[Build Log] The Acrylic Dragon - Overclock.net - An Overclocking Community
post #1 of 224 (permalink) Old 02-09-2013, 02:03 PM - Thread Starter
Rep: 81 (Unique: 67)
^GaMbi's Build Log - The Acrylic Dragon.
Hello fellow Overclockers!
This is a build log I created to better be able to view and show off my PC project.
It is my first water-cooled PC and most (if not all) the mods are first time as well.
You can explore most of the finished build right here on the OP and second post, but I encourage you to check out the log! loads of info and pictures of the process!
Use the links below to jump between the different stages of the build.
The Build Log includes:
Part 1. Case and Water Cooling. [ ]
Part 2. New PC Hardware. [ ]
Part 3. Delidding. [ ]
Part 4. Window mod. [ ]
Part 5. 1080 Radiator. [ ]
Part 6. DIY Back Plate. [ ]
Part 7. Acrylic Tubing. [ ]
Part 8. Costume Sleeving. [ ]
Enjoy!
Current state:
Original Case
Modded case.
And here is a short video view of the box:
Any comments are much obliged!
GaMbi2004 is offline
post #2 of 224 (permalink) Old 02-11-2013, 08:35 AM - Thread Starter
Pictures of the Finished Build.
post #3 of 224 (permalink) Old 02-13-2013, 05:47 PM - Thread Starter
Part 1. Case + W/C:
Cabinet:
CoolerMaster HAF XB
CPU block:
Swiftech Apogee HD
GPU block:
XSPC RayStorm GPU
(Later upgraded to: XSPC Razor GTX680)
Pump:
Swiftech MCP655
Reservoir:
Alphacool Cape Corp Coolplex Pro 10 LT
(Later upgraded to: Phobya Balancer 150 black matt)
Radiators:
HW-Labs Black Ice - GTX 280 - Black
(Later "downgraded" to: HW-Labs Black Ice - GTS 240 - Black)
HW-Labs Black Ice - GTS Lite 120 - Black
(A normal 120mm rad wont fit Acorting to a CM HAF XB review I read, so I had to go "Lite")
Coolant:
EK - Ekoolant - UV Blue / CLEAR - 1L (premixed)
(Later changed to distilled water + adjectives, both solutions seamed to form particles in the water,
Im currently running cheap distilled water + silver kill coil - 100% clean)
Tube:
XSPC High Flex - 1/2'' X 3/4'' - UV-Blue
(Later changed to XSPC High Flex - 1/2'' X 3/4'' - Black
Currently, Monsoon Hardline Tube 3/8'' X 1/2'')
Fittings:
Monsoon - Compression - 1/2'' X 3/4'' - Blue
(Later changed to Red
Currently, Monsoon Chain Gun Hardline Compression Fittings, 3/8" x 1/2" - Red)
Fans:
2x140 BitFenix Spectre PRO LED - Blue
1x120 BitFenix Spectre PRO LED - Blue
(Later upgraded to 3x120 Noctua NF-F12 PWM 120mm)
The Hardware.
Planing etc.
Pump and res locations found
Clear case and cable management
This is how much tube I had left ;D petty lucky, LoL!
Starting to look finished tongue.gif trying to get all the small bubbles out zZz, low/high speed, shaking the case, tapping the tubes
I guess this just takes time smile.gif maybe it will help to turn it off over the night smile.gif getting pretty late anyways biggrin.gif
All in all, I think I got off to a good start on this project!
post #4 of 224 (permalink) Old 02-14-2013, 07:44 AM - Thread Starter
Here is the final look (I think)
With Flash/Without Flash
Here is some info on my old temps vs. my new
COOLER MASTER Hyper 212 Plus
ARCTIC COOLING Accelero Xtreme GTX Pro
(the stock cooler easily got to 80-90 degrees AT STOCK clock :O )
CPU Air Cooled [email protected]
Idle: 36, Full load: 70
CPU Water Cooled [email protected]
Idle: 26 Full load: 50
GPU Air Cooled [email protected]
Idle: 41, Full load: 67
GPU Water Cooled [email protected]
Idle: 33, Full load: 45
Now THAT is what I like to see!
Just ordered a Fan Controller, hoping to bring down the noise a tat and still keep some good cooling scores.
Edit:
Upgrade from old Old INCREDIBLE OLD Logitech Media keyboard (yes.. that is its actual name biggrin.gif )
and a Func from before they "died" with burn marks and all in all worn out, mouse mat
To: Logitech G710+, the new Func Surface 1030 XL and ofc new gliders for my G5 Mouse tongue.gif
GaMbi.
post #5 of 224 (permalink) Old 02-14-2013, 05:52 PM
Quasimojo's Avatar
Rep: 35 (Unique: 34)
I'm surprised you haven't gotten any feedback on this. There's certainly no shortage of expertise around here. I'm pretty new to the notion of water cooling, myself, so I appreciate all the photos and build progress. I think, like you, I'm still trying to figure out how to "join the party" in this particular forum, as my initial post for feedback/suggestions didn't generate much interest, either.
Looks like a really clean build. I love the case.
"You might be a king, or a little street-sweeper,
But sooner or later, you dance with the Reaper."
-- Grim Reaper, Bill and Ted's Bogus Journey
Quasimojo is offline
post #6 of 224 (permalink) Old 02-14-2013, 06:13 PM - Thread Starter
Thx Quasimojo!
tbh I'm a bit surprised about the feedback myself smile.gif maybe I picked the wrong headline, ey? tongue.gif
post #7 of 224 (permalink) Old 02-14-2013, 09:01 PM
Linux Lobbyist
BadDad62's Avatar
Rep: 80 (Unique: 66)
BadDad62 is offline
post #8 of 224 (permalink) Old 02-14-2013, 09:45 PM
Killa Cam's Avatar
Rep: 73 (Unique: 72)
awesome build! btw, how old was that keyboard?
Killa Cam is offline
post #9 of 224 (permalink) Old 02-14-2013, 09:50 PM
chann3l's Avatar
Rep: 24 (Unique: 12)
Looking good there. Tip to get the bubbles out try tilting your whole case in all directions and be careful to watch that the water doesn't come over the top of the res lol. have the res about half full so you have a bit of give on the titling
chann3l is offline
post #10 of 224 (permalink) Old 02-15-2013, 10:05 AM - Thread Starter
Thx all!
Hmm thinking.gif .. I actually don't remember.. I had to order a replacement from Ebay a few years back cause they weren't being manufactured any more tongue.gif
