Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 2126 - Overclock.net - An Overclocking Community
post #21251 of 21269 (permalink) Old 01-08-2020, 06:52 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 422 (Unique: 282)
Quote: Originally Posted by ntuason View Post
Awesome great to hear I bought the H360X3 instead of the EK-MLC Phoenix 360, though I bet they'd be similar in performance?
The Swiftech has a better pump, and is easier to refill and expand. Performance is similar, but the stock Swiftech fans really hinder it.
ciarlatano is offline
post #21252 of 21269 (permalink) Old 01-08-2020, 07:31 PM
ntuason's Avatar
Rep: 173 (Unique: 154)
Ya I’m using the stock fans right now and they don’t seem to push a lot of air through the rad. I’m trying to research which fans to go with but there’s an overwhelming selection LOL.
Would you be able to recommend something that’s good for radiators?
Thank you
i7 980x + CF 6970
(11 items)
i9-9900K @ 5.2GHz (Direct-Die)
ASUS ROG Maximus XI Apex Z390
ASUS ROG STRIX GeForce RTX 2080 Ti O11G
G.Skill Trident Z Royal @ 4200MHz CL18
Samsung 970 EVO Plus NVMe M.2 500GB
Samsung 860 QVO 1TB
Seagate BarraCuda 8TB
Corsair Professional Series Gold AX1200 (10+ Years Old)
Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
Lian Li PC-011 Dynamic
Operating System
Windows 10 Pro 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
ASUS ROG Strix GeForce GTX 1660 Ti
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #21253 of 21269 (permalink) Old 01-08-2020, 07:46 PM
I Like Beer
Hokies83's Avatar
Rep: 264 (Unique: 170)
I’m doing 3 360s rads myself the h360 + 2 more, with that much rad you can get away with avg fans,
I kept the stocks on the h360 and using Corsair hd120s on one 360 and LL120s on another,
I’ll audibly adjust them till I can’t hear them, then leave them there lol
Hokies83 is offline
post #21254 of 21269 (permalink) Old 01-09-2020, 06:20 AM
ciarlatano's Avatar
Thank you
A lot of that is going to depend on whether or not you find the RGB a necessity. If so.....the only decent RGB fan I am aware of is the Corsair ML120. If you don't need RGB, the Noctua NF-A12X25 is the vest of the best, be quiet Silent Wings 3 being another top choice. If you are looking for something a little more budget friendly (I think....I know pricing in Canada is really wonky), there is the Phanteks F120MP or Arctic P12. And....keep in mind that you can go with any of these fans with no RGB and add Phanteks Halo frames for the best of all worlds.
post #21255 of 21269 (permalink) Old 01-09-2020, 09:16 AM
ntuason's Avatar
That's insane. Did you see a big improvement when adding a third rad or did you start with 3 from the from the get-go?
I don't really care for RGB since its going to be in a ''push'' configuration on the H360X3 and wont see it. I really want those Noctua NF-A12X25 but at $40 for one in Canada LOL! I'll have to settle for the P12.
I have my H360X3 on top pushing air into the case and the other 360 rad pushing air in also, I'll probably push/pull the other rad to compensate for the poor performance of the helix 120 iris.
Thanks for the assistance. +Rep
i7 980x + CF 6970
(11 items)
Samsung 860 QVO 1TB
Operating System
Keyboard
Mouse
Mousepad
Logitech G840
Audio
Audio
Audeze LCD-4
Operating System
Keyboard
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is offline
post #21256 of 21269 (permalink) Old 01-09-2020, 10:57 AM
doyll's Avatar
Rep: 1678 (Unique: 932)
Just a caution, if you have 6x 120mm vents and fans pushing air into case through radiators you also need similar 6x 120mm vents letting that 6x of air out of case. If case only has 3x 120mm vents for exhaust then the 6x 120mm intakes can only move as much air into the case as the 3x exhaust vents can let out. A case can only flow as much air in as it can flow out .. whichever is smaller (intake vs exhaust area) limits the maximum case airflow. There can't be more air going into the case than is coming out of it .. simple physics.
doyll is offline
post #21257 of 21269 (permalink) Old 01-09-2020, 12:44 PM
ciarlatano's Avatar
What if he has six 120mm fans as intakes going through rads with the fans spinning at 750rpm....while having three 120mm exhaust which are mostly unimpeded running at 2500 rpm?
Mind you, I do agree with you that there should be actual airflow for the case rather than everything just blowing air in. And your simple physics are simply correct.
post #21258 of 21269 (permalink) Old 01-09-2020, 01:24 PM
doyll's Avatar
So you suggest running exhausts 2x or 3x fans at 4x or 8x higher noise levels than 6x intake fans on radiator? Wouldn't it make more sense to have one 360mm rad as intake and one as exhaust?
But seriously, isn't ntuason using a Lian Li PC-011 Dynamic case with four 3x 120mm vent sets, one in bottom and two on right side near front and one in top, plus 2x 80mm vents in back over motherboard I/O. He should be fine with just the 6x good intake/radiator fans as intake, although I would consider using them as exhaust and keep case air temp lower so all components that are not under waterblocks have optimal cooling.
doyll is offline
post #21259 of 21269 (permalink) Old 01-09-2020, 03:29 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 163 (Unique: 127)
Does anyone know if the H360X3 Drive X3s pump is powerful enough to handle 2 360mm rads and a Watercooled 2080Ti?
Swiftech says yes.
Absolutely. That is exactly what it was designed for,
Some concern on this too.
I want to build a custom loop but unsure if I should keep anything from my DriveX3, rather than just buy a new pump/res+360 rad to go along with it. Or maybe I should just swap the waterblock for an Optimus AM4 one.
Thank you
I swapped the swiftech fan for Gentle Typhoon 2150s and drop temp around 6-8c on full load.
X99 5820K 4.5G, ~220-240w.
I found out those Helix stuff are just really cheap chinese fans that everyone is rebranding and selling.
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #21260 of 21269 (permalink) Old 01-10-2020, 03:35 AM
I Like Beer
Hokies83's Avatar
Just waiting on my QDC to get here.
Looks clean to me 🙂
3 360’rads so I can run all fans at minimum speed, that’s the only reason.
Hokies83 is offline
