[Build log] Clementine - a tasty Bitfenix Prodigy - Page 2 - Overclock.net - An Overclocking Community
post #11 of 119 (permalink) Old 11-14-2012, 09:41 PM - Thread Starter
charleybwoy's Avatar
Rep: 19 (Unique: 18)
Originally Posted by jsocontrer01 View Post
Awesome paint job...can you elaborate more on your painting process? I am interested in painting my case and would like to some tips.
Hello jsocontrer01! Welcome on OCN and Thanks for your comment!
The paint is actually a powder paint.
Powder coating is a type of coating that is applied as a free-flowing, dry powder. The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is typically applied electrostatically and is then cured under heat to allow it to flow and form a "skin". The powder may be a thermoplastic or a thermoset polymer. It is usually used to create a hard finish that is tougher than conventional paint. From wiki
The process on my prodigy is rather simple
First, Parts has been thoroughly cleaned. This is done utilizing liquid degreasers & cleaning solutions. Once everything has been Sand Blasted, Parts will then be Steam cleaned and Phosphated.
After that it is the conventional process and the oven, etc.
If you chose to go this route, which i suggest as the result is amazing, you should be aware of couple things. Powdercoating is thicker than liquid paint so you might have trouble reassembling your case,. You need to ''plug'' the hole, What hole? Every hole you dont want to be filled by powder. Also you cant powdercoat plastic due to the heating process. Anyway i think i covered the base but if you have any question, feel free to let me know and i will try to answer with the best of my knowledge!
charleybwoy is offline
post #12 of 119 (permalink) Old 11-15-2012, 05:45 AM
jsocontrer01's Avatar
Rep: 0
Thanks you so much for the process and the welcome. I am a newb to the whole process and I think the the prodigy is an awesome case for my first build. I am an Apple guy who now wants to and needs to switch to PC. I look forward to seeing more of your build.
Cheers!
jsocontrer01 is offline
post #13 of 119 (permalink) Old 11-15-2012, 09:58 AM
Hanoverfist's Avatar
Rep: 190 (Unique: 113)
Hanoverfist is offline
post #14 of 119 (permalink) Old 11-15-2012, 12:08 PM - Thread Starter
Cheers!
You are welcome! If you are planning to build in a Prodigy, i suggest you check this thread: Bitfenix Prodigy Owner's Club, you will find many information.
Originally Posted by Hanoverfist View Post
Thank you for your comment Hanoverfist biggrin.gif Yes the paint came very nice honestly! I hope my build will turn as good as your Electric Orange :3
post #15 of 119 (permalink) Old 11-15-2012, 03:36 PM - Thread Starter
Couple pictures of the motherboard, which is a Zotac Z68 mITX
I think its a pretty solid board with good features. NCIX.ca is actually selling them for 112.80$ (Its a 53$ instant rebate)
If you have any question about the board, feel free to ask and i will try to answer as soon as possible! Thanks for watching.
post #16 of 119 (permalink) Old 11-15-2012, 11:54 PM
Editor22's Avatar
Rep: 66 (Unique: 40)
Damn Charley that paint job is stunning! should look awesome once it starts to get filled biggrin.gif
Project Log: Evolution | K2 | 21
Editor22 is offline
post #17 of 119 (permalink) Old 11-16-2012, 12:54 AM - Thread Starter
Thanks Editor22! I really think it'll look great so stay tuned!
For now, here's couple pictures of the ram i will probably be using for the build. It's an AVEXIR Core 8GB DDR3-1600 CL9 Memory Kit.
This is a Kit i previously reviewed and let me tell you its a pretty piece of hardware. If you want to read my review you can do it here
Heres a video of them in action!
If you have any question concerning the ram, just comment it below and i should be able to answer you!
Thanks for watching and don't forget to tell me what you think so far!
post #18 of 119 (permalink) Old 11-16-2012, 02:51 AM
Mosha's Avatar
Rep: 1 (Unique: 1)
Thanks for the PM mate, this is by far my favourite painted prodigy. Great Job. Sub'd
Mosha is offline
post #19 of 119 (permalink) Old 11-16-2012, 11:24 AM - Thread Starter
Thank you Mosha! Your comment is very appreciated. Stay tuned, much more coming soon! biggrin.gif
post #20 of 119 (permalink) Old 11-16-2012, 11:29 AM
Eh?
zoid.srg's Avatar
Rep: 42 (Unique: 42)
zoid.srg is offline
