Thermaltake Bigwater 760i water cooling kit quetions - Page 3 - Overclock.net - An Overclocking Community
post #21 of 33 (permalink) Old 02-11-2013, 07:41 AM - Thread Starter
skitz9417's Avatar
Rep: 20 (Unique: 20)
skitz9417 is offline
post #22 of 33 (permalink) Old 02-11-2013, 07:57 AM
morencyam's Avatar
Rep: 277 (Unique: 203)
It's a decent kit. My only issue with it is the pump again.
If you're trying to save money and don't plan on watercooling anything other than CPU later on, I'd just go with an AIO unit. I'd go with a Corsair H80i, or something similar. It would offer similar temps as the kit you linked, and completely maintenance free, other than blowing dust out of the radiator every once in a while.
Never attribute to malice that which is adequately explained by stupidity
morencyam is offline
post #23 of 33 (permalink) Old 02-11-2013, 07:59 AM - Thread Starter
skitz9417's Avatar
well i have a h60 now so u think i should keep it and change the fans to helix fans
post #24 of 33 (permalink) Old 02-11-2013, 08:01 AM
morencyam's Avatar
I would try that before spending the money on a custom loop. If you really want to build a custom loop, I'd recommend a new case that can fit more than just a single 120mm radiator before anything else
post #25 of 33 (permalink) Old 02-11-2013, 08:07 AM - Thread Starter
skitz9417's Avatar
ok i will just that frist ok thanks and whats a better cheap case i can change to
post #26 of 33 (permalink) Old 02-11-2013, 08:16 AM
morencyam's Avatar
The NXZT Phantom and Switch get a lot of good publicity here. Fractal Design is gaining popularity as well, but can be a little pricey. The Corsair cases are really nice, I have a 700D now a love it. Coolermaster's HAF line, specifically the 922, 932, and HAF X, are all pretty good watercooling cases.
post #27 of 33 (permalink) Old 02-11-2013, 08:27 AM - Thread Starter
skitz9417's Avatar
well i was going to mod this case anyway and cut 2x120mm holes at the top of the case
post #28 of 33 (permalink) Old 02-11-2013, 08:31 AM
morencyam's Avatar
That is another option. If you do, that would eliminate the need for a new case. Then a good 240 radiator with good fans would give you better temps than the h60 does. Depending on how much space you would have, an EX240 with push-pull fans would be a good option.
post #29 of 33 (permalink) Old 02-11-2013, 08:33 AM - Thread Starter
skitz9417's Avatar
post #30 of 33 (permalink) Old 02-11-2013, 08:38 AM
morencyam's Avatar
It might require some modding, but I think it would be easier to work with than your current case
