Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 2 - Overclock.net - An Overclocking Community
post #11 of 21261 (permalink) Old 03-04-2013, 11:55 PM
CTM Audi's Avatar
Rep: 23 (Unique: 15)
Mine should be here some time this week. Started working on the rest of the coolers in my review.
CTM Audi is offline
post #12 of 21261 (permalink) Old 03-05-2013, 04:09 AM
Hallengreen's Avatar
Rep: 0
Thinking about buying one and expand it with another radiator. (Later expand to GFX WC) But I could use some help to that, since this will be my "first" actually WB.
I will place the H220 rad in the front with push/pull configuration & the other one should be placed at the top in my FD Arc mini. But the radiator shouldn't be bigger than a Swiftech Rad or H100, because I'm worried that it might interfere with my RAM's.
So i'm thinking about getting a HW-Labs Black Ice - GTS Lite 240 in push/pull also, but would it gain more if I choosed to get a bigger rad and only do pull or push instead of both?
Also I would need some fittings for the new rad? As told I will place it at the top but which fittings to choose? The fittings should turn against the 5,25bay because there's the space to get the tubes routed good.
Also which tubes do I need to get it all working together and with 2 rads I'm gonna need some coolant can you guys recommend something?
Currently I'm having 4x Akasa Apache fans but should I change them to something else?
Hallengreen is offline
post #13 of 21261 (permalink) Old 03-05-2013, 05:01 AM
gsk3rd's Avatar
Rep: 50 (Unique: 32)
Ordered mine last night. Should be the last thing for my build.
gsk3rd is offline
post #14 of 21261 (permalink) Old 03-05-2013, 05:19 AM
Julsmba's Avatar
Rep: 1 (Unique: 1)
I have it since the 25 of february...
Julsmba is offline
post #15 of 21261 (permalink) Old 03-05-2013, 05:28 AM
smex's Avatar
Rep: 174 (Unique: 147)
they finally did it right and the heatsink i lapped from the factory. no thermal paste on it or did you just replace it?!
RigOnTheRun
(6 items)
7700HQ @ Liquid metal
GTX 1070 8GB @1850mhz (2250mhz Boost!)
32 GB DDR4 2400
1 TB Samsung 950 SSD
Operating System
Win10 x64, Cubes R4.0
120hz FHD IPS-Tech
smex is offline
post #16 of 21261 (permalink) Old 03-05-2013, 05:34 AM
Julsmba's Avatar
Rep: 1 (Unique: 1)
Julsmba is offline
post #17 of 21261 (permalink) Old 03-05-2013, 06:39 AM
justanoldman's Avatar
Rep: 282 (Unique: 145)
If by lapped, you mean a nice shiny reflective surface, then yes. If you mean lapped as in flat, then no. Their coldplate, like many manufactures today, assumes your IHS is concave so the surface of the H220 is slightly convex.
justanoldman is offline
post #18 of 21261 (permalink) Old 03-05-2013, 06:40 AM
colforbin's Avatar
Rep: 11 (Unique: 10)
Mine should be here Friday as well. First Time WC! Looking forward to my new money pit.thumb.gif
Surrender to the Phlow!
colforbin is offline
post #19 of 21261 (permalink) Old 03-05-2013, 07:28 AM
Avonosac's Avatar
Rep: 158 (Unique: 114)
I went with another MCR-220-QP for my loop, for the second rad. I got the HydrX coolant concentrate, and I am buying some distilled water locally. For this system you want to get 3/8 ID / 5/8 OD fittings, you can get compression, or barb whichever your preference. I got some of this tubing here.
I'm curious to know if they stealth GT thin rad push pull would be better than the MCR-220-QP, I went with swiftech just to keep things consistent in my prodigy. Let us know how it goes for you.
Avonosac is offline
post #20 of 21261 (permalink) Old 03-05-2013, 08:01 AM
byomes's Avatar
Rep: 3 (Unique: 3)
Ordered mine 3/2 and the order status has stayed 'status received' ever since frown.gif
byomes is offline
