[Build Log] Hydra - Overclock.net - An Overclocking Community
View Poll Results: What ya think?
Good setup! 40 54.79%
dude you crazy!? 16 21.92%
Requires modifications 9 12.33%
Bad! 5 6.85%
TL;DR 3 4.11%
Voters: 73. You may not vote on this poll
[Build Log] Hydra
post #1 of 250 (permalink) Old 11-08-2012, 11:01 AM - Thread Starter
Intel Pariah
King4x4's Avatar
Rep: 98 (Unique: 75)
Hydra
I have been meaning to join the WC bandwagon for a very long time and I just decided to pull the trigger.
Some background info, I am a mechanical engineer who specializes in pumps specficialy centrifugal pumps hailing from Saudi Arabia (the weather is hot and don't go there they are too crazy).
The build is named like this since it's a three card setup and three rads with three screens... what better then to name it after a mythical dragon with three heads?! Also the theme of the hardware will be green and red!
My current build is as follows:
Silverstone TJ10-ESA
Intel Core i7 970 @4.2Ghz on Noctua NH-C14
Samsung DDR3 24GB
2xGigabyte 7950 GDDR5 3GB Crossfire
OCZ Revodrive X2 160GB
Yamakasi Catleap
The system is very nice and decent but coming from an eyefinity 23in system I wanted to have eyefinity back... Tried putting the 7950s next to each other to get a feel of the noise level if I wanted to trifire them... lets just say on stock they are decent... but when OCed they scream like banshees!
Now think about it if I added a third... or even a fourth... Not very nice indeed!
So went and just said... screwed time to fork out the cash!
Non-WC Order list:
2x Archiva Shimian (From Dream-seller from Ebay) (Arrived)
2x Active Displayport to Dvi Adapters (Cino_tech from Ebay) (Arrived)
1x Gigabyte 7950 (From Amazon) (Arrived)
1x Danger Den Double Wide Tower (From a local user) (Arrived)
Additions non-planned (X58 had compatibility issues with Trifire 7950s)
1x Gigabyte Z77 Sniper 3 (Bought Locally)
1x Intel 3770k (Bought Locally)
Most of my WC gear I ordered from FrozenCpu and they are as follows: [UAll of it arrived!![/U]
1x EK Supremacy Universal CPU Liquid Cooling Block - Full Nickel (EK-Supremacy - Full Nickel)
3x EK Radeon VGA I/O Bracket - HD7950 / HD7970 (EK-VGA I/O bracket HD7970)
3x EK Radeon HD 7950 VGA Liquid Cooling Block - Acetal + Electroless Nickel Plated (EK-FC7950 - Acetal+EN (Nickel))
1x AeroCool Touch-2100 5-Channel 25W Fan Controller w/ USB 3.0 - Black
1x Swiftech Maelstrom 5 1/4" Dual Bay Standalone Reservoir w/ Dual MCP35X Pumps (Maelstrom-35X2)
3x XSPC RX360 Triple 120mm Radiator Rev 2.
12x Yate Loon Clear 120mm x 25mm Red LED Fan - Medium Speed (D12SM-12)
6x Bitspower G 1/4" Thread 45 Degree Rotary 1/2" Barb Fitting (BP-BS45R2I)
10x Koolance G1/4 Swivel 90° Angled Barb w/ Clamp (13mm / 1/2" ID) - Single - (NZL-L13B)
12x Bitspower Black Sparkle G1/4" Barb Fitting - 1/2" ID (BP-BSWP-C01)
3x Bitspower UV Reactive Purple O-Ring (10 Pack)
3x Danger Den DreamFlex Value Pack - Tubing / Clamps / Tube Cutter ( 1/2"ID x 3/4"OD ) - UV Red
1x Danger Den Premium Delrin Tubing Clamps - 3/4" OD - Black (10 Pack)
3x IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
4x Enzotech G1/4" Barb Stop Fitting w/ Cap - 1/2" ID - Nickel Plate (Metallic Silver) (NPH-ID1/2-G14)
4x Bitspower Silver Shining Sealing Plug For ID 1/2" Tube (BP-WTP-C31)
4x Alphacool G1/4 45° Rotary Fitting Adapter - Chrome
4x Bitspower G1/4" Silver Shining Rotary 45 Degree G1/4" Adapter (BP-45R)
2x Bitspower G1/4" Mini Valve - Silver Shining (BP-MVV-SL)
4x XSPC G1/4 Male to Male Extender - 5mm - Chrome
4x XSPC G1/4 Female to Female Extender - 18mm - Black Chrome
4x Alphacool G1/4 Male to Male Rotary Extender - Chrome
7x Akasa Flexa FP5 PWM 5-Way Splitter - Smart Fan Cable (AK-CBFA03-45)
2x Alphacool G1/4 High Flow Y Connector 45° - Chrome
2x XSPC M20 to G1/4" Fillport - Black Chrome
2x Koolance 13mm, 1/2" Panel Mount Nozzle - Single - G1/4" Thread (NZL-V13BXG-P)
2x Danger Den Premium Delrin Tubing Clamps - 3/4" OD - UV Blue (10 Pack)
2x Koolance INS-FLTR01 Inline Coolant Filter
PrimoChill Anti-Kink Coils - 3/4" OD Tubing - Purple
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 2.5
Build Log: Hydra 3
Build Log: Mini-Hydra
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
Intel i7 3930k @[email protected]
Asrock X79 Fataility Champion
3xInno3d GTX 780 with Full Nickel EK Waterblocks
Gskill RipjawsX [email protected] 11-11-11-31
2xSamsung 830 256gb
Seasonic 1250 watt
Custom H2O - 3x XSPC RX360 with EK Blocks
Danger Den Double Wide 21
Surround Gaming [email protected] (X-Star)
Keyboard
Cooler Master Trigger Red Caps
Mouse
Roccat Kone+
Audio
Roccat Kave 5.1 Headphones
Audio
Creative ZX (Incoming)
4930k
Asus Extreme Black Edition
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Gskil TridentX 2400mhz
Samsung 830 256GB
Samsung 840 500GB
2x Seasonic 1250watt
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
BenQ 3201 32in 4k IPS
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Coolermaster Storm Trigger
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
Gigabyte Aorus Ultra
EVGA 1080 Ti
EVGA 1080 Ti
Ballistix Sport LT 32GB
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #2 of 250 (permalink) Old 11-08-2012, 11:05 AM - Thread Starter
Intel Pariah
King4x4's Avatar
Pics of most of the stuff that already arrived:
The route the screens took to arrive... talk about detours!
