Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 580 - Overclock.net - An Overclocking Community
post #5791 of 21297 (permalink) Old 08-13-2013, 08:27 AM
thebanik's Avatar
Rep: 2 (Unique: 2)
Originally Posted by fortunesolace View Post
http://www.erodov.com/forums/swiftech-h320-cpu-liquid-cooling-kit-review-360mm-aio-open-loop-cooler/66231.html
I plan to order the H320 from NCIX.ca. If BramSLI1 could chime in on this.
biggrin.gif, Its my review, Actually it can be a local distri issue as well, since the box was open even though it was a retail unit. However I know for a fact Corsair Packing is much more robust. So whosoever fault it was, the packaging seems to be not upto the mark IMO.
thebanik is offline
post #5792 of 21297 (permalink) Old 08-13-2013, 10:44 AM
thelude's Avatar
Rep: 4 (Unique: 4)
Originally Posted by Phelan View Post
Yep, no prob. But if 2 of those blocks are GPUs, be sure to set them up in parallel, not serial, so you have much better flow.
Will do. Thanks.
thelude is offline
post #5793 of 21297 (permalink) Old 08-13-2013, 10:52 AM
bond32's Avatar
Rep: 91 (Unique: 70)
I have 2 7950's being delivered tomorrow, already have one heatkiller block and will order the second one soon. Using this: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=36182 to connect them... A parallel config would simply mean inlet on the top left and outlet on the top right correct?
bond32 is offline
post #5794 of 21297 (permalink) Old 08-13-2013, 11:05 AM
Gabrielzm's Avatar
Rep: 399 (Unique: 201)
with two connections between the two cards. The bridge you linked apparently allows both types of operation, parallel and serial.
Gabrielzm is offline
post #5795 of 21297 (permalink) Old 08-13-2013, 11:07 AM
bond32's Avatar
Right on, thanks. That's what I thought.
bond32 is offline
post #5796 of 21297 (permalink) Old 08-13-2013, 11:12 AM
jincuteguy's Avatar
Rep: 6 (Unique: 5)
So let say you got a H320 or H220, then you add an extra cylinder Reservoir. Then isn't the only spot that you can put that extra Reservoir is at the top of the case? Since you want the Res to be always above the pump (in this case the pump is the cpu block itself)? Or is it ok to put that extra Reservoir below the H220 / H320 pump in the case and it won't damage the pump?
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Gaming Rig
(10 items)
5820K
Asus X99-A
2 x MSI GTX 1080 Ti Trio
Corsair AX 1600i
Corsair H100i Pro
CoolerMaster C700P
DELL U3014 Premiere 30"
Keyboard
Logitech G910
Audio
KEF LS50 Wireless
Audio
JL Audio E110 Sub
jincuteguy is offline
post #5797 of 21297 (permalink) Old 08-13-2013, 11:33 AM
Hardware Enthusiast
BramSLI1's Avatar
Rep: 207 (Unique: 129)
Being that the H220/ H320 radiator has a built-in reservoir, you can put the extra reservoir pretty much wherever you want. Just remember that if you're going to fill or drain your loop from this extra reservoir that you'll want to rotate your case to have it at the highest position, or it will spill out due to the pressure.
*Official* sonic.gifGigabyte GA-990FXA-Series sonic.gif*Thread/Club*
BramSLI1 is offline
post #5798 of 21297 (permalink) Old 08-13-2013, 12:34 PM
Stablerage's Avatar
Rep: 0
Originally Posted by Stablerage View Post
My pump has begun to make extra noise. It isn't a ticking like I have seen others state more of a whirling Noise. I have it set to silent with the asus AI suite II. It only started yesterday. could this be air? Any help would be appreciated.
Stablerage is offline
post #5799 of 21297 (permalink) Old 08-13-2013, 12:54 PM
Hardware Enthusiast
BramSLI1's Avatar
It could very well just be an air bubble in your pump. Please try the instructions in the OP for removing air from the pump and let me know if they work to quiet it down for you.
BramSLI1 is offline
post #5800 of 21297 (permalink) Old 08-13-2013, 01:35 PM
jincuteguy's Avatar
Rep: 6 (Unique: 5)
So if I fill / drain my loop from the built in Reservoir for the H220 / H320, then I shouldn't have to do that right?
Gaming Rig
(10 items)
5820K
Asus X99-A
Corsair AX 1600i
Corsair H100i Pro
CoolerMaster C700P
Keyboard
Logitech G910
Audio
KEF LS50 Wireless
Audio
JL Audio E110 Sub
