Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 579 - Overclock.net - An Overclocking Community
post #5781 of 21172 (permalink) Old 08-13-2013, 06:55 AM
EarlZ's Avatar
Rep: 27 (Unique: 25)
I've seen martins site and I've been there a couple of times, I cant seem to find his specific article if he has compared the X60 with the H220 directly.
Linus shows a difference of about 12c
Consider my self sold, though I still need to dig how the Helix fans compare to the Gentle Typhoon AP15 though I have 3 of them here to test..
9700K / Gigabyte Z390 Master / Gigabyte 2080TI Gaming OC / 16GB G.Skill Trident Z RGB / Samsung Evo 860 & 850 500GB / Creative Sound Blaster Z / Acer Predator X34P
EarlZ is offline
post #5782 of 21172 (permalink) Old 08-13-2013, 07:12 AM
fortunesolace's Avatar
Rep: 24 (Unique: 20)
Originally Posted by BenchAndGames View Post
Did your H320 packaging arrived like this?
It's from a review. http://www.erodov.com/forums/swiftech-h320-cpu-liquid-cooling-kit-review-360mm-aio-open-loop-cooler/66231.html
Opening the box, it seems package is not very secure and there were quite a few dents on the radiator fins because of the packaging. This is certainly one concern which Swiftech must look into.
I plan to order the H320 from NCIX.ca. If BramSLI1 could chime in on this.
fortunesolace is offline
post #5783 of 21172 (permalink) Old 08-13-2013, 07:17 AM
EarlZ's Avatar
Is anyone here using Cool Laboratory Liquid Pro on their H220 ?
EarlZ is offline
post #5784 of 21172 (permalink) Old 08-13-2013, 07:28 AM
os2wiz's Avatar
Rep: 61 (Unique: 40)
The Swiftech fans are quiet and a good bang for the buck.
Technology is NOT a liberator . Whom technology serves is a class question.
Technology wielded by the capitalist class benefits only the exploiters.
Technology wielded by the working class will serve ALL Humanity.
Ryzen 9 3900X at 4.2 GHZ, MSI X570 MEG ACE motherboard, AlphaCool Eisbaer 360 cpu AIO cooler
32GB G.Skill TridentZ DDR4 4000mhz CL-19-19-19-39 1.35v Samsung 970 EVO m.2 NVMe 1TB
AMD Radeon VII gpu
os2wiz is offline
post #5785 of 21172 (permalink) Old 08-13-2013, 07:46 AM
os2wiz's Avatar
If that is all metallic like their Liquid Ultra it is not a good idea. It is conductive andany micro leak could destroy the cpu and water block. The best non-conductive tim is IC Diamond. Far better than both AS5 and the MX stuff.
AMD Radeon VII gpu
os2wiz is offline
post #5786 of 21172 (permalink) Old 08-13-2013, 07:46 AM
bond32's Avatar
Rep: 91 (Unique: 70)
I must dig up Linus's result then I vaguely remember his result, thanks for the heads up!
Linus is good but remember I think he made a mistake on his initial review of the h220, so make sure you check out his revisit videos. Also, I don't remember what he said about noise, but it still stands the kraken x60 fans are absolute junk. There are only 2 140mm high static pressure fans that are viable in my opinion, bgears b-blaster 140 and noctua. The kraken fans are absurdly loud at even low rpm.
Edit: I am about to order some nf-f12's, let us know how your ap-14's do.
bond32 is offline
post #5787 of 21172 (permalink) Old 08-13-2013, 07:59 AM
EarlZ's Avatar
The screenshot I posted above is the result from his redid video and he also explained the mistake he made.
EarlZ is offline
post #5788 of 21172 (permalink) Old 08-13-2013, 08:07 AM
BenchAndGames's Avatar
Rep: 1 (Unique: 1)
The instruction manual, I get very bent, inside the box, where is the block and pump, also the packaging was broken, as in the photo review.
The radiator has a small crack, a scratch, but its OK, the performance its good.
▐► CPU: Intel® Core™ i7-4770K
▐► GPU: Nvidia GeForce RTX 2060 6GB
▐► MB: Gigabyte G1.Sniper 5
▐► RAM: 16GB G.Skill TridentX @ 2400 MHz
▐► SSD1: 250GB Samsung 840 EVO
▐► PSU: Corsair HX850W
BenchAndGames is offline
post #5789 of 21172 (permalink) Old 08-13-2013, 08:16 AM
Hardware Enthusiast
BramSLI1's Avatar
Rep: 207 (Unique: 129)
Thank you for your input on our packaging and I'll make sure to pass it on to our production crew.
*Official* sonic.gifGigabyte GA-990FXA-Series sonic.gif*Thread/Club*
BramSLI1 is offline
post #5790 of 21172 (permalink) Old 08-13-2013, 08:22 AM
Gabrielzm's Avatar
Rep: 399 (Unique: 201)
You can also compare AP15 to helix, corsair and other fans in Martinsliquidlab.
Gabrielzm is offline
