strix
G.Skill Ripjaws V
Samsung 830
OCZ Agility 3 AGT3-25SAT3-60G
Western Digital Black
Corsair RM750x
CORSAIR Hydro Series H80i v2
NZXT S340VR-Elite
Operating System
Windows 10 64-bit
Acer XF270HU
TCL 55P607
Keyboard
Corsair K70 Red LED Blue Cherry
Mouse
Asus GX950
Audio
Beyerdynamic DT990
Audio
SoundblasterX G5 DAC
Audio
Audeze Mobius
Other
Steamcontroller
Other
Xbox 360 Wireless Gaming Receiver for Windows
Other
Microsoft Wireless 360 Controller
Other
DX Racer DOH/EA01/NW
Other
CP1500PFCLCD UPS
Other
Thrustmaster T.16000M FCS HOTAS
8bitG33k is offline
post #4 of 4 (permalink) Old 03-07-2013, 02:31 AM - Thread Starter
M3TAl's Avatar
Haha ya, those are shoe laces! They seem to hold up just fine. The 620 is sideways, it takes up too much room in the 5.25" bays if vertical. In my old Cooler Master Centurion 590 it fit all the way in the front of the 5.25" bays.
M3TAl is offline
