[Build Log] Smokey Green Giant ~ Enermax Fulmo GT ~ Titan SLI - Page 39 - Overclock.net - An Overclocking Community
post #381 of 405 (permalink) Old 03-18-2013, 09:00 PM - Thread Starter
hardware nerd
num1son's Avatar
Rep: 109 (Unique: 88)
Originally Posted by wermad View Post
That was 3/8x1/2 so it was easy to bend straight. I am running now 3/8x5/8 (same thickness as 1/2x3/4) and it its not too hard to bend. a bit of heat applied by a heat gun/hair-dryer or dipping the piece in hot water will help softened it up. The spacing is enough to make it work.
Just make sure your cards are secured and then start cutting the tube. Its hard to get the exact length. Too long and it bends the cards pcb or too short and it might leak or pull. Compression fittings help a ton to secure it though.
Awesome! Now I have a plan, thanks Wermad. +1
num1son is offline
post #382 of 405 (permalink) Old 03-19-2013, 11:27 AM
WeAreMad! (yup, I'm back)
wermad's Avatar
Rep: 906 (Unique: 620)
Remember, that's a parallel setup so you'll need four compression fittings. You only need two for series smile.gif Personally, i prefer series for the maintained higher pressure.
"Rock Bottom Became The Solid Foundation On Which I Rebuilt My Life" J.K Rowling
Mont Blanc 2.0
(10 items)
Intel i7 6700K @ 4.5
Gigabyte GA-Z170X-Gaming G1
XFX 295x2 (Quad-fire)
G.skill Ripjaws 4 16GB (4x4GB) 2400
EVGA 1300G2
Corsair H105
Thermaltake View 71 (diy Snow Edition)
Operating System
Windows 10 Home
Keyboard
Razor Deathstalker Chroma
Mouse
Razor Deathadder Chroma Elite
wermad is offline
post #383 of 405 (permalink) Old 03-19-2013, 10:48 PM - Thread Starter
hardware nerd
num1son's Avatar
Yup I got my order in and will have it set up nicely in a few days. BTW guys please vote for me for MOTM at the end of the month! thumb.gif
num1son is offline
post #384 of 405 (permalink) Old 03-20-2013, 03:54 PM
Gamer
kgtuning's Avatar
Rep: 106 (Unique: 64)
Got my vote buddy!
mITX
(0 items)
kgtuning is offline
post #385 of 405 (permalink) Old 03-20-2013, 10:07 PM - Thread Starter
num1son is offline
post #386 of 405 (permalink) Old 03-31-2013, 04:31 PM - Thread Starter
hardware nerd
num1son's Avatar
Hey guys finally got the Titan upgrade finished all the way. Also decided to switch out the fans for black ones. I can finally say that this thing is done. Only using her from now on, I'm moving on to a new project! thumb.gif
Final photos:
Look at those cute little monsoons between the blocks! Love how this turned out. thumb.gif
Pretty proud of the wiring back here. It's about as clean of a back panel as I've ever done.
If I do anything it will be to try and work more lighting into it. There are some areas that could definitely be brighter. Not an easy thing to do and make it look good though.
num1son is offline
post #387 of 405 (permalink) Old 03-31-2013, 04:40 PM
Gamer
kgtuning's Avatar
friggin awesome! looks great. and the wiring on the back does look very clean. better then mine..lol
mITX
(0 items)
kgtuning is offline
post #388 of 405 (permalink) Old 03-31-2013, 04:49 PM - Thread Starter
hardware nerd
num1son's Avatar
num1son is offline
post #389 of 405 (permalink) Old 03-31-2013, 05:24 PM
Gamer
kgtuning's Avatar
Thanks man!
Oh and remember everyone voting starts tomorrow if you're a fan please vote!
MOTM March
Like I said before you got my vote.
mITX
(0 items)
kgtuning is offline
post #390 of 405 (permalink) Old 04-01-2013, 02:30 AM
kingchris's Avatar
Rep: 34 (Unique: 25)
Warning: Spoiler! (Click to show)
Final photos:
Does look good thumb.gif as for the fuzz on the panel try mr sheen polish.
kingchris is offline
