Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 570 - Overclock.net - An Overclocking Community
post #5691 of 21188 (permalink) Old 08-11-2013, 07:22 AM
bond32's Avatar
Rep: 91 (Unique: 70)
H220 does perform better than the h100i.
bond32 is offline
post #5692 of 21188 (permalink) Old 08-11-2013, 07:26 AM
selk22's Avatar
Rep: 57 (Unique: 49)
I can confirm this as my friend owns the h100i we have similar systems and I have better temps at higher clocks and voltages.. If only this pump noise would stop.
EDIT: We both also use Mx-4 as I find this to be the easiest to work with and provide 1-2c difference from IC Diamond
selk22 is offline
post #5693 of 21188 (permalink) Old 08-11-2013, 07:47 AM
bond32's Avatar
Martin's testing showed that the h220 performs better. Not really a huge increase over the h100i but it does perform better.
bond32 is offline
post #5694 of 21188 (permalink) Old 08-11-2013, 08:43 AM
os2wiz's Avatar
Rep: 61 (Unique: 40)
The IC Diamond is a little thicker but no more difficulto work with. You apply it in exactly the same nanner as other tim. A peas sized drop in the middle of the cpu and then mount the block.
The difference in temps is more like 4 degrees Celsius not 1-2. MX-4 is not even close.
Technology is NOT a liberator . Whom technology serves is a class question.
Technology wielded by the capitalist class benefits only the exploiters.
Technology wielded by the working class will serve ALL Humanity.
Ryzen 9 3900X at 4.2 GHZ, MSI X570 MEG ACE motherboard, AlphaCool Eisbaer 360 cpu AIO cooler
32GB G.Skill TridentZ DDR4 4000mhz CL-19-19-19-39 1.35v Samsung 970 EVO m.2 NVMe 1TB
AMD Radeon VII gpu
os2wiz is offline
post #5695 of 21188 (permalink) Old 08-11-2013, 09:56 AM
Hardware Enthusiast
BramSLI1's Avatar
Rep: 207 (Unique: 129)
Originally Posted by goddog View Post
sorry for not replying more quickly I got side tracked with work. So this poses another question would another pump in the loop help this by forcing air out. or would the other pumps work be stalled by the h220 pump in a state of stuck.
Adding a second pump to your loop will only improve performance. Even though they're different pumps, that operate at different speeds, they will only enhance your flow rate and improve your head pressure. Adding a second pump to the loop will also improve this kit's ability to bleed air out of it.
*Official* sonic.gifGigabyte GA-990FXA-Series sonic.gif*Thread/Club*
BramSLI1 is offline
post #5696 of 21188 (permalink) Old 08-11-2013, 10:48 AM
BenchAndGames's Avatar
Rep: 1 (Unique: 1)
Originally Posted by os2wiz View Post
What is Liquid Pro, a coolant or tim? I know the best non-conductive tim on the market is Icy Diamond. I got that from the best overclockers on the AMD FX Vishera Owner's Club, Red1776 and KyadCK.
And what you mean by this? I did not say that the Liquid Pro is the best, do not understand why you give me this answer ...
▐► CPU: Intel® Core™ i7-4770K
▐► GPU: Nvidia GeForce RTX 2060 6GB
▐► MB: Gigabyte G1.Sniper 5
▐► RAM: 16GB G.Skill TridentX @ 2400 MHz
▐► SSD1: 250GB Samsung 840 EVO
▐► PSU: Corsair HX850W
BenchAndGames is offline
post #5697 of 21188 (permalink) Old 08-11-2013, 10:51 AM
jincuteguy's Avatar
Rep: 6 (Unique: 5)
Originally Posted by Imprezzion View Post
We shall see.. I used to use a H100i but as it's RMA I ordered a H220 which I plan to add a 360 60mm thick rad to later on.
I know exactly what temps my H100i pulled at specific clocks and voltages and I will re-test them with the H220. All tests will be done using Liquid Ultra TIM between the IHS and the block.
Yea let me know when u ge the H220.
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Gaming Rig
(10 items)
5820K
Asus X99-A
2 x MSI GTX 1080 Ti Trio
Corsair AX 1600i
Corsair H100i Pro
CoolerMaster C700P
DELL U3014 Premiere 30"
Keyboard
Logitech G910
Audio
KEF LS50 Wireless
Audio
JL Audio E110 Sub
jincuteguy is offline
post #5698 of 21188 (permalink) Old 08-11-2013, 10:54 AM
jincuteguy's Avatar
Rep: 6 (Unique: 5)
I was using MX-2 that I bought 3-5years ago. Then I just got the IC Diamond 3 days ago, so far it gives me better temp. Not sure how it compare to MX-4, I supposed it's better too. A lot of ppl are recommending this IC Diamond stuff, so I think it's def live up to the hype.
Gaming Rig
(10 items)
5820K
Asus X99-A
Corsair AX 1600i
Corsair H100i Pro
CoolerMaster C700P
Keyboard
Logitech G910
Audio
KEF LS50 Wireless
Audio
JL Audio E110 Sub
post #5699 of 21188 (permalink) Old 08-11-2013, 11:40 AM - Thread Starter
Phelan's Avatar
Rep: 140 (Unique: 102)
I like IC Diamond, and have used it quite a while, but now I just use Swiftech Tim-mate 2 since I have a lot of it, and it's easier to apply on thermal pads and whatnot.
Phelan is offline
post #5700 of 21188 (permalink) Old 08-11-2013, 11:51 AM
jincuteguy's Avatar
Rep: 6 (Unique: 5)
How much better is your H220 compare to your friend H100i ? Is it like 2-3C better? or 5C+?
Also I thought the H220 supposed to be silent? and you got p ump noise? hm...
Gaming Rig
(10 items)
5820K
Asus X99-A
Corsair AX 1600i
Corsair H100i Pro
CoolerMaster C700P
Keyboard
Logitech G910
Audio
KEF LS50 Wireless
Audio
JL Audio E110 Sub
