7870 Tahiti LE Waterblock - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 02-16-2013, 03:10 PM - Thread Starter
Rep: 9 (Unique: 7)
I've been researching this pretty heavily over the past day or so, and I think I might have made some headway on it. I just want some input on it before I take the plunge and drop 350$. Would it fit.
Tahiti LE chip http://i.imgur.com/qBNkT.jpg
7870 GHZ chip http://www.coolingconfigurator.com/upload/pictures/AMD-Radeon-HD7870-PCB.jpg
The waterblock - http://www.coolingconfigurator.com/step1_complist?gpu_gpus=631
Silvercast is offline
post #2 of 9 (permalink) Old 02-16-2013, 07:05 PM - Thread Starter
Rep: 9 (Unique: 7)
post #3 of 9 (permalink) Old 02-16-2013, 07:39 PM
Whalemeal's Avatar
Rep: 16 (Unique: 16)
Well I'm not gonna say a firm "no" here but full cover block not only covers core + VDRAM. It also covers VRM part. It seems to me that Tahiti LE has different layout of VRM part than reference 7870.
Whalemeal is offline
post #4 of 9 (permalink) Old 02-16-2013, 07:42 PM
Linux Lobbyist
utnorris's Avatar
Rep: 174 (Unique: 160)
I doubt the block that fits a 7870 will fit the LE (Tahti) card. Just in the two pics everything is different. You can always email them and ask, but I think you should either wait for the correct block or use a universal GPU only block.
utnorris is offline
post #5 of 9 (permalink) Old 02-16-2013, 07:51 PM - Thread Starter
Rep: 9 (Unique: 7)
The universal block is horribly ugly, and passive RAM cooling just... no.
How new is the tahiti LE chip? I mean, one of the big water block manufacturers are saying there are no plans for a full cover block for it, that's just no acceptable frown.gif
Custom waterblocks? Where!?
post #6 of 9 (permalink) Old 02-16-2013, 10:45 PM
Linux Lobbyist
utnorris's Avatar
Not every card gets a block made for it, especially the mid range cards. Look at all the non-reference cards out there and 1 or 2 get blocks made for them. There are plenty of different GPU only blocks that look great, the EK and Heatkiller are both great looking blocks. If you want a custom block, I am sure you can find someone to make one, but it won't be cheap. Why not get a HD7950 if a full cover block is that important to you? I don't think they are that much more if catch them on sale. Just a thought.
utnorris is offline
post #7 of 9 (permalink) Old 02-16-2013, 10:54 PM
jeffro37's Avatar
Rep: 43 (Unique: 39)
Look and see the difference between the 7870 le and the 7950. They have they same chip so maybe the card is laid out about the same.
jeffro37 is offline
post #8 of 9 (permalink) Old 03-10-2013, 07:52 PM
Entropia's Avatar
Rep: 0
Just some advice for anyone looking to water cool this card. I've recently purchased on and can confirm that the GPU chip and mounting holes are the same as regular 7870's and the rest of the 6xxx and 7xxx range bar the 7900 series. And yet the PCB layout is different to the regular 7870 so there's definitely no full cover solution that will work as of this date. I've got a universal block on mine and that fits easily and cools it quite effectively (over 40% reduction in load temps).
Entropia is offline
post #9 of 9 (permalink) Old 03-11-2013, 02:34 AM
markovian's Avatar
Rep: 6 (Unique: 6)
i have a maze 5 on mine copper sinks on the ram ... moded the vrm abit have a fan on both sides of it overkill abit but i like low temps
fyi atm temps and volts are not helping the card atleast on the saphire xt one
i canot spell punctuate or anything english related beond 3rd grade ... try to decipher im sorry if its hard
markovian is offline