Comparsion between the old Active DP that only works on 1080p and the new one that supports 1440p
The screens after setup:
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #3 of 250 (permalink) Old 11-08-2012, 11:05 AM - Thread Starter
Intel Pariah
King4x4's Avatar
Reserved for WC setup
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #4 of 250 (permalink) Old 11-08-2012, 11:05 AM - Thread Starter
Intel Pariah
King4x4's Avatar
Issues log:
Had a massive problem of continuous crashes when I installed the third 7950 and enabled eyefinity. Every 2 mins after launching a game it would crash.
Said what the hell lets go and upgrade the whole system from X58 to X79 and have the parts ready before the WC gear arrive... went out and got myself this:
Park it next to my desk and open the overlock.net forums and found a topic regarding quadfire 7970s and X79 chipsets... check the RoG forums... and vola a huge thread with compatibility issues regarding the 7000 series and intel chipsets X58 and X79 in general regardless of the mobo maker.
To say the least I wasn't pleased but if you look on the bright side... it's no loss since everything still in it's boxes and just short drive to the shop. Replaced them both for a 3770k and a Gigabyte Sniper 3.
Updated 11/9/2012:
One of the Shimians just died on me with no reason what so ever. Tried to get it up and running and no chance what so ever. Put it in a request for the seller to return it.
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #5 of 250 (permalink) Old 11-09-2012, 07:12 PM - Thread Starter
Intel Pariah
King4x4's Avatar
Water Cooling Kit just arrived in dubai... soon soon!
Edit: Arrived!
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #6 of 250 (permalink) Old 11-13-2012, 12:36 AM - Thread Starter
Intel Pariah
King4x4's Avatar
Just Finished deliding the 3770k... talk about stress!
Nicked the PCB a bit though..
Booted though!
Also started work on changing the coolers on the GPUs
Plan is take my sweet time and get it right the first time.
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #7 of 250 (permalink) Old 11-15-2012, 05:30 AM - Thread Starter
Intel Pariah
King4x4's Avatar
Just started assembling the system:
Sent from my GT-I9300 using Tapatalk 2
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #8 of 250 (permalink) Old 11-16-2012, 10:42 AM - Thread Starter
Intel Pariah
King4x4's Avatar
The Danger Den Double Wide is a pain to assemble... but at least it is done!
The moment of truth!
It's alive!
Hickups encountered:
1. Cable management is a pain. Need some advice there lads!
2. Aerocool controller failed big time on the pump. Can't control it.
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #9 of 250 (permalink) Old 11-16-2012, 12:45 PM
Rep: 9 (Unique: 8)
Very nice! Wanna trade!drool.giftonguesmiley.giflaughingsmiley.gif As for the cable management I would plan out or at least try to visualize the route you want to take. Then try it before you sleeve your cables in case you have to or want to lengthen/shorten any. I used black zip-ties on black para-cord, but something like what you have I would try to find a nicer method. As for the controller, I haven't got a clue about that. Maybe post in the wc'ing section and someone might be of help to you.
 Anyways keep this thing updated, It is one of the nicest looking cases I have seen from DD imo!
beezweeky is offline
post #10 of 250 (permalink) Old 11-16-2012, 03:29 PM - Thread Starter
Intel Pariah
King4x4's Avatar
Yup thinking of going it slow on the cabling and just let everything dangle for now.
Don't have kids so no worries... YET!
Just for a quick overclock... Ivy is so much easier then Nehlem in OCing!
HELLO 5GHZ!
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 3
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
2xSamsung 830 256gb
Seasonic 1250 watt
Keyboard
Mouse
Roccat Kone+
Audio
Audio
4930k
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Samsung 830 256GB
Samsung 840 500GB
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
EVGA 1080 Ti
EVGA 1080 Ti
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
