[Build Log] Phoebus Temjin 07 (Finished) - Overclock.net - An Overclocking Community
post #1 of 129 (permalink) Old 03-20-2013, 10:24 AM - Thread Starter
JottaD's Avatar
Rep: 4 (Unique: 4)
Hi this is the new rig for my work and pleasure.
Long time ago I was planning to have a water cooling system and looks like now I´m able to do it biggrin.gif
Here the list of Phoebus computer parts
Hardware:
Silverstone SST-TJ07B-W USB 3.0 - black
Motherboard Asus Rampage Iv Extreme
Intel Core I7 3930K
2x EVGA Geforce GTX 680 SuperClocked
2x 32 Gb Corsair Dominator Platinum 2133MHZ CL9
Fonte Corsair Digital AX860i
Asus Rog Xonar Phoebus
SSD Kingston 240Gb Hyperx 3K Bund-Sh103S3B/240G
Western Digital 2Tb - Wd2002Faex
Drive Slim Silverstone SST-SOD02
Sleeve MDPC
Water Cooling:
EK Water Blocks EK-Supremacy - Nickel
EK Water Blocks EK-FC680 GTX - Nickel CSQ
EK Water Blocks EK-FB KIT RE4 - Nickel CSQ
Rad Hardware Labs Black ICE Radiator SR1 480
Rad Hardware Labs Black ICE Radiator SR1 240
Pump Alphacool VPP655 - Single Edition
EK Water Blocks EK-RES X3 110
EK Water Blocks EK-RES X3 250
Primochill 16/10
Mayhems Aurora - Tharsis Red Coolant 1000ml
Bitspower 16/10mm - Matte black
Bitspower 90º Rotary - Matte black
Bitspower crystal links
Bitspower Multi-Link Adapter
Aquacomputer Aquaero 5 XT
Aquacomputer Temperatursensor inner/outer thread G1/4”
Corsair AF120 Performance Edition - 120mm
Alphacool HF D5 TOP - Black Acetal
Modding by HardModding
JottaD is offline
post #2 of 129 (permalink) Old 03-20-2013, 10:25 AM - Thread Starter
JottaD's Avatar
Rep: 4 (Unique: 4)
Build log is finished
Here are the final pictures for the Build, excelente work made by Gambo thumb.gif
I got the PC case monday 23/12/2013 in Oslo, excellent packing, all ok!!!
I hope you like it
JottaD is offline
post #3 of 129 (permalink) Old 03-20-2013, 10:25 AM - Thread Starter
JottaD's Avatar
Rep: 4 (Unique: 4)
JottaD is offline
post #4 of 129 (permalink) Old 03-20-2013, 10:31 AM
GerBem's Avatar
Rep: 7 (Unique: 6)
subbed
GerBem is offline
post #5 of 129 (permalink) Old 04-30-2013, 06:35 AM - Thread Starter
JottaD's Avatar
Rep: 4 (Unique: 4)
Now its time for a update:
The theme for this mod is based on the Asus Rog Xonar Phoebus sound card and we will invert the motherboard tray so will be the first thing we see from the top window from the case.
Here some render test made by Hardmodding:
The inverted motherboard tray that is the same length as the case
The midplate as the same lenght as the mohterboard tray
The side panel and the top panel
The front panel
JottaD is offline
post #6 of 129 (permalink) Old 05-01-2013, 10:43 AM - Thread Starter
JottaD's Avatar
Rep: 4 (Unique: 4)
Here a new update, time to turn on the CNC machine
front panel
top panel
later some more updates for the PSU panel and the radiators stands
JottaD is offline
post #7 of 129 (permalink) Old 05-01-2013, 10:46 AM
Not a Linux Lobbyist
Solonowarion's Avatar
Rep: 42 (Unique: 41)
I believe I am going to enjoy this!
Solonowarion is offline
post #8 of 129 (permalink) Old 05-01-2013, 10:46 AM
ledzepp3's Avatar
Rep: 110 (Unique: 85)
1995 Chevy Impala SS: Dark Cherry Metallic, Nitto NT555's (255/40/W17), Flowmaster 40 Series Mufflers, stock 350-LT1 V8. The Daily.
2006 Pontiac GTO: Brazen Orange Metallic, 6-speed, Stock Internal 6.0L LS2 V8, SLP Long Tube Headers, SLP Loudmouth II Cat-Back, Custom Catless Mids by Red's Muffler, Trickflow Intake, BMR Aluminum Skidplate, Hinson Motorsports Single-Piece Aluminum Driveshaft w/ Forged Chromoly Yolks, Hinson Motorsports Short-Throw Shifter, Melling High-Volume LS2 Oil Pump, Powerbond 15% Underdrive Pulley, SCSS Oil Pressure and Boost/Vacuum Gauges, BMR Sub-Frame Connectors, BMR Strut Tower Brace, Hotchkis Front/Rear Sway Bars, Roadsafe Bushingless Front Swaybar Endlinks, Tow Brace Delete, Hinson Polyurethane Transmission and Motor Mounts, Koni Adjustable Shocks and Struts, Whiteline Upper Rear Shock Bushings, Whiteline Differential Support Insert, Whiteline Upper Strut...
ledzepp3 is offline
post #9 of 129 (permalink) Old 05-01-2013, 10:49 AM - Thread Starter
JottaD's Avatar
Rep: 4 (Unique: 4)
Originally Posted by ledzepp3 View Post
JottaD is offline
post #10 of 129 (permalink) Old 05-01-2013, 11:31 AM
Syan48306's Avatar
Rep: 149 (Unique: 115)
Syan48306 is offline
