loop orientation - Overclock.net - An Overclocking Community
loop orientation
post #1 of 4 (permalink) Old 03-10-2013, 08:15 PM - Thread Starter
dylanwelch95's Avatar
Rep: 0
hey, should I go from res rad cpu gpu? or res cpu rad gpu?
does it matter which way it is set up, what do you suggest? thanks
dylanwelch95 is offline
post #2 of 4 (permalink) Old 03-10-2013, 08:21 PM
Computer Art
Jameswalt1's Avatar
Rep: 304 (Unique: 206)
Makes no difference as long as the pump is directly after the res (which is just common sense smile.gif
post-flame-small.gifTEARS IN RAIN A Blade Runner inspired build (2017)post-flame-small.gif
post-flame-small.gifPARVUM WARFARE An Advanced Warfare themed build (2014)post-flame-small.gif
post-flame-small.gifPARVUM TITANFALL A Titanfall themed build (2014)post-flame-small.gif
post-flame-small.gifROBOCOP A Robocop themed 900D build (2013/14)post-flame-small.gif
Jameswalt1 is offline
post #3 of 4 (permalink) Old 03-10-2013, 08:44 PM
Rep: 116 (Unique: 108)
The difference is negligible; eventually the loop will reach a thermal equilibrium. The best advice is to aim for minimal tubing and aesthetic appeal.
Only must have rule is that the reservoir be before the pump.
A man who praises himself displays his deficiency of intellect.
Raul-7 is offline
post #4 of 4 (permalink) Old 03-11-2013, 02:39 AM
markovian's Avatar
Rep: 6 (Unique: 6)
this is true dispite what most think ur water temps shuld be stable between blocks ... the exception is in very low flow ... thats a flow problem tho
i dont understand min tube/amount of water yet tbh acording to what i know this shuldent do anything unless flow rate is low
i canot spell punctuate or anything english related beond 3rd grade ... try to decipher im sorry if its hard
markovian is offline
