[Build Log] Mil-Spec - Page 11 - Overclock.net - An Overclocking Community
post #101 of 216 (permalink) Old 10-19-2012, 01:36 PM
TheHarvman313's Avatar
Rep: 12 (Unique: 10)
Originally Posted by CodofMC View Post
Wouldn't the AF series be better as intake fans than the SP series fans? I plan on one day watercooling my rig and I would for sure use the SP's for the radiator, but I was thinking the AF series fans would be better for just blowing the air over a larger area since I'll want them to blow cool air over as many components as possible.
Nothing saying you can't mix and match the AF and SP in your build. From some reviews that I've seen the AFs perform just as well as the SPs on thin radiators (i.e. H100, etc.).
TheHarvman313 is offline
post #102 of 216 (permalink) Old 10-19-2012, 01:51 PM
CodofMC's Avatar
Rep: 5 (Unique: 4)
What about a REALLY thin radiator, as in 25mm thin. My plans are to have the entire loop installed internally and I should just barely be able to fit a 25mm 240 rad with 2 120mm fans at the top of my HAF 912. And I was actually planning on mixing the fans. I'm thinking two AF series fans for intake and two SP series fans as exhaust on the radiator in push.
CodofMC is offline
post #103 of 216 (permalink) Old 10-19-2012, 01:54 PM
2 Easy
nyk20z3's Avatar
Rep: 70 (Unique: 52)
Stick to the SP fans for the rads.
I have a mix of both in my build and the SP's are best suited for the rads for sure.
nyk20z3 is offline
post #104 of 216 (permalink) Old 10-19-2012, 02:02 PM
CodofMC's Avatar
Rep: 5 (Unique: 4)
Okay, I was just making sure. I can't wait to see how everything looks with the pipe installed biggrin.gif
CodofMC is offline
post #105 of 216 (permalink) Old 10-24-2012, 07:09 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
The kit from XSPC has arrived! Got some rarities in here to!
An unpainted prototype EX 360!
4 EX 120s of various colours!
A D5 bay and 2 normal bays!
Lets have a closer look shall we...
The evergreen XSPC bay res,staple of many builds.
The prototype 360,painted tanks and polished sides i think for this if i can squeeze it in.
The guys at XSPC did ask what colours i wanted,i said i didnt mind as they would be painted anyway.
So he sent a mix of unseen colours.
The D5 res i will be using if i can get a cheap pump.
A lot of kit for sure!
Once the fittings arrive,its all systems go!!
This custom loop wouldnt of got off the ground without the great team at XSPC.
I will try to do you proud!
images?q=tbn:ANd9GcSiAhp8uy1eOoBoiQFhw6ybLaQfbZ9MLs3rxaRJHBUdI_FVT_iVgw
B NEGATIVE is offline
post #106 of 216 (permalink) Old 10-24-2012, 07:15 AM
Davayy's Avatar
Rep: 81 (Unique: 69)
Davayy is offline
post #107 of 216 (permalink) Old 10-24-2012, 07:20 AM
Fuganater's Avatar
Rep: 68 (Unique: 54)
Fuganater is offline
post #108 of 216 (permalink) Old 10-24-2012, 10:12 AM
Hanoverfist's Avatar
Rep: 190 (Unique: 113)
Just Browsing through some of the High Res Shots. Awesome Detail.. Congrats on this Build. It is Stunning.. thumb.gif
Hanoverfist is offline
post #109 of 216 (permalink) Old 10-25-2012, 05:32 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Started on the front cover panel,got it roughed out ready for prep and paint.
Gloss black with some yellow detailing is the look for this piece
post #110 of 216 (permalink) Old 10-25-2012, 05:45 AM
Fuganater's Avatar
