[Build Log] CaseLabs STH10 - Aquacomputer EVGA - "Seanimus448" - Overclock.net - An Overclocking Community
post #1 of 1388 (permalink) Old 08-18-2012, 08:02 PM - Thread Starter
Seanimus's Avatar
Rep: 43 (Unique: 33)
Final Pictures from June 2013:
Initial run-removing air from 2x 420 AQ Radiators:
The motherboard wall has custom cutouts and PEMs so the AQ bracket can be installed with one hand
Link for Build Log for Vertical Slightbox and has a 1" gap for cables to pass through:
Link for Build Log of the front custom made Seanimus Dual Vandal Switch bay:
Link for Drilling Acrylic on the horizontal Slightbox - drilling of acrylic:
Two 420Aquacomputer AMS Copper Radiators - Cougar 140MM Fans below:
How to mount /drill holes in STH10 for AQ 450ML reservoirs. Post #926
Using standoffs to hide cables behind a mini-SlightBox Post #935
Shrinkless Sleeving. Post #720
How to mount Bitspower fill port into acrylic or metal. Post #791
Jeak's RGB Amp Post #764
Anode versus Cathode Based Leds. Post #759
Seanimus is offline
post #2 of 1388 (permalink) Old 08-18-2012, 10:31 PM - Thread Starter
Seanimus's Avatar
Original post from August 2012:
Hello All,
My first post and my first liquid cooled build. Please provide comments to make this build better.
so far all i have done is put the cpu into the board
Couldn't deal with the custom PSU 24 pin layout coming out of Corsair AX850. Purchased Silverstone.
Got EVGA PSU...new one..returned Silverstone
EVGA 690 Hydro Copper:
Aquacomputer Aqualis with NanoCoating
LG Blu Ray Drive
Seanimus is offline
post #3 of 1388 (permalink) Old 08-26-2012, 10:07 AM
mphysgr's Avatar
Rep: 0
Hey, I have a TH10 and am planning on using much of the same aquacomputer gear. I will be interested in seeing what you do with it.
Subbed
mphysgr is offline
post #4 of 1388 (permalink) Old 08-26-2012, 10:17 AM
Linux Lobbyist
theseekeroffun's Avatar
Rep: 116 (Unique: 93)
You should send your A-5 faceplate to Jim and have him powdercoat it for you, that's what I did.
The Aqua rads are very restrictive, so you will have crank the D-5's. Good luck and nice gear, especially the case.thumb.gif
theseekeroffun is offline
post #5 of 1388 (permalink) Old 08-26-2012, 04:20 PM - Thread Starter
Seanimus's Avatar
Spent this afternoon painting the faceplate of the Bluray, A5 and a 3.5 bay Akasa multi card carder/usb 3.0.
The A5 is being stubborn, had to resand and doing 2nd try now.
May have to send to Jim at CaseLabs.
Just got my Canon t4i back yesterday; will post pictures once the paint has dried.
Seanimus is offline
post #6 of 1388 (permalink) Old 08-26-2012, 07:18 PM - Thread Starter
Seanimus's Avatar
The white case:
macrolens shot:
Priming:
Result:
Have to redo the 3.25 Card Reader.....pressed it too hard in the corner before 24hrs.
Sample try in case:
Still waiting on sleeving from Nils...received this so far:
Seanimus is offline
post #7 of 1388 (permalink) Old 08-27-2012, 04:22 PM - Thread Starter
Seanimus's Avatar
Aquaero 5 ; can't get it to fit in 5.25 bay of STH10. I am obviously doing something wrong since so many have installed this on STH10; so if you have STH10 with Aquaero 5, let me know what I am doing wrong.
theseekeroffun is going to help me tomorrow...In the mean time here's the issue.
It looks like Aquaero 5 (LT and XT) are approx. 148MM wide:
IMG_0033
And on STH10 case..can't get it to fit ...note left side in photograph - it's off by 1-2 mm...sigh
IMG_0031
Seanimus is offline
post #8 of 1388 (permalink) Old 08-27-2012, 04:27 PM
Lazy Bear's Avatar
Rep: 52 (Unique: 42)
Well subbed for sure, this looks exciting.
*Official ATi/AMD EyeFinity Club*|::The Official Northwest Overclockers' Club::|Haskell Basics: Ten Lesson Guide I <3 Mechanical Keyboards
FrozenQ Helix > Dual DDCs > EX240 > EK Dominator X4 > EK Supreme HF > EX120 > EK FC7970 > EK FC7970 > EX240 > FrozenQ Helix
My artsy fartsy builds! (Click to show)
Lazy Bear is offline
post #9 of 1388 (permalink) Old 08-27-2012, 07:27 PM - Thread Starter
Seanimus's Avatar
Posting pictures of new parts that arrived..
monsoon fittings:
IMG_0039
Aquacomputer Flowmeter USB:
IMG_0051
the top part of Blu Ray painted white:
IMG_0037
IMG_0038
turned out well...especially with Matte coating on that..it feels nice.
Updated first post with new dates for Aquacomputer D5 (9/6) and its adaptor (9/14) for Aqualis. This delay from Aquacomputer would put me out of reach for any RMA's with the entire NewEgg order.
Also getting new Powersupply from EVGA the Supernova....Lost like $100 in just restocking fees with 2 returns on PSU's ..sigh....But hey I am down to one PSU and it definitely seems better.
Seanimus is offline
post #10 of 1388 (permalink) Old 08-28-2012, 07:50 PM - Thread Starter
Seanimus's Avatar
Seanimus is offline
