[Build Log] Smokey Green Giant ~ Enermax Fulmo GT ~ Titan SLI - Page 2 - Overclock.net - An Overclocking Community
post #11 of 405 (permalink) Old 10-03-2012, 07:24 AM
Erakith's Avatar
Rep: 58 (Unique: 36)
Erakith is offline
post #12 of 405 (permalink) Old 10-03-2012, 07:39 AM - Thread Starter
hardware nerd
num1son's Avatar
Rep: 109 (Unique: 88)
Originally Posted by Fuganater View Post
Nice case. Please tell me your going to take out the mesh and add a window...
Thank you, and yes of course! That mesh is horrible isn't it? I do love though if you wanted and looks weren't a thing to you, you can put 4 180mm fans on the door. That's pretty epic.
Originally Posted by Kaged View Post
Thank you sir!
Originally Posted by airnews39 View Post
Thank you!
Originally Posted by Erakith View Post
Subbed. Go git 'er!
lol thank you!
num1son is offline
post #13 of 405 (permalink) Old 10-03-2012, 02:20 PM
MightyMaik's Avatar
Rep: 0
I did the math on how the case compares to my case and your phantom.
The Fulmo GT is 26% bigger than your old phantom, and 58% bigger than my Source 210!
Subbed for tri-sli and huge case.
MightyMaik is offline
post #14 of 405 (permalink) Old 10-03-2012, 04:15 PM - Thread Starter
hardware nerd
num1son's Avatar
num1son is offline
post #15 of 405 (permalink) Old 10-03-2012, 09:54 PM - Thread Starter
hardware nerd
num1son's Avatar
num1son is offline
post #16 of 405 (permalink) Old 10-04-2012, 08:43 AM - Thread Starter
hardware nerd
num1son's Avatar
num1son is offline
post #17 of 405 (permalink) Old 10-04-2012, 01:17 PM
Fuganater's Avatar
Rep: 68 (Unique: 54)
Very interesting.
Just a friendly suggestion... just post your new updates when you post them. Don't worry about going back and editing old post because it takes readers longer to get them. What you could do is make a list of updates with links to the post number at the beginning of the thread.
Fuganater is offline
post #18 of 405 (permalink) Old 10-04-2012, 11:58 PM - Thread Starter
hardware nerd
num1son's Avatar
Very interesting.
Yeah I was thinking that myself...
num1son is offline
post #19 of 405 (permalink) Old 10-04-2012, 11:59 PM - Thread Starter
hardware nerd
num1son's Avatar
Update 2!
Lot's of boring work in this one. Suprisingly this stuff took a long time to get done right.
Modified 5.25 bay
22Ga Sheet metal
Bottom cut made.
Test fitting, looks good. I had to cut this piece twice, the first time it was too big because I forgot it had to get through the opening.
Tracing out the CPU cut out.
Looks good and test fit perfectly.
Next I had to remove two pieces of steel. One being the top PSU support, the other this strip that was bent out at the edge of the old HDD cage.
The PSU support was not problem. The other long strip was such a pain. Ran out of dremel cut off disks rather quickly and had to use my Skill saw which totally sucked. Good thing this cut will be hidden! tongue.gif
Finally I have the back panel and a piece of L aluminum temporarily installed. Really starting to be able to see how it will come together!
num1son is offline
post #20 of 405 (permalink) Old 10-05-2012, 12:03 AM
Fuganater's Avatar
