Loop Review (Now moved to 900D) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 73 (permalink) Old 02-06-2013, 02:07 PM
Rep: 963 (Unique: 708)
id Look and see what you can order from jab-tech they have much better prices the pump and res would be 35 cheaper alone.
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
ASUS AMD AM4 ROG Strix X570-E
EVGA GTX 1080 FTW Hydro Copper
G.SKILL TridentZ Series
Samsung EVO 850 500
SeaSonic M12D SS-850 850W
EK-SBAY Dual DDC 3.2 PWM Serial
Alphacool NexXxoS ST30 Full Copper Radiator 360
Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
EKWB EK-Velocity Strike CPU
EK-CoolStream RAD XTC 420
Thermaltake core x71
Operating System
Windows 10 Pro
ASUS VW246H Black 24" 2ms
Keyboard
Rosewill NEON K75 V2 BR
Mouse
CM Storm Sentinel Advance II
Audio
Corsair Void
Bal3Wolf is offline
post #12 of 73 (permalink) Old 02-06-2013, 04:45 PM
nleksan's Avatar
Rep: 660 (Unique: 521)
For that loop, I would ABSOLUTELY go with an MCP35X!!! Pressure > Flow when you have that many components, and an MCP35X will be able to continue to keep adequate flow in a loop where you'd have to use 2 D5's....
"The world breaks everyone and afterward many are strong at the broken places"Ernest Hemingway
~*~ THE TAO OF BACKUP ~*~
PLEASE DOUBLE-CHECK ANY ANSWERS I MAY PROVIDE, AS I AM HUMAN AND QUITE FALLIBLE
Warning: Spoiler! (Click to show)
Samsung Galaxy Nexus - Rooted & Running JBSourcery FINAL & LeanKernel Experimental
nleksan is offline
post #13 of 73 (permalink) Old 02-06-2013, 04:52 PM
He does not need 2 d5 pumps for that hes using a bridge for the cards so makes it easyer my loop is almost identical other then i have 1 less card but i have block thats very resrictive and i have 0 problems and great temps.
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
Samsung EVO 850 500
Operating System
Windows 10 Pro
Keyboard
Mouse
Audio
Corsair Void
Bal3Wolf is offline
post #14 of 73 (permalink) Old 02-06-2013, 04:54 PM
Jakusonfire's Avatar
Rep: 552 (Unique: 388)
Drop the Supreme LTX and get a proper Supremacy block
Edit: and where is that list coming from? It seems to be rather expensive.
Jakusonfire is offline
post #15 of 73 (permalink) Old 02-06-2013, 05:34 PM - Thread Starter
Computer Art
Jameswalt1's Avatar
Rep: 305 (Unique: 207)
Frozen cpu. I'm changing to the supremacy block, I selected the supreme ltx by mistake. I'll look into the mcp35x perhaps I suppose. I'll be placing the order tonight. Any feedback on the quick disconnect vs the bitspower valve?
post-flame-small.gifTEARS IN RAIN A Blade Runner inspired build (2017)post-flame-small.gif
post-flame-small.gifPARVUM WARFARE An Advanced Warfare themed build (2014)post-flame-small.gif
post-flame-small.gifPARVUM TITANFALL A Titanfall themed build (2014)post-flame-small.gif
post-flame-small.gifROBOCOP A Robocop themed 900D build (2013/14)post-flame-small.gif
Jameswalt1 is offline
post #16 of 73 (permalink) Old 02-06-2013, 07:51 PM
nleksan's Avatar
I didn't mean to say that he needs 2x D5s, simply that when it comes to pumps, a single MCP35X will go further than a ssingle D5.
nleksan is offline
post #17 of 73 (permalink) Old 02-06-2013, 08:10 PM
Sean W.'s Avatar
Rep: 118 (Unique: 108)
Crazy talk.
A vari mcp655 is quieter and has more pressure
T-mobile OnePlus 7 Pro
2014 Tesla Model S
2006 Suzuki GSXR-600
Sean W. is offline
post #18 of 73 (permalink) Old 02-06-2013, 08:52 PM
People should really be sure about stuff when they make posts like that. The 35X produces Around 6.5PSI at 1 GPM flow and the D5 produces around 4.5PSI at the same flow.
Having said that the EK GPU blocks are usually the highest flow / least restrictive blocks available so I would not be worried about using a D5.
I would rather have a D5 every time for their quietness
post #19 of 73 (permalink) Old 02-06-2013, 09:43 PM
nleksan's Avatar
Thank you, Jakusonfire, I was looking for that graph!
nleksan is offline
post #20 of 73 (permalink) Old 02-06-2013, 10:33 PM
Rep: 127 (Unique: 114)
... except those aren't his components...
A single D5 yields 4.5 psi at 1gpm when running at a full 12v.
Each video card drops pressure by 1.1psi at 1gpm. That leaves 1.2psi in 3xseries.
The CPU block drops pressure by 1.8psi at 1gpm.
Now you're at -0.6psi and still have to account for radiators, tubing, fittings, etc. That means running full out at 12v, you won't get 1gpm out of a single D5. You'll either want to get two D5s in series (which you can then run both at a lower speed), or go for an MCP35X. Otherwise, you could put your video cards in parallel; but that means that each one will only get 1/3 of the flow.
You could, of course, just keep it as-is and run a single D5 on max 24/7 and be content with somewhere around 0.7-0.8gpm too.
Electrocutor is offline
