Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 2120 - Overclock.net - An Overclocking Community
post #21191 of 21261 (permalink) Old 09-24-2019, 09:15 AM
Herp123's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by ciarlatano View Post
It's been discontinued for several years. A lot of asks in this thread, but I haven't seen anyone actually finding one. If you stay with 3/8" ID tubing, they are really unnecessary.
Oh I see.. That's really a shame, was planning to use rigid tubing. I might end up with ZMT tubing
Herp123 is offline
post #21192 of 21261 (permalink) Old 09-24-2019, 04:32 PM
Retired Staff
Mr.N00bLaR's Avatar
Rep: 262 (Unique: 154)
Has anyone got much experience with the x3? Seems like the 3 fan would be a neat way to cool my cpu and gpu. Does the pump have enough power to keep the flow up through a CPU, gpu stock combo unit and maybe another rad?
Rig: Ryzen 3600 + HTC 1080ti all in a Corsair Air 740
Mr.N00bLaR is online now
post #21193 of 21261 (permalink) Old 09-24-2019, 05:35 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 414 (Unique: 278)
It was designed with the expansion to a GPU and additional rad in mind. This is exactly what it was intended for and it does it very well. Adding a third rad is typically not an issue, either, but adding a third block would be pushing it.
ciarlatano is online now
post #21194 of 21261 (permalink) Old 09-24-2019, 05:49 PM
v1ral's Avatar
Rep: 67 (Unique: 65)
I have an odd question hopefully someone can chime in.
So the SATA power cable on both the splitter and the pump melted/Shorted, I don't like SATA powered cables only for drives anyways....
I want to convert those cables to 4 pin molex, I see that PPCS sales Swiftech's splitter in the older Molex type, but my question is the pump side. I see the wire has a solid black wire and the other has a white/gray broken line, my question is which one is negative and which one is positive?
I am trying NOT to bin my H220X or get the newer cooler!
Thanks for your time!
v1ral is offline
post #21195 of 21261 (permalink) Old 09-24-2019, 07:15 PM
ciarlatano's Avatar
It should be identifiable by location.
post #21196 of 21261 (permalink) Old 11-12-2019, 10:02 AM
Can we add products yet?
Justinator's Avatar
Rep: 2 (Unique: 2)
I just bought an X3 H360, I know it's not listed for this club but can I get in anyway?
Also, I've seen some criticism of the noise and cooling performance of the included IRIS Helix fans. I have some EK Vardar 120 ER EVO RGBs around that look to be about 30% better for airflow and static pressure. Do you think it's worth changing them, or will the Helixes be enough as is?
Working Name
(25 items)
Intel i7-8700K
MSI Z370 Gaming Pro Carbon
MSI GeForce GTX 1080Ti Gaming X 11GB
Corsair 16GB Kit DDR4 Vengeance RGB C15 3000MHz
Samsung 960 EVO 500GB NVMe
Seagate FireCuda
Corsair RM850i
EK X-Res 140 Revo D5 PWM
EK PE360
EK Velocity RGB - Nickel + Acetal
Bitspower CC5U Silver Shining Compression Fitting 1/2 ID 3/4 OD *6
Bitspower 90-Degree Rotary Extender
Cougar Conquer
Operating System
Windows 10 Home 64-Bit
AOC Agon AG271QG
Keyboard
Corsair K70 RGB LUX
Mouse
Steelseries Rival 600
Mousepad
Razer Manticore
Audio
Creative Sound Blaster ZxR
Audio
Logitech Z906
Other
Thrustmaster Warthog HOTAS
Other
Thrustmaster MFD Cougar
Other
NaturalPoint Track IR 5 Ultra
Other
MFG Crosswind
Other
DSD Fight - FLT 2
Justinator is offline
post #21197 of 21261 (permalink) Old 11-12-2019, 05:23 PM
ciarlatano's Avatar
if you have the Vardars, use them. The Helix are the weak link in the X3. Their low to mid Ron performance is pretty dreadful.
post #21198 of 21261 (permalink) Old 11-18-2019, 05:33 AM
ciarlatano's Avatar
@chrisjames61
See attached
post #21199 of 21261 (permalink) Old 11-18-2019, 02:47 PM
chrisjames61's Avatar
Rep: 169 (Unique: 99)
@chrisjames61
See attached
Thanks! It was 50/50 that I got it right and with dumb luck I did just that!
Ryzen- Too lazy to list everything. ASUS ROG Crosshair VI Hero- R5 1600, MSI Gaming Titanium- R5 2400G
chrisjames61 is offline
post #21200 of 21261 (permalink) Old 11-20-2019, 07:28 PM
Gamer
KillerBee33's Avatar
Rep: 48 (Unique: 33)
Got an old H320X2 Prestige on a loop with 6700K @ 4.6/1,320V and a Titan XP, well, "HAD" ...it finally started to leak after 4 years so i just ordered X3. It did the job well!
Oculus SetUp
Intel® Core™ i7-6700K
MSI Z170A Gaming Pro Carbon
NVIDIA TitanX Pascal
CORSAIR Vengeance LPX 16GB
SAMSUNG 840 Pro Series 2.5" 256GB
Mushkin Enhanced Reactor 1TB
RMi Series™ RM650i
Swiftech H320 X2 & Alphacool 240 Radiator
NZXT H440 Razer Edition
Operating System
Microsoft Windows 10 Pro 64-bit
Toshiba 50L3400U
Oculus Rift
Keyboard
Logitech Wireless Touch Keyboard K400
KillerBee33 is offline
