Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 2127 - Overclock.net - An Overclocking Community
post #21261 of 21269 (permalink) Old 01-11-2020, 01:46 PM
I Like Beer
Hokies83's Avatar
Rep: 264 (Unique: 170)
10c temp drop vs h100i platinum,
Hokies83 is offline
post #21262 of 21269 (permalink) Old 01-26-2020, 03:01 AM
v1ral's Avatar
Rep: 67 (Unique: 65)
v1ral is offline
post #21263 of 21269 (permalink) Old 01-29-2020, 08:42 PM
ntuason's Avatar
Rep: 173 (Unique: 154)
Does anyone know exactly how strong the pump is in the Swiftech H360X3 Drive X3 compared to D5 or DDC? Is the Drive X3 like a quarter the strength of tese standalone pumps?
I ask because I expanded to two 360mm rads, a 200mm reservoir and in the future planning to water cool the GPU and add in another 360 rad. How do I figure out if I’m reaching the headroom or surpassing the capabilities of Drive X3 pump?
Thanks
i7 980x + CF 6970
(11 items)
i9-9900K @ 5.2GHz (Direct-Die)
ASUS ROG Maximus XI Apex Z390
ASUS ROG STRIX GeForce RTX 2080 Ti O11G
G.Skill Trident Z Royal @ 4200MHz CL18
Samsung 970 EVO Plus NVMe M.2 500GB
Samsung 860 QVO 1TB
Seagate BarraCuda 8TB
Corsair Professional Series Gold AX1200 (10+ Years Old)
Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
Lian Li PC-011 Dynamic
Operating System
Windows 10 Pro 64bit
Samsung CHG70 32" QLED, 1ms 144Hz
Keyboard
Logitech G815 Tactile
Mouse
Logitech G Pro Wireless
Mousepad
Logitech G840
Audio
Kanto Yu4 + Kanto SUB8 8-Inch
Audio
Audeze LCD-4
i7 980X 3003B475* @ 4449.1MHz 1.45V (6C-12T)
ASUS Rampage III Extreme - 1208 BIOS
ASUS ROG Strix GeForce GTX 1660 Ti
6GB Corsair Dominator GT 2009MHz / 7-8-7-20 T1 C7*
RAID 0* OCZ Vertex 3 120GBX2 (OS)+ 4X 2TB WD Green
Seasonic PRIME 600 Titanium
Corsair Obsidian 800D
Operating System
Windows 7 Ultimate 64Bit
Keyboard
Filco Majestouch-2 Cherry MX Red
Mouse
Razor Mamba 4G
Mouse
Logitech G703
ntuason is online now
post #21264 of 21269 (permalink) Old 01-30-2020, 05:48 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 422 (Unique: 282)
Thanks
I had the exact specs, but can't find them. I do recall the head pressure being ~2.2m, and flow rate being over 1gpm. Essentially the pump was designed to comfortably handle two blocks and two rads. Anything beyond that you need to slook at adding an additional pump, or simply replacing the stock pump with the MCP50X (which is a direct replacement). The MCP50X has similar performance to an MCP35X DDC (https://thermalbench.com/2015/01/05/...mcp50x-pump/4/), but is quieter and does not have the DDC's heat issues.
ciarlatano is offline
post #21265 of 21269 (permalink) Old 01-30-2020, 09:18 AM
ntuason's Avatar
That MCP50X sounds interesting thank you!
Just out of curiosity, if I were to purchase a reservoir + pump (D5) combo and add it to my loop, would I run into trouble mixing H360X3 weaker pump with the D5?
Wouldn’t the weaker H360X3 pump struggle to keep up with the D5?
+Rep.
i7 980x + CF 6970
(11 items)
Samsung 860 QVO 1TB
Operating System
Keyboard
Mouse
Mousepad
Logitech G840
Audio
Audio
Audeze LCD-4
Operating System
Keyboard
Mouse
Razor Mamba 4G
Mouse
Logitech G703
post #21266 of 21269 (permalink) Old 01-30-2020, 09:51 AM
ciarlatano's Avatar
+Rep.
You can run two pumps that are not alike with no issues.
post #21267 of 21269 (permalink) Old 02-07-2020, 10:24 AM
mfknjadagr8's Avatar
Rep: 96 (Unique: 70)
I have a mcp50x and the h220x (which uses the mcp35x) in the same loop for years now with zero issues...I have a 480 monster and a 420 ek le rad and the 220x with two video cards blocked and have never had a flow issue even running the mcp50x solo they are very good pumps
mfknjadagr8 is offline
post #21268 of 21269 (permalink) Old 02-07-2020, 10:31 AM
ciarlatano's Avatar
Agreed, they are excellent pumps. But, the H220X uses and MCP30, which is an MCP50X based pump. The MCP35X is a Laing DDC based pump, and is not compatible (in terms of direct replacement) with the MCP50X or MCP30
post #21269 of 21269 (permalink) Old 02-08-2020, 11:39 AM
The swiftech rep that sent me an email about six years ago must've accidentally told me the wrong pump then when I asked thanks for the clarification....iirc the max speed of the mcp30 is slightly lower than the mcp50x but has shown zero effects in my loop but I also have a pretty non restrictive loop not sure that that would matter but I've only had two loops so far and both I chose non restrictive blocks and fairly non restrictive rads.....
If I showed pictures of my loop right now youde have me banned from ocn it's way overdue a cleaning...I just dont have the time working 7 days a week and having a 2 year old...
