[Build Log] Case Lab M8 WC Pipe >>Update lots of Images<< - Overclock.net - An Overclocking Community
post #1 of 35 (permalink) Old 03-18-2013, 07:37 AM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
So I finally have the chance to complete a computer build!
First off I would like to thank OCN and the members here for I have gained massive amounts of knowledge for this build to happen. So I'm here to share my experience on the journey I'm about to take that many before me have taken. thumb.gif
Just so everyone can understand the reasons I purchase the items I do. I'm looking to use this computer as an gaming rig, but I will also be running multiple VMware Servers on this computer also. I also plan to straight Pipe my build thanks to the informative guide Pipe Bending 101 by B Negative.
Any thoughts on what I would be best on ordering on CPU Block, Card Blocks/Back Plates, Pump/s, Reservoir. I am all ears. thumbsupsmiley.png
These are some of the parts that I will be looking to order tonight/tomorrow unless there is a reason I should change them.
EDIT: Updated Order List 1
Edit: Ordered Correct CPU Cooler 03/20/13
I'm still iffy on the motherboard as this time I was able to acquire more funds all of sudden that allows me to upgrade to a little bit better motherboard for my purposes so I'm looking at the ASUS x79 Sabertooth.
And I know everyone is probably wondering by now what case will be used for these pieces of eye candy. Well I have that one covered already. biggrin.gif
My case will be arriving on Tuesday and I'm needing to order all my parts by tomorrow afternoon to make sure they are all here on Tuesday also so any alterations will need to be made sooner than later preferably. thumb.gif
PRON UPDATE
Ignore the date on the pictures I know its wrong. I am not using my camera. redface.gif
So I immediately came home yesterday after work and I am greeted by three shipping boxes. biggrin.gif
Initial thought are school what is school I have a machine to build!!! But alas I held out from the impulse to miss class last night. I still believe I made the wrong decision there... rolleyes.gif
However back to the CASE PRON!
So when you have three boxes to open which do you open first the small ones or the big one first. thinking.gif
Well I decided to start with the big one first since I've always loved the Case Labs Cases.
I have to admit I have read many build logs with Case Lab cases stating the packaging is superb for these chassis. I would have to agree wholeheartedly that the packaging is superb. The next pron will I give is the M8 Chassis out of its shipping box which was suspended in the middle by four wrap around corner pieces of dense blue foam. Now I have seen packaging of a lot of expensive equipment before and I must say the packaging that Case Lab does takes the whole cake. See the plastic used to wrap the case its so thick its not even funny your not going to be getting through that plastic by no means easily with out a very sharp knife. I would estimate the plastic to be at least 3-4 mil thick if not 5 mil.
And the M8 unsheathed.
Front View
These next pictures are taken inside after I came home from school last night. 03/19/2013
Here is what the packaging of the inside looks like. Talk about not allowing anything to move.
Inside of the case with out the packing paper.
And here are all the extra parts you get with the M8. This picture does include some of the parts used for installation of the grounds on the motherboard removal tray. biggrin.gif
Okay so now some HARDWARE PRON
Hardware displayed on top of the case.
Sabertooth x79
Checking the pins for the CPU
Checking the DIMMs
Checking the PCI-E
Checking the VRM Heat-sink
Checking the TUFF
Intel I7 3820
Crucial M4 256GB
HyperX Genesis 10th Anniversary 16GB
Corsair SP120 High Performance Edition
Update: 03/25/13
I know I said I would get these pictures up a about two days ago, but real life intervened. Hope you enjoy not to many pictures at this time wished I had more to upload, but alas I do not. frown.gif
Noctua NH-D14 SE2011
This heat sink no lie is massive and is well worth the money you spend on it. I mean it covers almost the entire board!!! lmaosmiley.gif
Corsair AF120 Quiet Edition
The Corsair AF120 Quiet Edition fans are not to bad they are quite, but being practically deaf makes them almost silent. rolleyes.gif I think I prefer the high performance though on my fans just for the higher out put.
Components being installed
At this time thats all the pics that will most likely be uploaded till possibly next month. I may try to buy a few pieces this check but rent comes out of this coming check frown.gif
Drierwor is offline
post #2 of 35 (permalink) Old 03-19-2013, 06:15 AM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
>>>UPDATE<<<<br />
Packages are in route to my house now. thumb.gif Will have some pictures up later tonight if not early tomorrow. I have work and school today. So I won't be home till late. frown.gif
Edit: don't know why there is a break in the update part. thinking.gif
Drierwor is offline
post #3 of 35 (permalink) Old 03-19-2013, 01:06 PM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
UPDATE
Apparently OCN recognizes the greater than and less than signs as
lol.
But thats not the update I'm talking about Have 3 large boxes at my house waiting on me. biggrin.gif
Drierwor is offline
post #4 of 35 (permalink) Old 03-19-2013, 10:09 PM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
I have hit the first bump in the road... The Cooler Master Hyper 212+ does not work with the LGA 2011. Sigh... Should of looked the cooler over more... I have a select few Computer shops around I will check tomorrow for a cooler. So much for the computer at least getting a POST tonight. rolleyes.gif
Drierwor is offline
post #5 of 35 (permalink) Old 03-19-2013, 10:12 PM
Boweezie's Avatar
Rep: 36 (Unique: 23)
Boweezie is offline
post #6 of 35 (permalink) Old 03-19-2013, 11:20 PM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
Originally Posted by Boweezie View Post
I tried uploading some pictures tonight, but it keeps failing... frown.gif I will try to upload again later in the morning since its about 1:20am in the morning here.
Drierwor is offline
post #7 of 35 (permalink) Old 03-20-2013, 09:58 AM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
PRON UPDATE
Front View
Hardware Displayed on top of the case.
Sabertooth x79
Checking the DIMMs
Checking the PCI-E
Checking the VRM Heatsink
Checking the TUFF
More to come figured I'd give you all a little eye candy while waiting on the others images. thumb.gif
Drierwor is offline
post #8 of 35 (permalink) Old 03-20-2013, 11:44 AM
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
Looking good and thanks for the mention!
If you want any help with your loop then post up in the thread and I will guide you the best I can.
B NEGATIVE is offline
post #9 of 35 (permalink) Old 03-20-2013, 11:53 AM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
Sweet appreciate it. Just had a box of fans come in nothing much at the moment. But I'm about to have more pictures uploaded. biggrin.gif
Drierwor is offline
post #10 of 35 (permalink) Old 03-20-2013, 12:21 PM - Thread Starter
Drierwor's Avatar
Rep: 3 (Unique: 3)
All Pictures Are Provided In First Post As Well
Sabertooth x79
Checking the DIMMs
Checking the PCI-E
Checking the TUFF
Intel I7 3820
Crucial M4 256GB
Last but not least; this arrived while creating creating this post. biggrin.gif
Drierwor is offline
