cosmos s case and corsair h100i - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 12-22-2012, 10:24 AM - Thread Starter
coatsy101's Avatar
Rep: 0
can anyone confirm that the h100i will fit in the case or the fan bay on the top of the case ive been searching all over for confirmation and cant find the answer biggrin.gif
thanks in advance
lee
coatsy101 is offline
post #2 of 7 (permalink) Old 12-22-2012, 10:38 AM
AcLion's Avatar
Rep: 0
Yep, it should fit in the top.
AcLion is offline
post #3 of 7 (permalink) Old 12-22-2012, 10:49 AM
STG3 VET
Juggalo23451's Avatar
Rep: 1174 (Unique: 756)
yes it will fit with no problem
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><p><a href="https://www.overclock.net/water-cooling/913181-water-cooling-guide-noobs.html#post11984918">Water cooling guide for noobs,parts,setup install case suggestions,etc</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/962044-upgrade-time-update-2-3-18-a.html">Case labs TH10/ build log (2 gtx 590s) water cooling oh my</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/528648-heatkiller-club.html">Founder of the Heatkiller Club</a></p><span></span><p><span>W</span><a href="https://www.overclock.net/water-cooling/601449-water-cooling-cases.html">ater cooling case suggestions</a></p></div></div>
Juggalo23451 is offline
post #4 of 7 (permalink) Old 12-22-2012, 10:53 AM - Thread Starter
coatsy101's Avatar
Rep: 0
post #5 of 7 (permalink) Old 12-22-2012, 12:04 PM
gdesmo's Avatar
Rep: 71 (Unique: 64)
Will easily fit, approx 3 inches from top of mobo to top of case. With the H100 you could go push-pull with 2 fans in case and 2 on top, you would get some nice low temps then. thumb.gif
:True De-Lidder not Re-Lidder ! Processor dies can run naked. Show your TEC`s some love !!!
gdesmo is offline
post #6 of 7 (permalink) Old 12-22-2012, 12:20 PM - Thread Starter
coatsy101's Avatar
Rep: 0
Never fitted a water cooler before is it easy? Since this a sealed unit? Already been advised on my pc build on another part of the forum so gonna by it hoping for sales on scan in Jan would u fit in side on the ceiling of the case or in the fan bay on the top?
post #7 of 7 (permalink) Old 12-22-2012, 01:20 PM
gdesmo's Avatar
Inside on the top and it is a really easy install. Follow the instructions carefully and make sure that you install the retention system first before putting mobo into case. smile.gifthumb.gif
gdesmo is offline
