GPU backplate? - Overclock.net - An Overclocking Community
GPU backplate?
post #1 of 12 (permalink) Old 02-11-2013, 09:56 AM - Thread Starter
CNCoRIDDoR's Avatar
Rep: 3 (Unique: 3)
Does the black plate help with cooling or is it just for looks?
CNCoRIDDoR is offline
post #2 of 12 (permalink) Old 02-11-2013, 10:00 AM
chowtyme2's Avatar
Rep: 10 (Unique: 9)
EVGA Claims
Helps reinforce the PCB, protects critical components and best of all, looks awesome!
chowtyme2 is offline
post #3 of 12 (permalink) Old 02-11-2013, 10:02 AM
AaronO's Avatar
Rep: 4 (Unique: 4)
Backplates don't help the cooling performance, but besides looking cool, they also increase the strength/rigidity of the card making it less prone to bending/warping. If you are thinking of getting one, i would get in contact with Dwood here on OCN. he can make you a nice and affordable custom one.
www.overclock.net/t/1237219/tript-cc-620-920-h50-h70-gpu-brackets-fan-grills-custom-case-badges/
~Aaron
AaronO is offline
post #4 of 12 (permalink) Old 02-11-2013, 10:06 AM
francisw19's Avatar
Rep: 182 (Unique: 158)
I got the EVGA backplate for my GTX670's and it didn't do anything for temps. I mostly got it for looks and to protect the back-side of the PCB since there are lots of little chips on there. smile.gif
Intel Core i7 8700K
Asus Maximus X Hero WiFi-AC
Asus GTX1080 Strix
Corsair Vengeance LPX DDR4-2666 32GB
Samsung 970 Pro 512 GB
Western Digital Black 4 TB
Samsung 860 Pro 512 GB
EVGA 750 G3
Noctua NH-D15 (Chromax)
Fractal Design Define R6 w/ Tempered Glass
Operating System
Windows 10
Dell UltraSharp U2515H
Keyboard
Ducky One 2 RGB TKL (MX Brown, PBT)
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G440
Audio
Audio Technica ATH-M50x
Audio
Kanto YU4 (Matte Black)
Audio
Kanto Sub6 (Matte Black)
Audio
Rode NT-USB
Other
Logitech C920
Other
Xbox One Wireless Controller
Other
Wacom Intuos Pro (Small)
francisw19 is offline
post #5 of 12 (permalink) Old 02-11-2013, 10:29 AM
Whalemeal's Avatar
Rep: 16 (Unique: 16)
+1 to that back plate is mostly for look. Because the backside of GPU pcb is what you see in a windowed case, it really helps to make look neat and clean.
I have EK gtx 680 water blocks and back plates on two GTX 670 FTWs. There are some spots of direct contact (looks like vrm related part) on the back plate via thermal pads. I guess it will provide at least some passive cooling on these spots. But it definitely won't affect your GPU/VRAM temps.
Whalemeal is offline
post #6 of 12 (permalink) Old 02-11-2013, 12:15 PM
Yukss's Avatar
Rep: 41 (Unique: 32)
provide rigidity to the board and looks cooler.. so why not ?
heres is mine:
Yukss is offline
post #7 of 12 (permalink) Old 02-11-2013, 12:23 PM
2 Easy
nyk20z3's Avatar
Rep: 70 (Unique: 52)
I have notice no temp difference but yes it will add more rigidity,cleaner looks.
Here is 1 of my 670 FTW's with a 670 back plate!
The problem is these back plates are designed for a stock air cooled card so the hardware does not transition directly over.I am using water blocks so i had to use the hardware provided by XSPC.I was not able to secure every mounting point down on the back plate but all mounting points on the water block are secure.
nyk20z3 is offline
post #8 of 12 (permalink) Old 02-11-2013, 12:31 PM
stubass's Avatar
Rep: 2658 (Unique: 1360)
pretty much what was said, wont help with cooling, looks cool and may offer stronger support for the PCB. they really do look cool but not really needed with stock cooling.
stubass is offline
post #9 of 12 (permalink) Old 04-23-2013, 08:53 PM
ivoryg37's Avatar
Rep: 19 (Unique: 19)
Does this apply for 4gb cards as well with the memory chips on the back of the PCB? Would I need a backplate then
ivoryg37 is offline
post #10 of 12 (permalink) Old 04-23-2013, 09:01 PM
stubass's Avatar
i thought a card like that would come with one thinking.gif anyway AFAIK memory chips dont get that hot but ones on the back of the PCB i am not sure.
stubass is offline
