Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 565 - Overclock.net - An Overclocking Community
post #5641 of 21195 (permalink) Old 08-09-2013, 01:46 AM
michael-ocn's Avatar
Rep: 121 (Unique: 80)
I've been running an asetek550 for 3yrs. Pump is powered via a 3pin plug, its runs at 100% all the time on the SYSFAN header of the mobo. It's adjustable by voltage regulation, but its really more designed to run at constant speed (afaict).
2015: i7-5820k @4.4, 980ti FTW @1481/7710, ASUS X99-PRO, Crucial Ballistix 2400 cl12, Silverstone 850W, Swiftech H240X
2010: i7-875k @3.9, 670 FTW @1267/6840, ASUS P7P55D-E-PRO, Crucial Ballistix 1600 cl8, Silverstone 750W, Asetek 550LC
Kickass-X99
(19 items)
Falcon2010
(18 items)
i7-5820k | [email protected] 1.23v | [email protected] 1.1v
ASUS X99-PRO / USB 3.1
EVGA GTX 980ti FTW
Crucial Ballistix Sport 2400 CL12 (4 x 4GB)
Crucial MX200 (1 TB)
Crucial M500 (960 GB)
Western Digital Green (2 TB)
Optical Drive
Pioneer BDR-XU03
Silverstone Strider Gold 850
Swiftech H240-X
Phanteks Enthoo EVOLV ATX (gray)
Operating System
Win 10 Pro (64 bit)
Operating System
Linux Mint 17 Cinnamon
Asus ROG Swift PG279Q
Keyboard
Rosewill RK-9000BR
Mouse
SteelSeries Sensei [RAW]
Mouse
Gamedias NYX Mousepad 350x280
Audio
Grado SR80e
Other
Lexar Professional Workflow SR2 SDHC/SDXC UHS-II USB 3.0 Reader LRWSR2RBNA
i7-875K
ASUS P7P55D-E-PRO
EVGA GTX 670 FTW
Crucial Ballistix Tactical
Western Digital Caviar Black
Crucial M500 SSD
Optical Drive
LG Blu-ray Combo Drive
Silverstone Strider Plus 750
Noiseblocker Multiframe M12-P
Silverstone Case Fans
Asetek 550LC
Silverstone Kublai
Operating System
Windows 7 Home Premium 64bit
Samsung 2443
Keyboard
Rosewill RK-9000BR
Mouse
Audio
AntLion ModMic v4
Audio
Sennheiser PX100 headphones
michael-ocn is offline
post #5642 of 21195 (permalink) Old 08-09-2013, 03:18 AM
Thorgasm's Avatar
Rep: 0
ff
Thorgasm is offline
post #5643 of 21195 (permalink) Old 08-09-2013, 03:30 AM
bobsaget's Avatar
Rep: 25 (Unique: 17)
Originally Posted by Thorgasm View Post
Hello, i need help. I used the 8 long silver screws to mount my radiator to my case with the fans on the bottom. Was i supposed to use the long screws to mount the radiator to the case or did i damage the fins underneath.
if you put the screws through the radiator (Case=>rad=>fans) then you damaged the unit
bobsaget is offline
post #5644 of 21195 (permalink) Old 08-09-2013, 03:44 AM
Thorgasm's Avatar
Rep: 0
Thorgasm is offline
post #5645 of 21195 (permalink) Old 08-09-2013, 05:10 AM
Thorgasm's Avatar
Rep: 0
It is performing well and it is mounted the way i wanted it. Should i be worried?
Thorgasm is offline
post #5646 of 21195 (permalink) Old 08-09-2013, 05:25 AM - Thread Starter
Phelan's Avatar
Rep: 140 (Unique: 102)
Most AIOs are voltage controlled, buy they are of a different design. It all has to do with the design of the PCB in the pump/fan. The H220 (and Apogee Drive II, MCP655-PWM, and Helix PWM fans, for that matter) are designed exclusively for PWM control will be damaged when run on voltage control. How long it takes is somewhat random, but it is a matter of when, not if. The MCP655 and Helix fans have voltage-controlled variants that will not be damaged with voltage control. I believe the MCP35X is PWM-only as well, but I don't remember.
Phelan is offline
post #5647 of 21195 (permalink) Old 08-09-2013, 05:26 AM
os2wiz's Avatar
Rep: 61 (Unique: 40)
Originally Posted by jincuteguy View Post
Oh ok yea I have the Sabertooth Z77 board, glad all of the 4pin headers are PWM, I just checked the manual too, thx for clarifying them smile.gif
I forgot to ask you one more thing. Are all the pumps from these Asetek / CoolIT based like the corsair H100i, H80i, H110, NZXT X40 / X60, Thermaltake Water 3.0, etc...like are all the pumps from these AIO coolers adjustable? Like can you run the pump speed according to the temperature? Or does it have to run at the max speed at always? Because I checked the spec of all the pumps from these AIO coolers, they're all pretty much like 2500rpm +/- 200rpm.
This is the Swiftech H220-H320 owners club. Go to the general watercooling forum for your answers since you don't intend to buy the Swiftech product. I knew you were OCD and would wind up shooting yourself in your foot. Get a life.
Technology is NOT a liberator . Whom technology serves is a class question.
Technology wielded by the capitalist class benefits only the exploiters.
Technology wielded by the working class will serve ALL Humanity.
Ryzen 9 3900X at 4.2 GHZ, MSI X570 MEG ACE motherboard, AlphaCool Eisbaer 360 cpu AIO cooler
32GB G.Skill TridentZ DDR4 4000mhz CL-19-19-19-39 1.35v Samsung 970 EVO m.2 NVMe 1TB
AMD Radeon VII gpu
os2wiz is offline
post #5648 of 21195 (permalink) Old 08-09-2013, 05:32 AM
os2wiz's Avatar
Phelan, do you remember some earlier post mentioning that Swiftech was going to make the radiator slightly thicker to relieve the flow restriction issue in the radiator?
AMD Radeon VII gpu
os2wiz is offline
post #5649 of 21195 (permalink) Old 08-09-2013, 05:51 AM - Thread Starter
Phelan's Avatar
Originally Posted by os2wiz View Post
Phelan, do you remember some earlier post mentioing that Swiftech was going to make the radiator slightly thicker to relieve the flow restriction issue in the radiator?
I haven't seen a post of such. The main reason for the flow restriction in the swivel barbs anyway, not the rad itself. The core is similar to the mcr220-qp-res, but with a couple moved water channels so that over-tightened screws that push through don't create leaks.
Phelan is offline
post #5650 of 21195 (permalink) Old 08-09-2013, 05:54 AM - Thread Starter
Phelan's Avatar
See my above post. The unit is damaged aesthetically from this but because the fins behind the screws don't see air flow really anyway, you won't see a performance difference. The H220 rad is unique in the regard that it won't leak if screws are over-tightened, unlike all other AIOs.
Phelan is offline
