Thermaltake Bigwater 760i water cooling kit quetions - Page 2 - Overclock.net - An Overclocking Community
post #11 of 33 (permalink) Old 02-11-2013, 06:42 AM - Thread Starter
skitz9417's Avatar
Rep: 20 (Unique: 20)
ok so all my parts that i have listed are all good for a cpu loop
skitz9417 is offline
post #12 of 33 (permalink) Old 02-11-2013, 06:49 AM
morencyam's Avatar
Rep: 277 (Unique: 203)
Yes, that looks good. I'm pretty sure that reservoir doesn't come with a pump though, so you would need to ad that.
EDIT:
*Images provided are pre-production - actual product may vary. Pump not included.
You need to add a D5 pump to that list then you are good to go.
Never attribute to malice that which is adequately explained by stupidity
morencyam is offline
post #13 of 33 (permalink) Old 02-11-2013, 06:51 AM - Thread Starter
skitz9417's Avatar
EDIT:
its says it does http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_299&products_id=14352
post #14 of 33 (permalink) Old 02-11-2013, 06:55 AM
morencyam's Avatar
Directly under the picture it says "pump not included" and a says nothing about including a pump in the description. It only says "for use with D5"
post #15 of 33 (permalink) Old 02-11-2013, 06:58 AM - Thread Starter
skitz9417's Avatar
post #16 of 33 (permalink) Old 02-11-2013, 07:04 AM
morencyam's Avatar
Personally, I think that looks cheap and low quality. I'd go with something like this instead http://www.pccasegear.com/index.php?main_page=index&cPath=207_160_296
I know it's a little bit more expensive, but it's a better pump and would be more reliable.
post #17 of 33 (permalink) Old 02-11-2013, 07:15 AM - Thread Starter
skitz9417's Avatar
the link didnt work
post #18 of 33 (permalink) Old 02-11-2013, 07:16 AM
morencyam's Avatar
Hmm... That's odd. Try this http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_296&products_id=21957
post #19 of 33 (permalink) Old 02-11-2013, 07:26 AM - Thread Starter
skitz9417's Avatar
ok the link worked and what kind of clear coolant should i use
post #20 of 33 (permalink) Old 02-11-2013, 07:34 AM
morencyam's Avatar
I'd just stick with distilled water and either a concentrated additive, like PT Nuke or I&H Deadwater, or a silver kill coil.
Either of these would work
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_301&products_id=19311
OR
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_301&products_id=21444
I like kill coils better since they can be reused over and over again. Whereas with the additive, you'd either have to save the fluid you drain to reuse, or you have to buy more to use with new water
